Jeep Grand Cherokee Plus & Minus Sign on Shift
deboraddeborad Member Posts: 2
edited March 2017 in Jeep
I have a 2005 Grand Cherokee that did not come with an owner's manual. On the shift is a plus and minus sign and I have no clue what it's for, if anything. I've asked other Jeep owners but I'm the only one with a 2005. Does anyone know what it's for? Thanks in advance.
  • kyfdxkyfdx Moderator Posts: 270,010
    Can't see it from here (that's a joke), but the +/- is usually where you push your automatic shifter over, then shift manually.... One direction upshifts, the other direction downshifts... hence, the +/-
    Some call those transmissions, manumatics.... because even though they are automatics, you can shift through the gears manually...
  • md2005md2005 Member Posts: 1
    The gear shifter on my 05 grand cherokee laredo labeled + & - just stopped working. Nothing appears on the dash when you slide either way & it definitely isn't going into a lower gear. Any ideas?
  • KeesterKeester Member Posts: 1
    the silver + and - tabs on steering column on my 2016 grand cherokee Laredo. with no oweners manual yet I dont know how they work. ????? Keester
    Are they paddle shifters? Pull on one paddle and you manually shift the transmission up. Pull on the other paddle for down shifts.
