Downshifting on 2011 Legacy (manual)
Hi, I have been driving manual / stick shift for 40+ years and purchased a AWD 2011 legacy six months ago. There is currently 6500 miles on the clock.
Every so often I get a faint smell like burning breakpads / clutch. I initially thought it was just the fact it was a 'new car' and some coatings on the underside were being 'burned in' but now I think it could be the clutch. Anyone aware of issues with the clutch on 2011 Legacy?
This is my first AWD so maybe I should not be downshifting on an AWD and just put the wear on the breakpads?
By the way in those 40+ years of driving I never once burned out a clutch even when towing (not towing anything yet on the 2011).
Maybe they arn't making clutches like the used too? Last car was a Mitsubishi 3000 GT manual, sold it at 120k with origional clutch in it.
Thanks in advance for any replies.
I have a '09 WRX (5-speed manual), and when I'm trying to free myself from deep snow, I've noticed that smell. I also noticed it once when gently trying to climb a sidewalk curb.
What I think is happening is that the traction control may be intruding. The car applies the brake to the wheel with the least traction, or what it thinks has the least traction, and you get that foul smell. If you turn off the traction control (switch on lower left dash), that won't occur. At least it works in deep snow. Not sure about climbing curbs, as I haven't done that in a couple of years. Once you're free from the questionable traction condition, turn the traction control back on.
Bob
That said the traction control light has only ever come on once, not as frequent as I have noticed the burning smell.
I agree with Bob that the car is much more responsive to get moving in low traction situations when the VDC is turned off. Otherwise, you have the car trying to out-smart you, and you end up with both the low traction and car fighting your progress.
I'll pay more attention to my driving and traction conditions over the coming week, maybe try and avoid downshifting as well, but that will be hard as I have been doing it so long it happens subconsciouncisly.
Your timing is good today - you caught me checking posts!
In low friction environment center diff fluid (I think Subaru still uses viscous coupling in center diff) starts smelling too, at least in my experience.
Krzys
i am a new member and i would like to share my problem that i am have with my 2011 subaru outback. know i know that the outback and the legacy 2.5 have the same tranny clutch and gear box. and i was wondering if anyone has this same problem. when the car is cold and the weather is below -10 i have a problem from first to second gear and also from third to second. it is every hard and i have to apply lots of force. this getts better when the car is full warm and as been driving for about 45 minutes.
please let me know if anyone had this problem and how did you or the dealer fix it.
So far I haven't smelled anything but then again not traction problems either because the weather has been soo nice. Will drop back in a week or so with more update.
My previous manual car had similar, but not as noticable problem. I am living with it at the moment, I expect it will 'loosen up a bit' with more miles on the clock.
