Is this a good price for an 01 Forester
Looking at an 01 Forester L AWD Auto with 118k on it. Body is near perfect and it runs perfect. Is $4900 a good price to pay? The Edmunds numbers seem to show it is but wanted some opinions.
Check the maintenance records, and drive it in a tight figure 8 to make sure all the diffs and AWD are working properly. Turn off the radio, open the windows, and listen carefully for odd noises.
Check the engine for oil stains - front main seal, rear main seal, and head and valve cover gaskets.
Timing Belt w/Tensioner, idler pulleys
120k service which for a non-turbo forester would be:
Front and rear diffy fluid changes, Oil Change, ATF Change w/filter, Coolant Change, Brake Fluid Flush, spark plugs changed
Here is what we charge for such services, if they haven't been done, you could use these prices to try to bring the price down by that much.
http://azpinstalls.com/index.php?option=com_content&view=article&id=89&Itemid=12- 2
The 90k is the same as the 120k service.
-mike
Subaru Guru and Track Instructor
