Mazda CX-9 No Start Problems
                    Mazda CX-9 2008
Sometimes when I get into my car, the steering wheel locks
and there is no play in it. I do NOT exit the car with the steering wheel
locked.
It takes enormous strength to turn the wheel just a bit to get the car
to start. It seems to be an intermittent problem.
I tried a solution I locked and then unlocked the car with the fob while I
was in it and that sometimes cures the problem.
The problem just started after owning the car for 2 years.
At times the KEY light flashes when I start the car too.
Don't know if it is related.
I took the car to the dealer and was told the steering mechanism
works and there is no problem which is incorrect.
I am nervous to start the car when I have an appointment to go to
since it sometimes takes 5-7 minutes of fiddling with steering wheel
before the car starts.
locked.
At first I thought it was the battery, but it is fine and there is no cranking from the starter. There is a flashing key on the console making me believe this is an antitheft issue.
I have 2 keys for the car. Neither key will unlock the doors. The nearest dealer is 45 miles away. Towing it would be an expensive option!
Any thoughts would be appreciated. Thanks.
I'd love to figure this out without taking it somewhere. Thanks!
