Aftermarket keyless entry
I just bought a 2001 Honda Accord LX. It's a fantastic car! It came from the car lot with a "Valet" branded keyless entry remote. One of the two it came with works perfectly fine. The second one however, doesn't. The green LED on it doesn't light up unless you press "AUX" unlike the remote that works, where any button press lights up the green LED. Here's a picture of what the remote looks like. http://bit.ly/amMsrF I've tried, but I don't think it has a remote start system. How do I program the additional remote?
Thanks guys!
Thanks guys!
Here is the manufacturers remote store for that brand of system: Directed Electronics Store
Manufacturers site: Directed Electronics
For example, check page 2 of this manual remote manual.
Reason I suggest the remote is bad, is that if there is no transmit light on it for the buttons needed, it is not sending a signal - therefore you will not be able to program it to the cars system.
EDIT: I just gotta find out where the "Valet/program" button is... I can't find it. =( The used car dealership knows nothing about the car since they just got it in when I bought it. :mad:
Frequently its stashed in the area of the lip at the bottom of the drivers side dash plastic. Though it could be located in any out of the way, but accessible to the driver place, in a cubby or the center armrest storage area, etc. Best way to find it is to kneel next to the car and inspect the lower dash area, under the drivers seat, etc. For my system the valet was installed above the hood release on the drivers kick panel, and the main system module was cable tied to the steering column under the dash, out of sight unless you crawled on your back up into the pedal area. Don't forget to look under the interior fuse box lid on the drivers side of some years.
Sounds like the used car dealership isn't interested. I would think any Honda new car dealer would have staff familiar with dealer installed options - and they would know the typical spots to check.
I dislike these aftermarket products, and decided after the automate that I would only by factory brand systems. That way they integrate better. Its much harder to tun on the factory alarm while driving, unlike the automate that you could arm regardless.
A web search turns up some options, such as
http://www.safetyairbags.com/
or you can find your local salvage yard and check on them. Most are part of a network these days and can locate parts if they don't have them.
