1998 Toyota Camry valve cover replacement
My mechanic recommends to replace the valve cover on my '98 6 cyl Camry due to leaking from the rear cover. I got a couple cost estimates which range from $550 - $625.
After doing some online research, I learned that some also advise to replace the Spark Plug Cover Seals at the same time. Please let me know if this is a good approach, since it was not mentioned when the initial recommendation was made to replace the valve cover only.
About a year after my engine started to overheat, from a failing water pump, I noticed a oil leak. My mechanics did about $650 of work replacing bypass seals, gaskets, crank seals, oil pump seals, and a cam s seal. While they were at it the timing belt was replaced because it had to be removed for the work. Later the oil continued to drip. So I used a oil stop leak from the lube techs when they changed my oil, it worked for a year, then I had the toyota dealership do a tune up and they replaced a valve cover gasket, about $150. I think my car still leaks oil. Grrrrr!!! CBs or come backs, are what the mechanics would call it.
