2000 Saturn SL2
My son has a 2000 Saturn SL2. The service engine soon light came on, the speedometer quit working & the car jumped when putting it in drive. When driving it shifted hard. I took it to a mechanic & was told the speed sensor had gone out. I had it replaced & less than 2 weeks later it happened again. I took it back & they reset it & said a bunch of transmission codes popped up but they weren't sure what was wrong. Well, 2 days after resetting it, the check engine light is back on & it's driving weird as my son says...he said the speedometer is still working & it didn't jump when shifting into drive but it just didn't feel right. He wasn't able to describe the problem other than it feels like the transmission isn't right. I drove it last night & all was fine. What sort of transmission problem causes this & is there something that can be repaired to hopefully avoid having to replace the transmission?
When you press the gas pedal all the way to the floor you shut down the injectors giving the motor a chance to clear itself out of excess fuel and then the vehicle starts.
In the am the car needs a little more fuel for a cold start but when its warm it needs a lot less fuel.
Check with Saturn or Chevy to see if there is a Tech service bulletin on that specific problem
