1999 Chevy Venture Driver Information Center Repair
1999 Chevy Venture Driver Information Center Repair.
I researched and finally found a fix for non functioning Driver Information Center.
The solution was similar to that found for similar modules on other brands of vehicles.
Remove the Driver Information Center Module
(See GM manual for procedure)
Push back clips from black housing box and carefully remove circuit board
Place circuit card flat on table.
Place display and component side of circuit board facing up
Rotate circuit board so the display module side is facing you
There are button switches on either side of the display module
Look at the right button switch.
Next to it just left and above are four 1/4" X 1/8" black components attached to the circuit board
They are marked 430, 430, 820 and 820 reading from top to bottom.
These are resistors with 43 and 82 ohm values.
On the two modules I have repaired the problem was with the top most resistor. It is marked 430 and is 1/2" above and 1/4" to the left of the right button switch. The soldering to the circuit board had fractured. I resoldered the resistor into place using a bit of solder and 15 Watt pencil soldering iron.
All fixed.
The problem is NOT the black spot on the display in the upper left corner
The problem is NOT the DC to DC converter modules.
Why does it come loose?
I believe the resistor was part of the circuit which supplied power to the display module plates.
The resistor came loose due to the metallurgy of solder. The solder often is a mixture of tin and lead. The tin is more strongly attracted to the copper in the circuit board than the lead is attracted. When hot, when within 10% of melting temperature (resistors designed to run hot), the tin near the circuit board face will move. Having moved there is stress in the solder at the locations where it left. These holes create high stress in the solder structure, this leads to a fracture staight across the mounting face of the resistor as smooth and complete as if a knife cut the resistor loose. This only happens in designs which allow parts to heat to values close to the melting point of the solder. This rarely would happen in the past before surface mounted components. The cure would be higher temperature solder, cooler running parts, avoiding flat straight mounting interfaces, etc. Reheating the joint sets it right for a while.
Key words:
Chevy Venture 1999
DIC
VA344314KMD
VFD Vacuum Fluorescent Display
Futuba VA3527 2-BT-225GN
All fixed.
Key words:
Chevy Venture 1999
DIC
VA344314KMD
Maurice
My driver information Center was not working for the last 1 year. Since it was working sometime for couple of minutes, I was kind for sure that it could be some kind of dry solder or loose connection,Since I was not sure about that , I didn't do anything until today.
Thank you again for the detailed instruction about how fix this issue.
now just be careful watching the inst mpg readout. Keep you eyes on the road.
btw
after putting on goodyear fuel max tires and putting them at 42psi, I got 32mpg at 50mph, 28 mpg at 62 mph.
anyone do better?
Thank you so much for the information!
I enjoyed driving with the center functioning.
Glad it worked for you.
Regards
fltcoils; I know this is an old post; but, THANK YOU. Mine is a 99 Blazer LS. As you said, one of the 430s lifted easily. I did a slight lift check on the others. The other 430 popped loose at opposite end. My 30 watt with its big tip made it a challenge but I managed. Thanks to you, I am a hero; at least for today.
Thanks again
Knut Smilden
