no backup lights
ramone899ramone899 Member Posts: 3
Hi all. The backup lights on my '97 Outback (151K miles) stopped working one night. I figure it's the backup light switch since new bulbs didn't work either. Is the switch hard to replace? Can I trust online providers to sell me the correct replacement switch, and help me avoid paying the dealer's price? Thanks a lot.
  • xwesxxwesx Member Posts: 17,837
    If you use a reputable source, I'm sure you'll have no problem. For example, I've found Rock Auto to be reliable and fast. I have also used Amazon Auto, but you have to be a little more careful with them (especially with small accessory items like bulbs), as they sometimes don't get their fitment lists correct. Be sure to read the reviews there, as if something doesn't fit, somebody else has probably already discovered that for you!
    As for the switch, it's not a common thing to stop working, so there likely aren't many owners who have dealt with it! Make sure you check fuses and whatnot before you start throwing parts at it.
