Acura MDX 2010-2011 Battery Warning Problem
I was thinking about getting an MDX when I came upon this thread, which suggests a significant, recurring problem with the battery warning system in the 2010 and later model MDX:
http://www.mdxers.org/forums/74-2007-newer-mdx/39239-check-battery-sensor-mdx-20- 10-a.html
When I called Acura, I was not convinced that they had a fix for the problem that would work.
Is anyone not experiencing this gremlin? Any bad experiences to share? Would you buy the car knowing about the problem?
just annoying.
Last weekend I drove about 70 miles out of town. The warning indicator was on the entire trip down. Went off on the trip back. But the warning came back on Monday. It's still on despite just driving it for 40 minutes.
I've never had trouble starting the vehicle. Just loss of confidence. Shouldn't have worry about driving 2011 MDX with less than 2000 miles out of town.
It will be interesting to see if Acura makes an effort to resolve the issue.
Obviously not the case.
It has the dreaded battery drain problem. About 6 months ago, he took it to the dealer for testing and they couldn't find anything which was draining the battery. The service guy just kinda mentioned that there was some talk that it might be the HFL, so we came home and did more research on the web. We disconnected the HFL and took it out of the car completely. Inconvenient, yes but not as much as a dead battery. Things didn't improve much - there were sporadic problems and after more research on the web we disconnected the trunk light in the middle of May 2013. We thought the problem was solved - no more dead batteries. BUT:
Today the battery is dead again. The car was just driven 3 days ago. Now what? We have this practically new car that we're slowly dismantling trying to solve this problem. Any suggestions? We really, really don't want to trade in this beautiful, almost-new car, and if we do, we probably won't ever buy another Acura because of this issue.
Dealer was patient as was I and they solved it.Each time I was given a loaner and Acura extended warranty covered all at 51K miles.
Needless to say my faith was very shaky but it works now
We have a 2010 Acura MDX with Nav. The battery has died on us at least 3 times. Battery dies without warning. Dealer says there is nothing wrong. Battery is fine. We even had remote car starter checked. We took it elsewhere and they said there is something with the lift gate drawing power, and replaced something there. But low battery warning came on again. low battery warning has been turning on frequently. They have said nothing is wrong in the past. Something is going on, but Acura/honda won't own up to it. ( interestingly, the battery on my infiniti ex2008 died once in 5 yrs.
