Corolla Tire warranty
Hi:
The treadwear indicators have become visible on the front 2 tires of my 2010 Corolla LE which has less than 20 K miles. Does anyone know what the warranty is on the original tires that came installed on this car? It's hard to believe the treads are already gone at such a low mileage. I can not seem to locate the original warranty that came from Bridgestone.
Thanks for helping me out.
Omega53
Omega53
You might call the tire manufacturer to see if they will grant you an exception - BUT - you now have 2 problems:
The first is that you didn't rotate tires - which is why the front tires are worn out. Had you rotated, the set would have reached close to 40K. The tire manufacturer knows this and may not be willing to cut you much of a deal.
The second is that it is the vehicle manufacturer who sets the specs - including treadwear - for the tires on their vehicle. Typically, vehicle manufacturers are concerned about rolling resistance and they get it by sacrificing treadwear. That's why there is no treadwear warranty.
So call Bridgestone and hope for the best..
Although I mentioned already (see message #3 above), to clarify once again, the tires were rotated once at the dealer's place (at 10 K) and a 2nd time at Firestone shop (at 13 K).
Thanks everyone.
