2012 Honda Civic and Accord Battery Drain
See Also: How To Stop Car Battery Drains
MODERATOR /ADMINISTRATOR
Review your vehicle
I spoke to the service manager at the dealership and was told that this was common due to the cars electronics ... this doesn't seem possible or correct. They actually suggested using a trickle charger if I was not going to start/drive the car for a few days. Any ideas?
Go to a different one.
A car should be able to start after a month on being idle much less a few days.
Did he try to tell you WHICH electronics are using battery power when the vehicle is off? I'd be curious about that, because I can't imagine what those would be (and it would take more than one). Clock - but most of those have a separate battery. Radio, to hold the presets - but then again, most modern vehicles have a radio with pre-sets, and despite leaving some of our vehicles sitting for over a week, we've never experienced battery drain because of that.
It's more likely that some electronic IS draining your battery, but it shouldn't be. It's either a bad battery, or they need to figure out what circuit is using the battery, that should not be, when the vehicle is off.
Review your vehicle
It almost sounds like a bad battery and this is fairly common.
If a particular new model were sold with the expectation that you'd have a dead battery every time you returned from a few days of vacation, I doubt it would sell very well!
Review your vehicle
Cars would sometimes sit, buried on lor lot for months and they would usually start. The more equipment they had, the more likely the battery would be dead. Certainly not in a Civic.
Worried !
I was not able to make my appt with my dealership service last week but have an appt for mid-February to have an electrical diagnostics performed, and it better not cost me even a penny!
Good-luck and please keep us all posted on your experiences with your wife's Honda.
P.S. - Don't be worried...take action!
Please call Honda Corp Hdqtrs.
Of course we are unsure if the problem is fixed and we are trying our own experiment. We have not driven the car since monday and will only try it tomorrow night.
This will make it 4 days since being started. If it starts then maybe they were right. If not, this will be definite proof there is a big problem. I'll let you guys know tomorrow night what the result is.
My 2009 Accord had a rear brake defect that Honda wouldn't address until someone sued. That's what it takes with Honda apparently, they won't get off their [non-permissible content removed] until someone (group of people) take action.
I suggest doing the same here.
Just have them replace the battery and be done with it once and for all!
I have had the same problem as all of you with no results! Bought a brand new, fully loaded 2012 Honda Civic (Non-Hybrid) in January and every 2 months the battery goes dead for no reason. I have the car towed to the dealership, they put the computer on the battery and it says, "Replace battery". So, they replace the battery and send me on my way...every 2 months!
I've gone to a different dealership, had a thorough diagnostic done, called Honda Canada (who were equally uncaring and dismissive) and everyone tells me there is nothing wrong with the car and everything is great now, "it was just that battery".
I have now had 5 new batteries since January 2012 when I received my new car.
I can't leave town or go far from home after the 1 month of the new battery as I know my car can and will die anytime without notice.
Sadly, I owe so much on this car still I can't dump it anywhere and still have money to get a good car. Am fed up, beaten down by the issue and I know Honda is just waiting til the warranty runs out when they can stop replacing the battery and say too bad for you, you're on your own.
Honda is a nightmare that just doesn't end.
If anyone ever comes up with a reason this battery drain issue is happening, please let us know. Thanks and I appreciate this forum, helps slightly knowing I'm not alone (although I am very sorry you're all going through issue as well).
I've had my 2012 EX w/ Nav Civic for nearly 1 1/2 months (already had 9k on it/bought used) and it hasn't had the problem (knock on wood). But I've used it everyday and haven't had it sit for any length of time before being started up.
I see all the problems from each of you. Do we need to live with it? I bout new car to not be in trouble at list for about 5 years. where to go?
I'm VERY DISAPPOINTED to say the least!!
My 2011 hasn't been idle for more than a day, so I haven't had the problem, yet. But interested in the source of the problem.
Honda Civic Lease Questions
Review your vehicle
Review your vehicle
Maybe the culprit could be the security alarm, since it is standard on all 2012-13 Civics except the DX I believe.
The only problem I have is mice making the engine compartment their home... made the battery their bathroom...... my dam cats need to catch it before it starts chewing on the wires!!!!!!!
'06 Civic. Still think they should've reimbursed me the full cost of the tires and a/c repair but I took what they offered as something is always better than nothing!
The Sandman
Tomorrow, I will call the dealership as we are due for an oil change anyway. My guess is that they will pro-rate the battery and sell us another one, at some discount. This will not solve the problem, but I am not optimistic that they will hear out, and act on what I have read in this thread and others.
Unfortunately, the easiest way out for us is to sell the car, and buy a Toyota. I will contact Honda, though, and explain my concerns to them, if they will listen.
Good Luck to everybody with a Civic!
Hi from AB. I noticed since buying the civic, May 2012, my battery never seemed charged the car always starts but seems not right. Last week received a recall notice seems the computer system is not charging the systems properly and i have till dec 2014 to take care of it. So tonight i took my very reliable charger and hooked it up to the battery and sure enough it's only charged at 57%...now the battery is probably screwed from never being fully charged. You know whats funny...Had a 2005 dodge dually diesel one ton Brand New in 2005 had the same problem.
I have a 2012 Civic EX-L. I had a dead battery after driving 25 miles and parking for 15 minutes. This was during a 75 degree day, so the lights were never on! I got a jump and drove to the dealer, who found no electrical problem and claimed the battery checked out OK. The car has not failed to start since, however it turns over more slowly than normal after sitting overnight.
Hi smylee, did you get the charging problem fixed by the dealer? My wife's 2012 civic had the dead battery-charge-works-for-a-week-dead-charge, etc. My charger says the battery is good and it holds the charge. However, the alternator charges at 12.5 volts and not 13.6 volts as my miata does. What is the recall problem?
Hi there sorry for the delay in answering...the answer is NO the recall didn't fix anything as a matter of fact it's worse now than ever. After sitting in the heated parkade for 3 days over the last weekend, I started the car Mon afternoon but it didn't sound good. So I too called the dealershipo and they've never heard of such a problem. And I too called Honda Canada and was equally met with an uninterested person who really could've cared less.This is very frustrating! I have to say this Civic has been the worst piece of [non-permissible content removed] I've ever owned. I can see nothing but problems coming. STAY AWAY from Honda I will post again after Fri appointment
Honda for sure has made a bad batch of batteries........see the 2013 Accord/Civic posts for more up-to-date troubles
I FINALLY FIGURED IT OUT!!!
It's the ECO mode!!!!!! Make sure to TURN OFF your ECO mode BEFORE you turn off your car. It took me countless times and research to just simply figure it out on my own since it would only not start random times. Well those random times..my ECO mode was on! When you turn on the car whether it starts or not, notice that the FIRST notification that comes up on the screen is "ECO mode ON" or "ECO mode OFF" Make sure it is OFF before turning off your car or you will have to get a jump.
