Where is the fuse for the cigarette lighter in a 2002 Protege5?
                    I blew the fuse in my wife's 2002 Protege5 that feeds the cigarette lighter.  I cannot find a blown fuse and I cannot find out which fuse it is in the Owner's Manual.  Can someone help me and make the whining go away?
There is an alternate problem with the wiring in the cigarette lighter where the wire melts and breaks. If you pull out the cigarette lighter assembly you will see a place where one wire splits into two. Find the damage point and replace the wire with a thicker one.
Good Luck
