Toyota Highlander Electrical Problems
My cigarette lighter and other ac outlets in my car not working. I have verified that fuses are functioning correctly. What are my next steps to resolve the issue?
Does ac = air conditioning, or do you have alternating current outlets?
The problem is the contacts behind the temperature control dial. First step is to pull off the dial and, holding the stem from turning, tighten the lock nut. Test the system. If that doesn't work, the problem is deeper in the two connection to the dial control. If you're that handy, open it up and re-solder the leads. If not, you're at the mercy of the dealer.
Good Luck.
I have a 2002 Highlander that seems to be having exactly the same problem. My temperature knob stopped working then today I lost all the gauges on my instrument panel as well as my radio, and air conditioning.
What was causing your problem and what did you have to do to fix it?
thank you for your time
santi
