Manual transmission/transaxle
                                  in Ford
                    Has the Windstar ever been offered with a manual transmission (transaxle)?  Does anyone know if one can be fitted from a different Ford vehicle?
I'm sure anything is possible, if you are willing to spend enough money. I doubt it would be worth the cost, though. The same engines were used in trucks that, I assume, had manuals.
That may change now that VW has come out with a technique to make the combination less hazardous. The VW technique will automaticall uprev the engine if a downshift results in too much engine compression braking for conditions.
Manual transaxle in a FWD "soccer mom" minivan...no way.
We did have a manual transmission in our first minivan, a 1989 Voyager. But in those days the manual gave you 5 gears, instead of the 3 in most automatics and it gave you significantly better mpg.
When we got our 2nd minivan, 1997 Windstar, automatic was the only option but at least it was a 4 speed auto by then.
The two engines used in the Windstar were the 3.0L Vulcan V6 and 3.8L Essex V6.
The 3.0L Vulcan was used in '86-'07 Taurus but only with an automatic. The only front-wheel-drive application of this engine with a manual transmission was the '90-'92 Probe LX and '92-'94 Tempo/Topaz. The Tempo/Topaz used a slightly revised version of the 'MTX-IV' used in the '89-'91 Taurus SHO. It was designed and built by Mazda for Ford.
The 3.8L Essex V6 was used in everything from the Taurus and Mustang to the Lincoln Continental and Thunderbird/Cougar. The rear-wheel-drive Mustang was the only one that offered a manual transmission with the 3.8L. It was never paired with a manual transmission in a front-wheel-drive vehicle.
So, in theory, a Windstar with the Vulcan V6 could be modified to work with the MTX-IV. The Essex V6 has never been paired with a manual in a front-wheel-drive, so it's unlikely that it could be done without spending ridiculous amounts of time and money.
With all that said, a manual-transmission conversion is rarely (if ever) financially worthwhile. In an older minivan, it makes no sense at all...
ty for your help
Can anyone help technicaly and commercialy
