Infiniti G25X transmission problem
We are experiencing intermittent transmission problem with our six month old Infinity G25X. In stop and go traffic or slowing down, the car makes a noise of varying intensity that can startle the driver. The dealer diagnosed the problem as the transmission shifting to first gear improperly. Infinity has admitted they have no fix for it, but claims that the car is performing as designed. All the offered are a couple of free oil changes instead of fixing the problem. The car also hesitates when taking a sharp turn after stopping . Driving this so called upscale car has been an unpleasant and disappointing experience. Instead of its top rating. Has anyone else had such an experience? Consider you options before buying one.
I also have noted this issue with downshift from 2-1. This is most noticeable in "DS" and when braking hard from 30mph to stop. Car shifts hard into 1st almost like hitting a pothole. This is not a common symptom but has happened 4 to 5 times.
I am suffering more with Vibration. The vibration is much more noticeable. From 55mph and up.
Symptoms: I have a low frequency resonance through the car with vibration of rear view mirror. Very noticeable. Sounds like a helicopter overhead. Night driving is hard due to vibration of rear-view mirror. And 3hrs of this resonance is maddening... :mad:
With all the items above I finally had to have Inifiniti USA send an expert tech to my dealership look at the vehicle as the dealer does not know what to do and is washing their hands. Infiniti expert asked for rear differential to be replaced. More to come I will keep you informed as to progress... :confuse: :sick:
Did the differential resolve your problem? I really need to get this fixed and am interested in your outcome
