TCM on 2001 Isuzu Trooper?
2001 ls trooper,need to locate where transmission control module is located?
Also i do know qualified izuzu tech is my best answer,I live where that doesnt exist,dealing with trans guy under warranty work, that cant find why trans is not recieving enuff power too engage trans? He has checked all wires underneath vehicle that runs trans power,did find wires that may heated and may had able to cause problem ,was all replaced,no luck. This censor or case connector you talk about?would this be located from PCM(behind battery?) that we could trace to A to B or C and D if thats what it takes? sorry to keep u guessing,Hes been guessing 5 months.
Plus, you're sure to get spammed now that you've posted your email. We try to fool the spambots by making the "at" sign a graphic, but it doesn't help much.
You can mark your email public in your Profile and hide it from everyone except registered members. Any member clicking on your name can then get your email. Still not foolproof but it helps a lot. Shoot me one if you'd like your post removed so you can repost without the email.
