2001 MPV - Nothing when i turn the key
mrmarkymrmarky Member Posts: 2
2001 mazda mpv. drove it quite a bit today, then parked and when i went to start it again a brief beep, cd ejected and nothing at all when ignition was turned. Tried a few minutes later and started fine. I noticed that the clock was reset. Just tried to start (hours later) and again nothing at all. Battery is fairly new. I noticed the coolan?t resoviour is empty. Anything I can check before i have to have it towed
  • jipsterjipster Member Posts: 6,302
    edited July 2013
    Check the battery cable connection, May be loose.
    Put some coolant in that reservoir asap.
  • mrmarkymrmarky Member Posts: 2
    Bingo
