Electrical Smell precedes Fuel Gauge Failure: Is it safe to drive?
reinsteinreinstein Member Posts: 11
Please help.
While driving my 2002 I35 there was a brief smell like electrical insulation burning. Shortly afterwards I noted that my fuel gauge was stuck on zero.
I spoke to my mechanic who told me it is unsafe to drive and a fire hazard because it might be the fuel sender wiring.
The Infiniti dealer says it will cost minimum of $250 to investigate and if it is a wiring issue it could cost as much as $3000 to repair.
Please advise.
I have no problem driving without a working fuel gauge ... but is it really a fire hazard? Can the repair really be that expensive?
Thank you for your help.
Larry
    You might have more luck in our answers section. Try starting here:
    http://answers.edmunds.com
    MODERATOR /ADMINISTRATOR
    Review your vehicle
  • atma97atma97 Member Posts: 47
    Definitely it needs to be fixed but not with the dealership since they tend to charge much more than a regular shop. Try to find a trusted mechanic with good experience in Japanese car or bring it to a NAPA repair center to get second opinion and estimation.
  • gr8rappergr8rapper Member Posts: 1
    Hi Reinstein,
    Have you found the solution to your problem of burning smell in I35. I have a 2002 I35 and get the same burning smell, it will be really helpful if you could tell me how you dealt with it..
    Vinod.
