Check Engine Light
I have a Ram 1500 and the check engine light is on. Changed the plugs but the light is still on with a code missfire on different cylinders. Any suggestions?
Corkscrew
The last time I drove it (last night) I hit nothing, heard nothing and smelled nothing sinister. I'm not sure how to go about checking engine codes on it. Last week the regular maintanence on the overhead console registered it's time for an oil change, etc. I hope I haven't left anything useful out, with the exception that I'm flat out broke and don't want to take it in and get the run around. If someone could help me sound less ignorant when I make some calls to mechanics I'd appreciate your help.
Thank you for your time. :sick:
Corkscrew
Vickie :confuse:
Corkscrew
the vacuum is faulty . Go to auto parts store buy a coil of tubing one by one replace a colored dot by marker on each one you replace be generous on the size of the tube
the longer the tube the better the seal. When the rubber gets old it leaks this causes
a long list of engine problems.
Sorry to hear you are having a concern with your Dodge truck.
You may want to consider having the vehicle diagnosed by your local authorized Dodge Service Department or a trusted mechanic since there are so many different systems that can cause the check engine light to come on.
Lisa
Customer Care
Chrysler Group LLC
