As a result of the jerking my right speaker busted and now the air conditioner comes on when I don't have the A/C button pressed one nor the 'auto' button engaged. I'm taking it back again to get the electrical looked at and the right speaker fix.
I like my car but I'm disappointed because I haven't had the opportunity to enjoy it.
Oh, I also completed a survey on the car and I said at this time I wouldn't recommend the 2013 Altima to anyone until these problems are fixed.
How many miles do you have on your Altima.
"the driver may experience difficulty in controlling the direction of the vehicle"
http://articles.nydailynews.com/2012-10-22/news/34660120_1_altima-sedans-altima-- owners-canton-plant
Problem after problem with this 2013 Altima and the year 2013 has not even started yet.
The other problem I have had is that when receiving a phone call the car won't let you pick up the call and it just keeps ringing. The first time this happened I had to manually delete the car phone from my iPhone. The next time I had to stop and turn off my car.
Any help is greatly appreciated.
Was getting 40+ MGP highway. However, I took it in for the transmission recall servicing when
I got a recall notice in the mail and now my highway MPG has dropped to 32+ which is rather
dramatic.
Anyone else experience this issue or have suggestions on what to do about it ? I'll be taking it
in for the 3 month service next week. Thanks.
cushion at the back of the seat or add an after-market lumbar support unit you
can get for under $10 and the problem is usually solved.
I recommend anyone reading this to record their mileage with pictures of the trip reading before and after filling up with each tank of gas, as well as saving the gas receipts to match the trip reading after filling up.
An answer came back which I didn't quite understand(have an SL 3.5 with Tech)
"While the fuel economy is displayed just hold the same button in for a few seconds and it will reset. "
Does anyone know how to do this with a 3.5 SL / Tech ?
Hal
I echo other postings. Drove exclusively on the highway at 75-80 mph on a recent trip between Ottawa, Ontario, Canada and Boston, Mass. Average about 31 mph with a fully warm engine.
At winter temps (25-30F, -5C) and all short city trips with engine almost never fully warmed up: 19-20 mpg.
These are number somewhat worse than our previous 2.5 VW Golf/Rabbit. While not horrible, it's hardly the mpg champion that I read about.
Other Issues:
The seats are BELOW PAR in comfort. The Zero Gravity is all BS.
Seat warmer heats the bum on high and just the back on low. So, you can have a hot bum and cold back or a warm back and a cold bum. Weird.
GPS is amazingly slow. Sometimes I can drive for several minutes before it finds its way.
Low beam performance is weak; not enough distance. High beam is OK.
It has one of the most unpleasant engine noise (I've owned over 30 cars) of any car I've driven. Nothing to do with the CVT drone. Just unpleasant sound.
The rear camera got coated with road salt and dirt easily. I've read about a built-in washer. If it's there, it doesn't work.
Steering is numb. Drove through some slush last few weeks and had to drive by sight only because I can't feel what the front tires are doing.
Can't program the navigation while moving. Seems to be a safety feature but it means the passenger can't program it either. DUMB.
Some good points:
Quiet cruising. Just don't push it to invoke the engine noise.
Roomy front and back.
Good size trunk, although with the all-to-common luggage crusher hinge.
Comfortable ride and pretty good handling. I have not experienced the swaying problem reported by some.
Quick acceleration for a 4 cyl.
Although there was a recall, reliable so far (only three months)
Nice abundant cabin storage with lids to keep things tidy looking.
Stereo has a USB input. Popped in a 16 GB USB drive filled with mp3 songs, and play for days. However, the random seems to reset every trip, so it's not truly random except one trip at a time.
Big fuel tank. So, although consumption is not impressive, we still refuel less often.
Convenient keyless entry and start. Keep the key in the pocket or purse and not have to fumble with it with winter gloves in and out of the pocket.
I will try that as soon as I get back to the car.
-Hold the menu button (on steering wheel) while looking at fuel consumption screen -
BTW I've set my display choices (you get to choose 4 from the list) to include
Tire Pressure (shows all 4 pressures), Compass, Fuel Consumption (instantaneous bar graph with average numeric) and I can't remember the fourth.
Around town I was getting about 26 in stop and go traffic. I made a couple of short trips (<100 miles each way) and was getting 38-40 MPG. I reset the MPG once I get on the freeway each way, which eliminated any driving in town. I was impressed.
Right after Christmas, I drove to Oklahoma City and could do no better than 33 MPG at any speed from 65 to 80 on basically flat Interstates. I'm not sure what is going on, but something has changed with the car. I did notice that the RPM was higher than I had seen it on previous trips at 75MPH, so that's when I started playing with the speed. It just seemed to me that the CVT was not in the proper "gear" for highway speeds. And in town it is now less than 20 MPG. And yes the OverDrive was on.
I'm tackling one problem at a time. Read on.
As for the navigation, mine started blanking out after about 300 miles into the trip to NEO and was once every 10-15 minutes or so. It continued to get worse and I took it to the dealer. They said they could not "fix" it unless they could "see" it blanking out. I guess their trained eyes would see the blank screen different than me. Maybe there is some hidden codes displayed that I can't see.
The 19th of December, I was heading out to do some shopping and the navigation screen was really going crazy. So I figured it would be a good time to go to the dealership. I stopped counting at 25 blanks after 2 miles of the 3 mile trip. When I got there the service manager got in the car and within a minute, it blanked out 5-6 times. Now his trained eyes saw the problem. They called Nissan and were told to order a new A/V unit.
I finally got the unit changed January 16th. I've only had it in about 150 miles so far and no blanking out. However, I did notice a few changes with the new head unit. BTW, the SD Card is the same one from my original unit as I made a very small mark on it.
1) The radio/XM now sounds like what I had originally expected to have. Before, the bass was kinda mushy and I had the volume at "5" for my desired level. Now, the bass will knock your socks off and the highs are crisp and clean. I now can go no higher than "3" for my level. At "5", it will knock the doors off and I sound like a boom-box on steroids with wheels. This is a NEW XM radio, so make sure to cancel your old one before you get billed for it and also request a new 3-month trial on this one. I did and it worked.
2) The RearView camera has only one view now and it's a bit wider than the old one, but not as wide as the alternate choice of view was. There are 2 sets of lines instead of just one. It may be me, but I think it's a bit brighter and maybe a slightly better resolution.
3) The navigation display is "different" somehow. I'm not sure exactly what, but it just seems to look different. Again, maybe it's just me. But, I do know that the tracking is very smooth and there are no lapses in updating side streets as I drive around town. No, I don't need it in town, but just watching it for any problems such as the blanking and crossing my fingers.
I found another forum a couple months back that has lots of complaints about the navigation problem. So it may be typical for this 1st generation of the "new Altima". I hate it when that happens.
Overall, the car is 5 years newer than my previous 2008 Toyota Camry Hybrid technology-wise. However, it has slightly more road, wind and engine noise than the TCH, not counting when the TCH was traveling under 40MPH on electric only, then you could sneak up on a sleeping cat. Initially the Altima had much, much better gas mileage than the TCH and I was very impressed, but now, it's not doing as well as the TCH. Something has changed.
Drove from Arlington Va to Fairfax Va on I-66 when traffic was moving Did some in town driving ( slightly heavy footed) then back on 66 to Arlington.
The avg going to Fairfax was 36.4. upon return home it was 34+.
Went as low as 31.6 after the heavy footed and in town stretches.
Going to work (in town, red lights stop signs etc) it's about 2 miles. For this kind of driving the car says I am getting 10-11 mpg.
The car is a 2013 SL 3.5 (V-6 engine)
I don't think her size would make a difference but she is about 5'9" and about 130lbs,i drove the car home about 50 miles and i thought the seat was pretty comfortable and i was impressed with the size of the cockpit even with a sun roof i can still set in it comfortedly and i am 6'9" tall and about 280lbs.Please let me know if you have gotten your seat fixed or replaced,i saw someting in a google search someone else had the same problem and nissian had a recall on the foam on the back part of the seat.
Too bad someone couldn't organize a purchase revolt until they make them less intrusive. The owners who have the most complaints are usually ones who have neck trouble (me) back trouble (me) lower back trouble (me) and anyone who drives with the seat back fairly upright.
It is a pretty big dilemma in my opinion. I felt more sure of this since chatting with others too who hate these new head restraints..even ones who do tilt seat back a lot.
I can't get over the drastic differences in MPG owners appear to be getting with the new 2013 Altima. When I read of slipping belt it somehow didn't surprise me, when I first read that the 4 cyl have a fibre type belt and the 6 cyl still use a steel belt. Although I didn't think it would slip so much as it might wear too fast. I guess the compounds they are using to fend off wear, are naturally harder so now slip issues appear.
I guess manufacturers will never stop using new owners as guinea pigs on our $'s. In fact, I believe it is worse in the past decade as cars have gotten disproportionately more technological. I am amazed at the degree of unfinished product is for sale to the general public, with a defensive stance that they are under wty so why the complaints? Well...DUH...they do not regard our time loss, frustration and stress levels in having to return to the stealership all the time and the whole time NOT having a new car to drive while it is there. And whatabout the gallons of gasoline used all on our dime while they test drive it over and over trying to replicate the issue. And then there is also the fear that we might have bought a lemon, or worse a lemon model. I have become very very skeptical of ANY new car or truck in the last few years even though I am in the market to replace (or add a used to) my present ride. If a new model makes claims that sound too good to be true, my caution flags already have started to whisp. Maybe being almost poor, is not as bad a thing as one might first think, because it means you can never be quick to pull the trigger on a buy of something that is supposed to be new and improved. If it truly is improved, it usually doesn't materialize that way until the 3rd or 4th year in production when they finally get all the bugs sorted out on our dime/dollar, and by then they are already getting ready to release their next guinea pig project on us..
I've learned but have been recently reminded by reading so many forums lately of newer models, that grass truly isn't always greener over yonder. That green you see is a mirage of your hard-earned bucks dancing across the field...in the opposite direction of your pocket..
I'm curious about your TCH...how many miles when you traded it? Was it a good car? i.e. did you have to invest much time/dollars dealing with issues? I'm sorta considering one or a used Prius to have as a second vehicle to my CRV. Am a little reserved in that I have a healthy cautious respect for the hybrid tech. But it seems they are almost too good to be true. Very few issues..would you agree?
The one thing that I could envision being a lot different (I haven't driven a hybrid yet) is braking dynamics which most certainly will affect the usual perceptive deceleration handling feel of the car.
The TCH had 47,000 miles, it was an excellent car with ZERO problems out of the showroom to trade in. Excellent performance from day one. I was really wanting a new 2013 TCH, but never could get one ordered. Toyota was not taking orders and I wanted to sell before it passed the 50,000 mile mark. I did save about $4,000 over the MSRP expected for the 2013 TCH with the Altima.
At this point, I would think that you need to look at MPG / cost and make the decision. I'm a "techie" person, so I just wanted one and loved every mile I drove my 2008, especially at Sonic when you parked, the engine shut off but the A/C or heat just kept on doing their thing with no engine running. Almost everything was electrically operated/powered including brakes and steering. Sweet ride.
Nissan has now acknowledged to one customer that this is a systemic problem in early production versions of the A/V unit. They are working on a software reload and therefore have stopped sending out new head units for swap to fix the Nav blanking. Good thing is they won't have to tear your dash out. So far, mine is not making any noises.
There is no date as to when the software will be available, but it looks like you may just have to wait for it now. :mad:
Yes, very cool..I could appreciate that. I do plan to drive one ( a hybrid).
One of my reasons to consider one though is reliability. It seems that Prius owners are thrilled in a number of ways, and you too are saying that your TCH was completely trouble free. I hope your new Altima will perform as well for you. If not, you will be wishing you had kept the TCH. I take it you did not consider the Altima Hybrid? Why the change in brands?
2013 TCH Hybrid was not available for order when I needed to get a new car.
So I got what was available as I was leaving on a trip within the week and didn't want to put more miles on TCH.
Mileage was still abt 33.5mpg overall as the roads were a bit up and down, but still Interstate at 75MPH round trip with RPM at ~1950. Reset the MPG once on freeway up and again coming back so in town did not count. There were a couple of times that it reached 36MPG (sticker estimate), but it didn't stay there very long.
Still have not taken the Interstate where I was getting 40mpg again yet, but will very soon.
1) Heated seats are wired incorrectly from the factory. There is no low setting. High heats only the cushion, while low heats only the back.
2) The passenger airbag light indicator says its off when an adult is sitting in the passenger seat. Obviously a serious issue.
3) The CVT transmission emits a rumble like the car is going to die out at about 1200-1500 rpm when accelerating lightly from a stop light.
4) Both of the front doors rub against the frame when opening and closing.
I have contacted the dealer and Nissan USA corporate affairs. As of now they are telling me that there is no fix for any of these issues. I would avoid purchasing the car until these are resolved.
Very dissapointing to say the least for a new car.
It is hard to believe this:
"I have contacted the dealer and Nissan USA corporate affairs. As of now they are telling me that there is no fix for any of these issues. "
Surely those are not the exact words they used?
1) is totally fixable
2) is totally fixable and should be immediately
3)
4) this sounds serious also...who knows why..maybe an unreported accident suring transport, or maybe the car hauler guy was having a bad day and winched down the poor car too tight by the transport hooks. This has always concerned me, because I have seen some vehicles really wound down tight. I believe this can strain everything, the unibody, all suspension components, springs, tires, wheels, wheel bearings...you name it. It can throw out factory specs for castor and camber, alignments and can cause poor tracking and a host of other issues.
Next time you see some car haulers in the dealership, just make a note of what I'm talking about..it may take a few before you spot one that has the poor car crunched down like a child's old wagon with a 200 lb'r sitting in it.
IMO, this should be a measurable component involved with destination, (especially when you consider the serious potential of hard to find and then address damage later) but have no idea how it could be done. The transport drivers have to give a damn for starters. Pretty sure that this mounting IS mechanized at the ship level, (computer controlled tensioning as per the specific vehicle being tied down) so this type of damage almost always is attributed to local delivery negligence. One thing I do is actually look at the tie-off hooks and at least see if they look like they or where they are spot welded to the unibody have been over-stressed. Its not much but better than nothing.
Within a week of purchase, I made a round trip to New Orleans from central Arkansas. I got 42/40 MPG at 75/80 MPH overall. For the round trip, I filled up just 4 times even though it was not really needed, but being a new car, I had not yet learned to trust the fuel gauge or remaining miles. Only once was I down to the fuel warning alert and that did spook me some.
When I got back and running around town, it was getting 35 MPG or greater with no regard to my "lead foot" or traffic.
After about 4000+ miles, the in town mileage is now ~18 MPG. When watching the RPM, and like the post above, keeping it below 1,500 RPM, I was able to gently approach 24 MPG.
Recently a trip (400 miles R/T) via interstate, cruise control on and speed of 75 MPH, I was able to do no better than 33 MPG overall.
Something is up with the Altima at ~4,000 miles. Although, my sticker says 27 MPG and 38 MPG, it's not there any more. Still, it's better than my previous car.
If you are a coaster (good MPG), the mileage will increase as you drive up to a point. If you are a lead-footer, it will decrease as you drive, again to a point.
While I was getting 42MPG on my trip and under cruise control, the miles left was dropping about 1 mile for every 5 to 8 miles I drove, which was somewhat unsettling, but nice to see. It started out showing 485 miles after a fill up after sucking empty. Then, after about 100 miles of Interstate driving with "great" indicated miles left, it began to drop about 2 miles for every 1 driven. After about another 100 miles, it was tracking pretty much 1 for 1 and probably displaying a realistic number from then on out. This happened about the half tank point.
Bottom line, I would not start across the desert with a half tank of gas indicated, even though the miles left was saying 300+. You will end up pushing or walking for sure. In other words, enjoy the high numbers shown, but don't take it to the bank.
The instantaneous MPG shown on the Driver Display is a bit more accurate as it's metering the gas past a point vs the speed. As you can see, it fluctuates a lot as you drive, thus the crazy reading on the miles left numbers. Overall, the Altima does get pretty good mileage for a mid-size family car. My older SUV gets 14MPG going downhill.
Well then you probably shouldn't have bought an Altima. The Combined EPA rating for the 2013 Altima 2.5 is 31. Camry, 26. That's a 5mpg difference. Granted, it's 5, not 4, but you should've anticipated a change of somewhere from 3-7mpg, based on driving style.
Is it safe to assume you're calculating mileage not based on the computer, but rather using the odometer and gallons pumped each time?
Especially interested in replacing the passenger seat.
I would think DTE would be automated, like it is in my car (a Sonata). It's dependent on driving style and fuel left in the tank. When I pump gas with the car "ON" but not running, you can actually watch the Range climb mile by mile until the tank is full.
