Jeep Grand Cherokee Diesel
jonopjonop Member Posts: 2
we bought the car about 3 month ago since then nothing but trouble to start with the coil relay kept popping so changed them as it struggled to start then had to replace no1 injector as that leaked alot of deisel through after doing a leak test. started up ok. then after having a tow bar fitted the engine management light came on and now cuts out when driving and wont start unless you use easy start plugged into computer and that brought up the air intake temp sensor that has been changed but still having the same problem and worse!! please help as we are running out of ideas!!!!
  • kyfdxkyfdx Moderator Posts: 271,314
    I'm guessing not in the US?
  • jonopjonop Member Posts: 2
    no not us in england its the merc engine one everyone has said they are great cars but so far we had nothing but problems
    edited April 2014
    "At more than $50,000, buyers should expect one of the best interiors in the business. Luckily, the new Grand Cherokee provides just that, especially in top-spec Summit form.
    On the highway the Grand Cherokee Ecodiesel is remarkably quiet, to the point you can barely detect it's a diesel. The bit of clatter it does exhibit makes it louder at idle than rival gasoline engines, but it's far from obnoxious.
    It has a terrific-feeling new steering wheel and solid, substantial controls, such as the large, grippy knobs for stereo volume, tuning and fan speed. "
    2014 Jeep Grand Cherokee Summit 4x4 Ecodiesel Full Test
