When I called my Mazda dealer yesterday they said that I was the first person to report such a problem. AM I??? I did check the brake fluid level. It is well above the MIN level, not quite on the MAX level, but close.
Does anyone have an idea as to what may be causing this problem?
I took it to my trusted mechanic and got a four wheel brake job and asked if the rotors could be turned (I knew something was amiss since I was getting that telltale pulsing when I braked). My mechanic took a look and said the problem was that the rotors were pitted and he suggested I drive the car more. Too much sitting caused the corrosion and pitting, especially in my climate and the amount of salt they use on the roads.
I've been trying to drive it more but it's mostly used in the winter because the van is more comfy. If I didn't live in the UP, I'd just sell it, but the van doesn't do good trying to get up to the ski hills.
