stalling subaru legacy 2004
in Subaru
My Subaru Legacy 2,0 2004 often will stall in the morning . The rpm will dropp to zero and sometimes it will get back to 1500 rpm and sometimed it will die . When it dies it is hard to get started again byt when it starts it smells gas ... The Map sensor i new, new sparkplugs, new air filter .
CAn it be the 02 sensor before the cat ?
Could be the ignition coil, or the wires (did 04s still have em?).
No MIL? Strange.
I might also try the fuel filter since it's cheap.
I probably didn't need to replace the crankshaft sensor, but all's well that ends well. :P
When the car is cold, it runs the idle off a map rather than adjusting fuel/air ratio based on oxygen sensor feedback, etc. So, I doubt it is your oxygen sensors. Rather, in order to maintain idle, it advances/retards timing based on knock sensor feedback.
I have chanched the map sensor ...
A tip was to reset the throttlebody during to disconect the + and - cable from the battery and put them together for about 15 min .
I tried to do that 2 days ago and so far so good , no problems left .
Lets se if it holding that way
