Wipers will not stop - 2003 Jetta
in Volkswagen
Hi all -
The wipers on my 2003 Jetta Wagon will not stop. All positions appear to work OK except "off". In the "off" position the wipers move at normal speed. In the "intermittent" position I do notice that the wipers do not stop at the bottom, but will stop 3-4" up - and begin the next cycle from there.
I've changed out the wiper stalk assembly, but that hasn't helped.
Any ideas?
Any ideas?
Also, the wiper stalks are DESIGNED to keep out water... it is unlikely that you will be able to encourage any kind of lubrication inside where it will do any good. It is relativly trivial to remove the nuts, pop the pivots out, clean them properly and GREASE them with appropriate waterproof lubricant. Hence, you will never EVER need to do that task again. (I have done it on at least 4 VWs... on every one the original lube had dried out and I never had to do it again.)
1) Remove the nut at the top of the wiper stalk
2) The wiper arm pulls right off (MARK ITS CLOCK POSITION FIRST)
3) Place nut back on the threads (To protect the threads)
4) Hold chunk of wood on it (to further protect threads)
5) gently hammer on wood to push the stalk down and out of the bushing.
Once you get this far you are ready to clean and lube it. Use waterproof GREASE...no light oil here.
I recommend you do this to the side that still moves 1st... so you get a feel how it works BEFORE you attempt to free-up the stuck one.
I hope it is obvious that you need to open the hood and pull off the plastic cover to access the stalk after you push it thru.
