Ford Edge exhaust smell in cabin
 cobaltken1
                    Member Posts: 11
cobaltken1
                    Member Posts: 11
                                  in Ford
                    I have a 2013 Edge SEL AWD and if I have any window cracked open a little or all the way down when accelerating to get on freeway or just putting the gas peddle 3/4 of the way to the floor or all the way to the floor I will get exhaust smell inside the vehicle,anyone else have this problem?This is the first vehicle I have ever owned that does this and it gives me a headache. Not sure why it does this the exhaust pipes and tail pipes all look good with no leaks. Please Help
1
Would you say that's an exhaust smell too? Or something else?
I would push hard on your ford dealer on making ford resolve the problem.
I have put ford on notice to fix the problem are will have to look at my alternative option.
I have a 2013 ford explorer. When I accelerate to get on the highway or around cars the exhaust comes in the cabin. It’s been so bad that I have to roll down the windows. I am concerned for the health of my family. I have had my car in and out of the shop more than a handful of times. Only 2 of the times did the service department document my exhaust issue. I was advised that ford is aware of the issue but has no idea how to repair it. Were any of you able to get your vehicle repaired?
Do any of you still have your ford vehicle with the exhaust issue?
Do not worry about the burning smell because as the tobacco companies they have internal studies that the fumes do not cause damage.
Ford sent me this letter.
I recently had a check engine light on a 2012 vehicle that was a result of a failure of the catalytic converter, so that's certainly a possibility. First time I ever had to replace a converter in a vehicle. We tend to keep vehicles a fairly long time, so I suppose I was due
Since you're not getting any codes, hopefully you get lucky and you simply have a leak in the exhaust. But exhaust/converter is certainly where I'd be looking.
