2005 Dodge Dakota 4wd engages by itself
My 2005 dodge dakata 4wd, with the ignition switch off, I can sometimes walk by and hear my 4wd trying to engage. it trys to engage, then stops, and repeats it's self. I took the 25 amp fuse out for now, until the problem can be resolve. Any Ideas?
NV244HD transfer case, both are electronically shifted by the TCCM (Transfer Case Control Module)...so you may have a selector switch (dash) or mode sensor issue, that needs replacing on the encoder motor in the transfer case.
Read this article for a better description on how it works:
http://www.rsgear.com/articles/2008_04.pdf
From your description, there has to be an anomaly where the power available
to the transfer case is controlling the electric motor that engages the
4WD unit. Something is obvious not in a proper state (engage/disengage)
and if that is the case..the PCM which is still energized even with the
ignition switch off, can be receiving a incorrect signal and trying to set
the correct state for the Transfer case..it can't accomplish that it
starts to "Hunt" between states and the encoder/sensor is not telling
it which state it's supposed to be in. In the electronics industry..that
is referred to as "fuzzy logic"
1. On (engaged)
2. OFF (disengaged)
3. "Maybe" ( try to assume the correct state, or keep trying until correct state is reached)
The "black box " that you are calling the "ECM" is in actuality the
PDC (power distribution center) located on the driver's side fender.
It has most of the fuses and relays used to control engine, fuel pump and
transmission /lighting, horn relay etc. The +side of the battery and the
alternator charging o/p meet there. so does the -side of the battery,
the frame ground and the engine (ground strap) ground.
Pretty much all of the power and ground distribution is sourced from the PDC.
in (or what the 4WD encoder in the unit thinks it's in) nothing happens until
you put the +12 volt fuse back in which starts the process all over again.
If the 4WD fail indicator is coming on...the PCM is posting a P-xxxx code
and you need an ODBII code reader to read the code. If you don't
own one (and I highly recommend with computerized vehicle controls that
you get an inexpensive one ($60 or so), you will need to take it to
an Auto Zone or some such place that will pull the code from the computer
and you will (hopefully have a better indication where the problem lies).
Without doing that..you are just guessing.
Any additional information would be greatly appreciated as I took it to the dealership today and they can't get the problem to occur, therefore they are unable to diagnose and repair the issue.
The 4x4 system can enguage on it's own, if the 5 volts to the transfer case shift motor gets shorted. The a/c pressure sensor can short out and cause this to happen. Since your problem is intermittent, just unplug the a/c pressure sensor (located in the high side line, next to the coolant over flow jug) and see if problem goes away. If so replace a/c pressure sensor. If not further testing will be needed. Hope this helps.
After reading this thread, I think it is the cause of my short, and it is now happening to my fuel system and not just my 4wd. I wondered if hearing the 4wd engage and disengage would hurt anything else. Guess I'll start looking outside my transfer case for lose it cut wires. Hopefully I don't have to open it.
