Audi Q5 Maintenance and Repair
I have a 2010 Audi Q5. At about 82,000 kilometres the engine warning light came on. I had Dealer run a diagnostic and they told me that carbon is building up in the air ports- emmission control system and it has to be cleaned. Unfortunately they have to remove the engine to do that! Thats a 35 hour job and thousands of dollars which I have to pay because it is just out of warranty. They admitted it is happening to more and more Q5s but Audi doesnt know why. It sounds to me like it is clearly a design flaw.
Has anyone else had this problem? Have you been able to get Audi to cover the repairs?
I need to pay $400-$500 to clean the intake manifold of my Bimmer.
Some said you need to drive the car hard to burn the carbon deposits from time to time...
If you have the same problem call customer service at Audi directly
Also is anyone willing to share some experience dealing with Audi, when their Q5 lease came to an end? Are they willing to buy the car back, or did they even lower the set purchase price. For the latter, I assume not, as the cars value is in high demand and value is holding up.
If anyone can share their experience, I would really appreciate!
Cheers
All appears to have been corrected under the certification now, but I am concerned about this reoccurring again. I will get another 8 mos.( & up to 13k miles) on original warranty plus the CPO warranty taking me to 4/15 and 100k. Any thoughts I whether I should walk away on this one? Also, any comments on Audi's prepaid service plan "Extra Care Plus" ($1050) for 55, 65, and 75K scheduled maintenance? Seems like it is worth the price, but I would appreciate comments.
With regards to carbon build up issue, from the experience with my car and from what I've found on the internet, it appears to happen typically between 45k and 85k miles, depending, I'm guessing, most likely on the type of driving and fuel grade used. My car required the repair (quite an invasive repair) at 49k, and was used mainly for city driving and fired on medium grade gas.
My first question is, is this worth the cost?
My second question is, does anyone know if this price is negotiable at all? Seems awfully expensive. I am admittedly not a "car guy" so I really don't know if this is a smart investment in terms of the care plan.
good luck.....ask about the factory warranty
I'm looking to purchase a 2013 Q5. Can someone explain the extended warranty to me. What the terms are, what it covers and how much it costs? I'm purchasing and not leasing. I'm very afraid of owning a German car that is out of warranty!
Thanks in advance!
-Jeff
I know that from owning many German cars, they don't put a simple maintenance item under the engine if they expected it to be serviced. Interesting on how much difference there is on repair estimates.....plan to shell out thousands of $!!
Audi is now sending out letters to Q5 owners that they are extending the warranty to cover this issue. My warranty for this carbon problem has been extended to 193000 kilometers and they will re imburse you if you had to pay for the work already as out of warranty. My Q5 is a 2010 with 3.2 litre engine.
Seems like Audi is coming through on this problem.
P.S. The oil burning problem is on later models with the 2.0 L engines. I dont know what is happening with that.
Thanks a lot.
When I am perhaps 1/3 or 1/2 into a long trip, it will show my range (before empty sometimes over 600 miles, but I have never squeezed more than 550 out of a tankfull. As you get close to empty the extended range will drop at a higher rate than you have actual miles left in the tank. And, believe it or not, although the gas tank is supposedly rated at 19.5 gallons, on two occasions I have put in 20 galllons, so I know I must have been running on fumes.
I October 2013 Audi extended the warranty form the carbon issue to 10yrs/120,000 miles. I'm going to need it addressed for second time
