fast flash turn signal 2005 Crown Victoria
                    Anyone know what to check for as to why my turn signal flashes fast?  This happens only on left turns.  I switched the turn signal bulbs on the left side with the ones on the right (both front and rear), but it didn't solve the problem.   The emergency flasher works fine (no fast flash, left and right). After reading in another forum that a blower motor speed can cause fast flash, I turned the blower fan to maximum and minimum speeds, but it had no effect on the flash speed.   I'm thinking an electrical connection may have jarred loose from hitting all the potholes lately.
If this is not the case, make sure that one of the bulbs has not been replace with a LED replacement. This will cause a fast flash. You can get a resistor to place in circuit with LED's to make the flasher cycle normally. The only thing that will make your turn signals flash fast is a lack of resistance, as in a burned out bulb or a replacement LED unit.
Also, if there is a faulty ground, this will cause dim illumination. Make sure that there is a solid, rust free & dry connection of the ground wire.
