2005 Z71 Suburban, Driver heated seat out of control
in Chevrolet
I purchased this 2005 Z71Suburban back in 11/29/09 and also purchased extented warranty. This morning when I first started the vehicle, it sounded as if it got an extra boost of energy. Not a normal startup. It did not start the same way as it usually does. I thought nothing of it until going down the road and noticed the heated seat was on for the driver side. After a while it was OUT of CONTROL going thru all the heat levels. I came home and heard a clicking sound from under the seat. Looking under the seat it looked like the sound was coming from a sliver looking cylinder about 4" long right in the middle of the seat. I then remove the refuse, which is labeled IGN-3 and is for the ignition/heated seats. The Heated seat for the driver side was still coming on, not sure why. After checking other places in my owner manual, I found no other locates for a heated seat fuse. I put the ues back.
I called the dealer and they can not say anything until they see it and charge me $$$$$. The extented warranty covers everthing except heated seats "go figure". So my next step is to find what the problem is and if I can replace it my self. Any thoughts would be helpful.
Thanks, Scott
Thanks, Scott
Did you ever find out what the problem with your seats was? I'm having a very similar problem with my Tahoe LT. The d/s heated seat comes on and cycles through all levels then to off and back on again. It seems that the computer or the relay thinks the switch is being held down??? Any thoughts are much appreciated!!!
Greg
Cycling non stop!
Did any of you find solution?
Also, rear wiper and defrost work very sporadically. Anyone else experience this???
