Oil pressure sensor
in Pontiac
I have a 97 Bonneville SE
I replaced the 3800 and the oil pressure gauge stays pegged till you shut off car. I figure it needs new sending unit but do not know where it is, can anyone help with this issue?
Probably taking off the right front wheel, then popping off the plastic splash guard exposing the side of the motor is the best access. This is the same as you would use to get to the motor mount spacer to remove it to replace the serpentine belt.
