GMC Yukon 2007 KeyFob Issue
rsmitty0151
Member Posts: 1
I have a 2007 yukon and the factory key fob(s) quit working full time. They will only work if you open the door with a key first, and then after about 20 seconds they will stop working. I tried the most obvious thing, so I changed the batteries twice yesterday on both remotes...no luck. Reprogrammed the fob , same thing still. Any ideas on how to fix my dilemia. It's driving me crazy.
Your only solution is going to the dealer and have reprogram your keyless entry modulo...I had a problem like it with mine XL'07 Denali(actually has 214 K miles) and I was charge $128 for reprogram the modulo(and if you like your remote starter and unlock and lock your car in the middle of winter)is well worth it.
Please keep us posted when the issue has been taken care of.
Thank you,
Caron, GM Customer Service
