Cruise control
                    I have a '97 Caravan.  The cruise Control, horn and everything else that operates off of the steering shell do not work.  Does anyone have any idea as to the nature of the problem & whether or not it is worth fixing?  Thanks
C.B.
A few days ago, the cruise control was working fine.
A couple days ago, I would turn the Cruise on, the light came on fine, but I was having intermittent trouble setting the speed. When I was successful at setting the speed, a short time down the road, the cruise control would stop working (but the light for it stayed on). Sometimes, pressing resume got it going again, sometimes not.
Today, the Cruise light won't even come on. The horn works fine and the airbag light goes off after starting the vehicle.
What do I do and where do I start?
ive just checked out a blog containing very simpler explanation of cruise control check it out
electronic adaptive cruise control system explained | readerrack.com
I'm having the same cruise control issues with my 06 Caravan. Goes on, then off.
I see you posted about this in March.
Have you figured it out yet?
Good luck!
