Isuzu Rodeo Heater Problems
                                  in Isuzu
                    I have a 1992 Rodeo LS $x$ V6 3.1. My heater worked fine last year, but when it got cold this winter and I turn it on it only blows cold air. I was told there was a control valve that lets coolant from the engine into the heater core and that it may be malfunctioning. Does anyone out there know if this valve exists in the 1992 model, and if it does if it's turned on by a cable or electronically?
I'm in poor health and it's the only vehicle I have. Any help that points me in the right direction in getting this fixed even in the short term until I can afford to get it to a shop would be graciously appreciated.
The blower fan is not working? I tried a new blower motor and that didn't work. All fuses seem to be ok. When it did go out there was a burning smell from the dash.
Thanks in advance
Phoenix
Thx for your reply
Phoenix
Here is some info on the heater control valve:
Heater Water Control Valve
REMOVAL & INSTALLATION
On early models the heater control valve was part of the heater core inlet. To replace the control valve, remove the heater core. Remove the control valve from the heater core, being careful not to damage the core. Use new gaskets when installing new valves.
The remainder of the vehicles are not equipped with heater water control valves. They use heater unit doors to regulate the amount of heat entering the vehicle.
Again thanks
Allyda
