Clunking from front end
jpal2626jpal2626 Member Posts: 2
I know this was a discussion already but i couldnt really get a solid answer. I have an 02 lse and everytime i hit even the smallest bump or pot whole it sounds like somebody is banging on the front end. Any suggestions on what it is would be great.....
  • badkwbadkw Member Posts: 3
    I've had sounds like the associated with inner and outer tie rods, and most commonly with upper ball joint (control arm). All are rather simple to diagnose.
  • cdnpinheadcdnpinhead Member Posts: 5,642
    the most common cause for front-end clunking of 2004 and earlier LSs is sway bar bushing wear. A long time ago the bushings could be replaced, but now it's necessary to replace the whole bar, which now has molded-on bushings. It's a much bigger job, but is supposed to be a lasting fix.
    Other suspension parts are possible, but not so likely.
  • larryk0202larryk0202 Member Posts: 3
    I've had that before, my problem was the "sway" bar. Pretty inexpensive, or could be the tie rods.
  • sailorlen10sailorlen10 Member Posts: 2
    Does any one know what size sway bar bushings this car takes? Front and rear the same size? Thanks!!
    Does any one know what size sway bar bushings my car takes?? Thanks!!
  • kargkarg Member Posts: 20
    The sway bar bushings - I don't believe are available by themselves for the 2004 or earlier - according to the other previous posts.
    I replaced my entire sway bar and it was indeed a job to do - fishing that darn thing through the front end and past all of the parts. I ended up have to unbolt the suspension from one side to get it to pass semi-easily.
    Anyway- I know that the "Sport model" had a different sway bar for the 2000 model - not sure of 2004. My guess is that you'd have to know that, as well.
    Bottom line - I don't believe they sell just the bushings.
  • toomanyfumestoomanyfumes Member Posts: 1,019
    Yeah I've heard you have to replace the whole sway bar. I don't think the sway bar is much of an issue on the 2nd gen (2003-up) LS's, I'd make sure that was the problem before replacing it.
    2012 Mustang Premium, 2013 Lincoln MKX Elite, 2007 Mitsubishi Outlander.
