I have owned a number of cars with Interference engines (mostly hondas). As long as you know going in that there is a belt and that it needs to be checked and replaced, then it shouldn't be a problem. Now if you are the type of owner that does not keep up on the maintenance of your car...well...getting a car with an interference engine may be an expensive decision.
In my case, the decision to go with the Cruze ECO really was driven by financial payback as much as it was driven by a desire to get a car that delivers great fuel economy and was enjoyable to drive. My wife has a Lexus RX330 AWD, which we love but can be a bit discouraging when it comes time to tank up :surprise:
I hope you enjoy a great Thanksgiving!
While I would have agreed with that statement back in the era of conventional oil; when synthetic oil is used there is no evidence to suggest that a turbocharger will have any negative inpact on the life of a gasoline engine.
Also my poor grammar indicated Engine Life problem, Sorry I should have stated "Turbocharger Life"
As you said Engine Life is NOT the issue here.
Also to point out again, the 1.4L Turbo engine has a Timing Chain, per Gates which will prolong maintenance intervals.
http://www.gates.com/part_locator/index.cfm?location_id=3598
The most common cause of Turbo failure is shutting the engine down after a run where the Turbocharger is at "High Temperature"
The engine should be allowed to idle for several minutes to allow the oil to cool the turbo. Even water cooled turbo's need time to shake off the extreme temperatures to minimize coking.
Failure to utilize some method of cool-down results in "oil coking".
The oil burns and solidifies to the Turbo shaft causing abrasion to the oil seals.
Then turbo lubrication/cooling oil pumps into the exhaust, this is obvious only on a cold engine, upon fully warmed up engines, this will Not be visible as the Catalytic Converter is "Flamed On"
Eventually the Converter will stop up, hopefully before the engine seizes.
Some oil additives claim the ability to ward off Oil Coking in this situation.
Pro-Blend in South Carolina is my personal favorite additive mfg.
I think Z-Max has this claim also.
Also just FYI, "Mobil 1" Oil is a synthetic oil ONLY in the US.
European Specs disallow it from claiming to be a true synthetic.
Waaay back when it first came out, it was called a "Pseudo-Synthetic"
As you stated, real synthetic oil will help coking problems on turbo's however MOST owners don't even change oil on suggested schedules.
15 psi boost @ 1850 rpm !!
Dat seems like a lot, that is good to hear though.
DrVette
In "87 & up GM Trucks with the 350[TBI] Throttle Body engines, many customers liked the bellowing intake roar under full Tilt.
This "moan" that was so reminiscent of a Quadrajet on a High Compression 327 Chevy that many "motorheads" found a twist of the distributor and some 93 octane allowed drag-racing Trans-Am's, Mustangs etc with success.
Now find Crown Vic's and most vehicles with some legacy of speed to have dropped the intake noise suppression tube in favor of a muscular sound.
IMHO, the mfg's have intentionally done this for those who enjoy this particular style of music.
Keep in mind, this sound is ONLY made when your foot is in front of the radiator
DrVette
The Oil Filter is on TOP of the Engine ?
Wow, what a mess, they could have done like my "94 GMC 4X4 Jimmy and ran some lines and put the filter next to the radiator, neat and clean, no drip, no fuss, no mess.
From your description, it's a paper element placed inside of a "non-replaceable' canister/housing, correct ?
DrVette
A while back they ran a Prius Hybrid around the track WIDE OPEN for some extended period of time.
Following closely behind the Prius was a BMW with some massive 400~HP engine.
After running quite a while they figured the economy of both vehicles.
The BMW got 19+mpg
The Prius got 17~mpg
I'm an old wrench, in the early 70's I had a 72 Datsun 1200 that I modified it to 198# Compression[stock was 165], Carburetor Jets to match and about 34 degrees ignition advance.
Man was it FAST !
On the highway I could get 48mpg~
Running hard, I have gotten as low as 14mpg
It's all in the right foot :shades:
DrVette
Some guys FLY by, SLAM on the brakes, then I PASS them while I hear their engine turning 4200 rpm at WOT trying to get back up to speed.
On multi-lane roads where traffic lights are a mile or two apart, it does absolutely NO good to run 128 mph between lights. 65-70 in a 55 works just fine.
I only Hyper-mile when I do not Pizz off folks behind me, on multi-lane roads with light traffic,, PASS Me if I'm going too Slow
Speaking of driving FAST, I go from Atlanta to Denver pretty often.
It's like 1500 miles, more or less.
If I drive "Breakneck Speeds" like 20 -40 over, I can do it in like 22 hrs.
Driving 10-25 over, it takes 24 hrs~
Is it worth it ?
To save a couple of hours, burn LOTS more fuel, not to mention the very good odds of making NEW Friends with Badges :shades:
On shorter drives, like 20~miles or less, do the MATH, driving like an idiot saves just a couple of minutes, wears out your brakes early and makes you generally bitc*y
DrVette
I find it interesting and slightly contradictory that you will go to the extreme of coasting for great lengths to catch a green light but consider your "normal" highway driving to be say 75-90mph. 90 mph is not only dangerous but is obviously terrible on the mpg.
Why? Water cooled bearings and Mobil 1.
DrVette
Also it is lowered for improved aerodynamics.
DrVettte
Yup, Diesel Fuel is approx 20% more than Reg Gasoline
A 20% increase of the 2012 ECO's 42~mpg[with Stick shift] yields NO Gain.
More initial Cost
More upkeep
Etc
So What is the Real Problem Here ?
The EPA insists that Gasoline & Diesel powered cars get the same CO2 and particulate footprint.
This after spending $B's on BioDiesel research.
You CANNOT run pure BioDiesel in VW's TDI or Any other Diesel Engine that uses a DPF Clean-Out shot of fuel.
Why ?
Modern Diesel auto engines have up to 5 Shots of fuel per power stroke.
4 for the Power Stroke and the last shot is with the exhaust valve OPEN to Burn Off the DPF [Diesel Particulate Filter] .
BioDiesel does NOT atomize as easily as Crude Based Diesel
When fired for the DPF cleaning cycle, it collects on the cylinder walls and washes into the crankcase diluting the oil.
VW will NOT warranty engines running BioDiesel stronger than B-5 [5% BioDiesel.
B-100 does NOT require a DPF or other methods to eliminate particulates yet the EPA has seen fit to basically eliminate the modern Diesel Passenger Car from the US market,
BTW
Big Oil has a vested interest here.
The cost to mfg Ethanol is 4.0 BTU's per 1.0 BTU of Product
The cost to mfg Bio-Diesel is 0.25 BTU's per 1.0 BTU of Product
That's right, it takes FOUR times as fuel to get each BTU of Ethanol produced
BioDiesel has a Four Hundred Percent profit margin,, hmmm,
I wonder just WHO would be against such a High Profit industry ?
Keep in mind, large OTR Trucks use approx 25% of the Diesel in the US.
Any Thoughts ?
DrVette
Still seems low to me, your terrain or traffic conditions may dictate harsher acceleration.
DrVette
I think "Politics" and "Big Oil" have more to do with the CO2 emissions particulate requirements than Clean Air !
drvette, "Chevrolet Cruze" #760, 1 Dec 2011 10:24 am#MSG759
Checking with my dealer on the "Retail" price of the Cruze's Turbo, I was pleasantly surprised.
Turbo - $650.00~ Retail
Labor Time R&R - 2.0 hr~
The Turbo comes as an "assembly" including the exhaust manifold, plumbing for oil etc.
It has a "Core-Charge" so obviously they rebuild them, which usually only involves seals & bearings and tolerance inspection..
Shocking this was, after checking the "Other" brand turbo offering some 20+years ago at a outrageous $2500.00~
If owners of the 1.4L Turbo engine will observe common and simple operator usage instructions, they should last a very long time..
Typically, owners should note driving/operating situation just prior to stopping the vehicle.
If High-Engine-Speeds, High Ambient Temps, High Engine Temps or any combination of operation variables that result in ;;
1. High Turbocharger Temps
2. High Turbocharger RPM's
3. High Engine Coolant/Oil Temps
You should IDLE the engine for several minutes to allow the oil in the Turbocharger Lines to Cool Off and the Turbo allowed to cool down so that the oil does not solidify [Coke] onto the shaft of the Turbo which will destroy the seals.
Sorry for the lengthy posting
DrVette
Many of the years going from Atl to Denver were during the 55mph max days, lots of the divided Hwy's from the MidWest to I-70 were down as low as 50 in the day.
Just FYI
You'll have to convert the Litres per Km to MPG to get an idea of how severe the problem is.
http://www.chevroletcruzeforum.com/index.php?/forum/25-cruze-20l-diesel/
DrVette
Is it worth it ?
Nothing above was indicated to be in the past. You're the one that said "if I drive" which indicates to me present tense and would be different from "when I used to drive" for example. How was anyone supposed to know this was "in the day"? Most current interstate speed limits are 65-75. You never said you were talking about 30 years ago.
The idea that you could get a car with a bigger backseat for just a few thousand more doesn't really matter to folks who WANT a small car.
litesong wrote:
I've always been a small car person. But with this surge of higher mpg ratings in bigger vehicles other than sub-compacts, I've been looking at the larger vehicles like Chevy Cruze, Elantra, Focus, etc. I want a vehicle I no longer have to apologize to passengers because 3 people are compressed into the backseat. One note no one talks about...... Chevy Cruze has fairly good interior rear seat shoulder room, but Elantra has about one inch MORE shoulder room, altho the Elantra exterior width is narrower than Cruze. Narrowness of exterior width is very important to small car drivers who are thinking about purchasing a larger vehicle. Additionally, Elantra turn radius is less than Cruze, altho Elantra has a more comfortable & longer wheel base than Cruze. That Elantra rear seat leg room is more than the Cruze also is a factor in favor of Elantra.
I have found that tiny bit of torque available at high rpm and use it daily.
Doc Vette i sure do like your style/facts/presentations especially relating the current diesel+adblue vs gas+ethanol structure and the arithmetic/power-mechanics/tax-structure/$ behind it. no apology necessary to me for length of posting or anything else. your points/questions are spot on!
i still want to testdrive a diesel cruze! the car is so well balanced with the gas motor... how much more does the diesel drivetrain weigh compared to gas drivetrain, for both auto & stickshift. (probably there will be no stickshift diesel cruze? that would be tough to resist just for drivability fun, no matter the price of gas vs diesel . )
For the Cruze Diesel to be attractive, it will have to get "super" economy to surpass the Gasoline Cruze's efficiency.
Note the vast array of vehicles that get poor mpg for the size/weight
i.e. Jetta Gasoline, Nissan Versa and too many others to name.
The Focus is plagued with tranny probs on the "AT-6" and instrument cluster issues for some.
IMHO, the Cruze is the thinking mans choice for a long-term transportation.
Here's a link to one European Cruze Forum directly to the Diesel Page.
My attempt to purchase a Cruze has been dismal and heartbreaking.
I've contacted many dealers, researched all avenues of incentives and still find the OTD price to be @ MSRP w/TTT
DrVette
re cruze pricing, for the LS the difference between invoice and msrp is barely $700. i paid MSRP minus incentives/GMcard/etc. I suppose the car is so popular that # days they stay on the lot remains low - less than a month?
if you are willing to wait long enough you'll find cashback cruze incentives some day, but it might be a while... and in the meantime there is lots of driving to do!
The Sandman
With the popularity of the Cruze it may be that you will be able to get a loaded Verano for just a bit more than a loaded Cruze if the Verano stays under the radar so to speak. I think it's a very good looking and optioned car. Unless you drive a lot of miles the difference in MPG wouldn't be that great per year.
Plus you get a 4yr bumper to bumper with the Buick. I've also found Buick service to be a much better experience in my area than Chevy but that may just be local.
Also, I've checked lots[in person] for 50-75mi.
Even in small towns, they have 4-5 and the larger cities have a row in the front, side and one in the back.
One dealer had 17 units in stock !
The so-called incentives listing is pitiful.
1 .USAA says as a son of a veteran I'm eligible, then say No.
link title
2. College Discounts don't apply to the "12 Cruze link title
3. Credit Union info is sketchy, salesman says it's valid, but he's talking, so he's Ly*** link title
4. As a GM Supplier Employee, "GM" says I'm eligible, but the HR says no go
link title
GM "Loyalty" discounts for the Cruze seem to be regional, in the NW and now have expired there.
I'm gonna hold my money till things ease up, or buy some junk from some other company.
I have a nasty e-mail word .doc telling the dealerships all about how I feel regarding the treatment of customers relating to their "appearance" [using a kind phrase if you will]
and have held off firing it just yet.
I was ready to drop the funds, but I freaking REFUSE to pay MSRP after TTT
DrVette
Not to mention how aggravated some will get using 6 gears over and over and over and over for up to 100k-200k miles, in traffic!
I've driven stick shift's since 1966, still have one I use[S-10] and love a stick.
Dunno how I'd feel about a 6-grinder after a couple hundred thousand shifts.
I wonder about the life of the synchronizer rings in those trannys too.
A call to inform him of the bad news about the pending Cruze purchase got some interesting commentary..
I told him of my investigation of the models offered by his dealership [Japanese imports] and how I was not really impressed with them, even with tremendous savings offered..
His comment was a muted "Chevrolet makes a good product"
This told me that the imports, though Japanese, do not hold up as well as Chevy's in the long haul..
His position is pretty high up, a manager, and can get me tremendous markdowns on the Rice Burners, he did NOT make any attempt to encourage me to purchase one, instead complementing the Cruze.
Odd, yet truthful, in my opinion, now to get the Chevy dealers to discount the Cruze.
Edit to add:
Note to potential buyers of Korean vehicles, they are pretty, but be aware, these are NOT the quality of American or Japanese vehicles.
100k 7yr bumper to bumper to warranty's do not cover everything, like rusted out gas tanks, bad calipers, etc..
Only sensors and parts to maintain EPA emissions are covered, as many here have found out the hard way. .
To me it means that the import dealers consider modern Chevys to be competitive. Not necessarily superior. Basically they recognize the threat to their marketshare. That's a huge step forward from the days of the Cavalier, but doesn't mean GM stuff is actually better.
As to the Korean vehicles, none that I know of come with a 100K/7yr bumper-to-bumper warranty. If you meant Hyundai, their warranty is explained in some detail at http://www.hyundaiusa.com/assurance/america-best-warranty.aspx.
If you compare the fine details of Hyundai, Chevy, Toyota, etc. you'll find little variation in what's covered. Rust, for instance, is rust through in body panels and not structural components (which, as a potential safety issue would generally be covered via recall). Brakes other than sensors are considered wear items & are not generally covered under anyone's warranty beyond a brief break-in period that allows for defective parts to be fixed.
It truly is a "World" class car,. I researched the car for months and even gave a presentation at a Chevy dealer on the airo and mechanical package they have. I am super critical of design and performance with economy in mind. Everything was in order tat I saw and was duely impressed with it. After driving these months, only 2 issues come to mind, neither quality problems.
First gear is way too low, you only get 1/2 thru an intersection and have to [non-permissible content removed] and the gas tank fill is terrible, always shuts off at 9 gallons and you have to play with it another 10 minutes to get the stated used fuel amount off the DIC. I have yet to completely fill the tank to check the accuracy of the calculated value. Otherwise the car has been flawless. There is no way I would have spent that type of money for a car that I did not trust or did not have a good reputation already, remember sold off shore for some time before coming to the us. Many miles in testing and developement. I would put my Cruze up against any manufacturer as to quality, design and economy. I was impressed with the mileage and intended a 50mpg target for most of my trips, rural area, highway and it has done that so far and I drive 60 mph when I can. Most of the complaints I see are individuals who would nitpick anything they can, unrealistic expectation, no real problems that I have seen yet.
I think the question has been answered, if you l the way it looks and drives buy the car and don't worry about past designs, this in NOT a Cavalier or Cobalt!!!!!
This is really off topic for a discussion focused on the Cruze. But since you brought it up... what is the factual basis for your assertion? And have you owned any Korean cars, especially within the last 10 years or so, to allow you to make a good comparison of the quality of Korean vehicles compared to American and Japanese vehicles?
If your opinion is based on the Chevy Aveo, a 10-year old design that was designed for one purpose, low price, that is not a good basis for a general comparison on relative quality.
I am familiar with the Sonata subframe rust issue, but that was fixed free of charge. There was also a front strut assembly rust issue on the Elantra which was fixed free as part of a recall campaign.
So yes, I freely admit that Hyundai has had probably more than their fair share of rust issues since 2000, but the ones I have heard of have been handled free of charge.
In an attempt to make this about the Cruze, when my wife was looking for a car to replace the '01 Elantra, the Cruze was on her short list. We liked how quiet it was. Power from the 1.4T was good. Ride was overly firm, though, and sitting in the passenger seat I couldn't get comfortable due to the position of the door arm rest. It was too high to comfortably rest my arm. The Cruze wound up as her second choice due to a few factors, which I've detailed elsewhere in the forums.
The Sandman
Your posting was quite informative and compelling given your experience and occupation.
Eveyone needs to know the Cruze with the 1.4L Turbo engine does NOT have a timing belt that may break and destroy a $3-4000.00 engine like so many others ..
Also the engine block is Cast Iron, this is for a reason.
The Turbo is rather inexpensive to replace, earlier forced induction systems like the Ford Turbo T-bird of some 20+ years ago cost about $2500.00
The Cruze turbo is a mere $650 RETAIL and 2.0 hrs to R&R, btw it has a "core" charge so obviously it's an easy rebuild..
My attempt to purchase a Cruze has NOT been successful as of yet.
Dealership claims of "limited" availability yielded this:
www.cars.com
Your Search Returned the Following
1313 New 2012 Chevrolet Cruze models within 150 miles of your ZIP, 3016*
Quote" what is the factual basis for your assertion? And have you owned any Korean cars, especially within the last 10 years or so, to allow you to make a good comparison of the quality of Korean vehicles compared to American and Japanese vehicles? "
Personally, no I have not but have several friends who own Mom & Pop repair shops and one pal with a 10~yr old Kia.
From my wrench pals, the Koreans have yet to match the Americans much less the Japanese in overall mechanical quality.
My pal who bought a Kia with a 100k "Bumper to Bumper" 7 yr warranty, well this may have been offered by the dealership in Atlanta, however it was NOT honored as it was explained to him.
[*note* read the fine print]
A stab at Japanese cars, while generally durable, WHEN they DO break, the parts costs are usually 2-4x more than similar American parts.
To be fair, compare parts for a Benz or BMW,, OUCH, the words Break My Wallet [BMW] are now painfully clear.
On the BBC show, Top Gear, the coil pack went out on a 12cyl Benz 2-door coupe, I forget the exact price but it seems like some 1200q or $1800~
I hope no one thinks I have issues with ANY country !
I'd buy a Chinese or Russian vehicle, given the right circumstances.
The One and Only issue I have with the Koreans is their treatment of canines. I do NOT object to the eating of dogs, I do however have a problem with the torture prior to slaughter.
For centuries the method has been to induce torture to the animal, this causes large amounts of Adrenaline to be produced, which makes the meat more appealing to a certain culture group in Korea.
www.thepetitionsite.com › Animal Abuse › Farm Animals › Pets
You will find several websites that claim this to be an urban myth, much like you will find many sites claiming the dispersant used in the Gulf of Mexico to be as harmless as dish-washing liquid.
Quote
"Nothing above was indicated to be in the past. You're the one that said "if I drive" which indicates to me present tense"
Sorry, you are correct, my continued and constant desecration of the English language continues to confuse those poor folks who attempt to decypher..
My apologies.
It was not a manufacturer warranty. Kia has never offered a 7-year bumper to bumper warranty. I don't think much of warranties backed only by a dealer. I don't see what a dealer-offered warranty has to do with the subject of relative vehicle quality.
I also don't see how Korean dietary preferences have ANYTHING to do with a discussion of relative vehicle quality.
I think you have made it clear that you have an issue with at least one country... which might be coloring your opinion of their cars?
I've owned or leased over 20 vehicles--American, Japanese, and Korean--including 3 Korean vehicles over the past 11 years. I'd put those Korean cars up against anything from America or Japan in the same price class over that time. And the quality has improved markedly in the past 10 years... really no comparison from what is available now vs. 10 years ago, or even 5 years ago.
Back to the Cruze... there's many things I like about it, including its quietness, well-trimmed interior, and great FE with the Eco. But I've decided to take it off my top-tier list for my next car after driving it in two one-week rentals recently. First, I found the steering more disconnected than I'd like. (These were LTs, btw.) Second, the rear seat is cramped for the size of the car--really no more usable leg room than in some smaller cars. Third, to get the Eco that I'd prefer will run around $19k. And I think there's some very good alternatives I like better for less money. If the Eco 6MT comes down in price before I am ready to buy, I might re-consider, but it would have to beat out the likes of the Mazda3 Skyactiv, Focus SE, Impreza, Elantra GLS, and Accent SE. And all of those but the Elantra are available as a hatch, which I prefer--another strike on the Cruze for me.
The Sandman
----------------------- 2009 2.3 liter ---- 2012 2.0 SkyActiv -----
- HorsePower: ---- 156 @ 6,500 ------- 155 @ 6,000
- Torque LBFT: ---- 150 @ 4,500 ------- 148 @ 4,100
Given that the output numbers are almost a statistical dead-heat, and given that the SkyActiv motor produces its peak numbers at lower RPMs, my bet is that, all else being equal (which it rarely is), the 2.0 liter SkyActiv motor would actually "feel" faster.
As a point of comparison, even though the Chevy Cruze "only" puts out 138 horsepower, by virtue of its forced induction it twists out some 148 LBFT of torque at an extremely low 1,850 RPMs, and as such, even though it has by far the smallest displacement of the group, it might could well "feel" the quickest (once again, all else being equal).
Given that I didn't get a chance to drive either the Cruze ECO 6-Speed or the Mazda3 SkyActiv 6-Speed, I can only speculate on the above.
The Sandman
