Visitor Agreement.
Also, I saw a hard top liner an ebay that looked like it help reduxce the road noise (if you have a hard top).
I assume they are TOTALLY waterproof, right? Are they too hot in the summertime? Do they fade from exposure to sunlight? Are they easy to clean? Do they stain easily?
Tom
Have you hugged your Jeep today?
I think I'm going to research the various materials, and line the entire interior floor and sides. All I have to do is remove the seats console and carpeting, so that part should be easy. Then, put a underhood liner in. If that is still not good enough, I may try something in the doors as well. I've seen some wranglers with spray on bedliners in the tub, put I think the right soundproofing material would be better (except when getting soaked like tsjay!).
Next step maybe a firewall covering, but not sure. I would like to take a look at the new unlimited to see what all Jeep did to those to make them quieter as well.
I might get a sound meter and see if I can actually document the improvements objectively.
Time to chip in and get Tom (and Ross Allen) one of these?
I wish I could explain how it was, but I'll just put it this way. You know how thunder and lightning are supposed to be way up high over your head or off on the horizon??? Well, Baby, the thunder and lightning was going on right around us it seemed, and it seemed like it was at our level, not way up in the air! There was one long bolt of lightning that didn't just flash and disappear. It seemed like it just danced and sizzled for a few seconds!
Oh well, looks like we survived, and neither RA nor the Old Tomster got sick from the long trip home while soaked to the bone.
Tom
Tomorrow we should get the Wrangler back and find out how much it will finally cost me. Sigh. I'm not looking forward to that!
I'm definitely going to put XM radio in the Wrangler - it made the drive between Vegas and LA better than before. Now that I have the A/C fixed perhaps we'll take my Noble Black Steed next trip.
Took me forever to catch up on the 150+ posts I missed. The gear ratio explanations were GREAT. I copied and pasted those for future reference.
It got me wondering how I can find out what my Jeep has. Which rear, 44 or 35? What ratio I'm set at? I bought it used so I'm clueless about what it has. It is running 31 x 10.5 tires.
If I climb under there and physically look at it, is there something I should look for?
As always, thanks.
-Dan
However, here are a couple of other sites to check out:
http://www.allthingsjeep.com/jehali.html
http://www.gatortop.com/
I am sure there are others as well.
Good luck
Glen
For gear ratio, you should find a metal tag on the differential housing that gives that ratio, but it could be gone by now or unreadable even if still there.
What you might want to do is contact DC and request a build sheet. This will give you a list of EVERY single thing that your Jeep had on it from the factory, including the type of differentials and, I THINK, even the gear ratio.
Do a search on "factory build sheet" to learn how to request one. If you can't find the info, post, and I will fill ya in.
Tom
P.S. I did the search for ya, and several posts came up. I copied what it said in one of those posts, but if you want more detail, you can look at some other posts on the subject. I think this will give you what you need, but you might have to play around a little bit once you are on Jeep.com to get to the right place.
"If you want to know your gearing, get a build sheet for your Jeep, and it will have that info. You can go to Jeep.com and then "contact Jeep." On the email form, tell them that you are requesting a build sheet, then give them the last eight characters in your VIN in the space they provide. You will get a VERY quick response from DC.
I've heard nothing but good about Okoles, it's something I am considering one of these months. I have never used them, but do dive (they are made of neoprene, same as wetsuits) and suspect that maintaining them should be somewhat like taking care of a wetsuit: The stuff is easy to clean, and like most things they will fade somewhat in time given a lot of exposure to the sun. The material is pretty durable, but can wear given a lot of use (what doesn't?!). It's not typically watertight, so I would guess that some water will still get by to the seats unless they have a non-breathable layer somewhere in there... (Edit), It probably depends on the kind of downpour we are looking at. Light rain will probably not soak the seats, but something like what you describe might allow for some water to penetrate the covers.
Andrew
-twylie
3 years ago today drove to Atlanta to pick him up. 3 years & 29,000 miles later still looks brand new..
TOM, man sorry about you geeting soaked on your trip back. I bet that was a sight from other drivers. "look at that old man getting wet" LOL.
glad you didnt get sick.
Keep Jeepin'
Bama
Jeep sent me the build sheet within a day of requesting it!
Here's the axel info:
Axle - Front, Dana 30/186MM
Axle Ratio - 3.73
Axle - Rear, Dana M35/194MM
Axle - Anti-Spin Differential
Looks like I have the 35. I haven't done any off roading (yet) so, I'm not completely disapointed. I figure I'll ease into the off roading thing easy. Maybe do a Jeep Jamboree and stick to the easy trek. Do I have anything to worry about running 31" tires and daily driving? It came stock with the 30th pkg
anyway, thanks.
If you ever get into more than just mild offroading, you can consider a Super 35 upgrade to your rear axle.
Tom
Mac24, tell me what has happened. I got the back seat bracket off on the passenge side. The bolts turned hard all the way out, but I got 'em.
Then, on the drivers side, I broke something. Those bolts were turning about as hard as the other side or even harder. I got a half inch drive power handle and used the reducer to get the 3/8 drive socket on it. I guess this was too much torque.
Now, if I broke the bolts, why can't I get the top end of the bolts out???? Something definitely broke, and the bolts turn freely now, but they WON'T come out!
The passenger side didn't seem to have a nut on the underside of the floor, but it sure seems like there was something like a nut that the bolts threaded into on the drivers side, and whatever it was broke loose. That's the only explanation I know of why I can't just take the bolts out, even though they turn freely.
I was removing seat belt anchors and back seat brackets in preparation for the Rhino Lining. The guy that does it says he gets over $200 more if he has to remove all that stuff. I will need to remove the passenger seat and the center console when the time comes. I will drive Thelma Jane down to the place that does the Rhino Lining, about 35 miles away, with just the drivers seat and no console or passenger seat.
I can always cancel my appointment, if there is some good reason not to Rhino Line Thelma Jane. If you know anything good or bad about it, please speak up.
Tom
-twylie
You said heat is a problem??? Ross Allen rides in the cargo area, and the floor will be hotter after the liner is in?
I bought him a sheet of styrofoam insulation the other day, since the floor was already warm back there. I bought the stuff that has a layer of something on one side to reflect heat.
Think I'll have a problem with the liner, if I use that insulation?
Tom
-twylie
Well, like you said, I can always throw a mat in there for myself and one for the passenger, and I have that insulation thingy for RA. Oh, I have also mounted a little 12 volt fan to the back of the center console, so RA has his own fan now.
Tom
-twylie
Still don't know what broke loose when I was trying to back those bolts out for the seat bracket. Will take a look underneath tonight. There must be something under the floor that those bolts thread into, and whatever it is must have broken loose. The bolts just turn completely free of any resistance, but they will not come out.
Tom
Tom
Thule has one for about $150.00 that bolts to the spare. Yakima/RhodeGear makes one for less that straps ONTO the spare -- but, I'm thinking the tailight assembly would prevent it from ataching correctly. There's also an older Yakima/RhodeGear one that bolts to the spare for like $50, but it seems rather flimsy (saw it in a clearance catalog). I know there's an actual Jeep-made rack out there too.
Any suggestions?
(Someone in an older post said they put a standard trunk rack on the FRONT of the Wrangler -- that's awesome!)
Mike
I think if I did it again, I would put a 2" receiver on the front, and go with a receiver mounted rack. This way, no stress on the tailgate, still easy to open the tailgate, and could still use the rear receiver for a trailer or other accessory.
Tom
Ripped a side wall Saturday as I drove past some tree roots on the trail at Turkey Bay. This forced me to use the spare, which has a deep gouge near the bead. So, it's time for some tires. I have a good amount of tread left, but I have really chewed up the sidewalls.
Guess I will go back with the 31 x 10.50 BFG Muds, like the current set. They sure give me good traction on the trails.
Have committed to staying with just my little two inch Procomp lift. I get around real good with my current set-up and see no reason to go to all the expense of going to a higher lift and bigger tires.
Tom
I'm starting to think about new tires again, and am not sure what I want to go with. Been thinking about the BFG AT tires - I've seen them at Costco and am thinking that might be the way to go, rather than with the Bridgestone Dueller ATs again. It'll be a while before I do anything about it - gotta build up my car-repair funds again!
They were real good tires for mild offroading and highway use. They just weren't agressive enough for all the wheelin' I do, so I traded them in with 6K miles on them for the set of BFG Muds that are on Thelma Jane now.
I think you would like those BFG ATs, and you would get some real good tread life out of them.
Tom
-Pete
I have the BFG A/T KO's on my TJ. I agree with Tom, for mild offroading, they are very good. For more severe offroading, the mud terrains like Tom's would be a wiser choice.
But I know that you use your NBS for fire trails around here. In that case the A/T KO's would be great for you. They are pretty quiet (relatively) on the road. You'll hear the wind more than the tires.
Keep in mind, with the A/T KO's the tread pattern is NOT conducive to getting water out of the way on a rainy day (like we have lots of THOSE around soCal).
-Paul
By the way, Paul, nice photos of the Caribbean.
I have to contend with mud and loose soil when I am wheelin', and the Mud Terrains are much better for my purposes.
I think you will really like the BFG AT's.
Tom
-Paul
Paul - I'm thinking about it. I'm looking into it. I'm drooling. And it is SO close. Are you going to go?
-Paul
Can we just sort of skip over July and go straight to August?!
-Paul
this is getting old you can almost set your calendar by this. Happens every 4 months.
since my warrenty is over, I really hate to take it to dealer to get fixed. only for it to come back 4 months later.
How can I get this fixed for good? I gonna drive it for awhile. Last time it went off on its own. maybe it will this time as well.
I owe about 2300 on TAZZ hopefully he will be paid for by the end of the year. Then im gonna try to get new wheels & tires.
Keep Jeepin
bama
I do not know if it is a bad seal at your gas cap or not, but it is a good place to start. Why don’t you remove the cap and replace the cap until it clicks a few times and see if the light goes off in a couple of days. You may even consider buying a new one just in case (there not that expensive).
The dealer should have been able to connect to their computer and tell you why the light was on. Did they tell you anything the last time you took it in?
I believe AutoZone will read codes for no charge. Guess they hope you will buy whatever part you need while you are at their store.
Good Luck, Old Bama.
Tom
Hey, check with your insurance to be sure the deductible applies on glass breakage. Here in KY, there is no deductible, and I think it is by law that there is no deductible. So, it wouldn't hurt to check.
Also, you said crack, so maybe it is too late, but if all you have is a chip, then it can be repaired, and the windshield would not have to be replaced. I have had three different chips repaired on Thelma Jane. I prefer that to a new windshield, since there is the possibility that the new winshield might not fit right and might leak or something.
If you have to pay for this out of your own pocket, then it is much, much cheaper to have the chip repaired. If it is actually a crack, then I guess it will mean a new windshield.
Tom
If you are comfortable doing the work yourself, you could probably replace the glass yourself, just get a new gasket kit from some place like Quadratec, get some of the glue stuff they use, get on your hood and do it.
You might be able to find a decent windshield at a salvage yard. But here in CA, most insurance companies will cover glass replacement, but my deductible is high enough, that it is higher than the cost of replacing it.
