Visitor Agreement.
Tomster
Have you hugged your Jeep today?
-Paul
That happened after I had left for home, but I heard about it later. I skipped the last day of wheelin' in order to have time to make a trip up to my hometown while I have the time off from work.
Tomster
Regardless of which type of rocker/bar you pick, they can be slick to women's shoes, so the handle is a good safety thing for them anyway.
Here are mine (prior to my lift).
-Paul
jeff
Just toss her in.
Terry
-Mike
While you were away, I don't think we were ever one of the most active forums
Nice pics as usual - looks like a ton of fun! So Hammond is way up near Gary, isn't it? That's a long haul from KY - but was it in Thelma Jane as well?
Just wanted to let you know I plan to post on the "Wave" forum this weekend, once I get a decent Jeep picture to include. Haven't forgotten, just delinquent with a good picture. Has everyone already posted there?
G
No, I didn't drive Thelma Jane up to Hammond. I drove the family 04 Impala, and that crazy thing got an avearge over two tanks of gas of 28.9 MPG! Yes!
It is about a 7 hour drive for me from here to Hammond. I go right up 41 from Evansville. Yep, Hammond is a neighbor to Gary and Chicago, right in between the two.
I saw a high school buddy that I had not seen in 37 or 38 years! We had it arranged to get together while I was up there. We had a real good visit.
Tomster
Jeff
Any advice would be greatly appreciated,
Thanks Bill
Your decision will depend on how much you'll be off road. Any jeep is already very good off road with a minimum of mods but....
You can put up to 31s on your stock jeep and not have rub. I think up to 33's will work with just a budget boost and no other additions. After 33's tho you start getting into making those major mods you're speaking of.
Anyway, you came to the right place...the experts will be along shortly..
welcome to the boards!
Aside from the highway issues of 35" tires and 3.73 gearing, which most likely would not make you a happy camper as far as acceleration or with repsect to maintaining speeds going up long hills, there is the crawl speed factor to consider for your off roading.
The crawl speed issue is exacerbated by the fact that you have an auto tranny. On very steep descents, you want engine braking going for you, so that you don't have to stay on your brakes. The larger tires will make your crawl speed faster than you would want it to be.
Is there some reason that you are going with 10" rims? If you air down for off roading, the 8" rim with a 12.50" tire will be less likely to lose the bead. It's perfectly OK to run 12.50" tires on 8" rims.
Tomster
Running 35's safely and efficiently can take a considerable amount of money, time, and effort.................though I'm not saying you shouldn't attempt it.
So, the higher the suspension lift, the more you change the driveline angle from the stock angle. You will get your U-joints working outside of their designed angle range.
Tomster
Bill
I'm always eager to learn stuff, so if you could get them to explain again the advantage of 10" rims with the 12.50 tires, I would be interested in hearing the details.
Maybe they are just telling you that you cannot keep your factory wheels with the 12.50" tires. That would be true. The insides of your tires would rub the spring perches in the back and the control arms up front. There is 5.5" of backspacing on the factory wheels, which is too much for the wide tires. You can BARELY run 11.50" tires on the factory wheels.
You can get 8" wheels with more backspacing, though. I have 15" x 8" AR767's with 4" of backspacing. I'm just running 31 x 10.50 tires, but I would be able to go to a 12.50" wide tire with those wheels.
Please find out if all it was was a backspacing issue.
If they say a 12.50" tire on an 8" rim would tend to make the tire wear in the middle, then I would counter that you would simply reduce the air pressure to make the tire have the proper "footprint." Jeeps weight very little, so it is not necessary or desirable to run a lot of pressure in the tires. I run 28 psi in mine. I could run less, if I chose to.
Bill, go with what they tell you, but believe me, LOTS of Jeeps out there run 12.50" tires on 8" rims with no problems at all. And, LOTS of people with experience will tell you that 8" rims are preferable to 10" rims for 12.50" tires.
Tomster
I was installing a new radio in my 2000 wrangler (amazingly one of my teen daughters took the car to the mall didn't pull the front panel and someone unzipped and helped themselves). I guess I was rushing and when I was installing I must have grounded out the hot lead (pink and white) now I get no dome light or courtesy lights not to mention hot power to the new radio install which is not working. I checked fuse 4 no joy! Any ideas? Thanks for any help!!!!!!
Well, finally got a CB radio for my Jeep...it's a Cobra 38 wxst handheld version, simple and sufficient for my needs so far.
Well, problem is, though it comes with an antenna already, it is obviously not very clear while in my vehicle. I cannot get anything other than the weather channel clearly. The purchase of another mounted antenna was necessary (and advised), so I went and got a high quality (as advised by all of you) magnetic mount cobra HGA 1500. Now I must set/tune it--now, as I've said plenty of times before, I am electronically retarded and do not own a meter to check this...any tips/suggestions? I really can't wait for this to work well, as I can then finally venture my jeep into nature where she belongs!!
Again, much thanks and appreciation.
Heading down to the outer banks next week, and am going to be taking my baby ('05 unlimited, stock
1. Any general tips you guys can give (what tire pressure to air down to, speed to maintain, 4 lo vs. 4 hi etc..)
2. What "emergency gear" should I take?
Thanks to all - Norm
sbcooke, "SUVs for Beach Sand" #350, 22 Jul 2005 8:30 am
I'm anxious to try it some day,,, (some day after I finally get to TB)
jeff
2: Take all the stuff mentioned on the recent thread about emergency stuff to carry, plus a narrow roll or two of carpet if you have it. A friend in another suitable vehicle would be a good idea too.
Just the opposite I would have thought. It's effectively a big inflated rubber bumper that will absorb part of any impact.
The rear glass, like the sides, is safety glass that shatters into blunt granules which rarely causes injury.
Your vehicle sounds as though it should be physically repairable without any problem. However, whether the insurance company deems it to be a financially viable repair is something only they can make the initial decision on.
Glad to hear you're all ok.
Were they on the phone? Is your jeep painted in urban camo? Drunk? Any explanation at all as to why they didn't stop? Just curious. Our traffic has been horrible here lately, and I have found myself often stuck for a minute at the end of a line. I sometimes flash my brake lights as I see folks barreling down on me.
If you heard about that terrible school bus crash in the news recently, that was in my town. I drove by within an hour or so and saw the aftermath. Being stopped at a light seems to be a really dangerous place to be.
Sounds like the Jeep did what it, and every other vehicle ideally, is supposed to do. Absorb the impact as best it can, and minimize injury. Glad to hear everyone's okay.
I recall (I think) we had an airbag discussion on this board recently. Would you mind offering if you and yours were wearing belts, and if the bags deplolyed?
Mike
I was amazed at how much body damage it had, and was concerned about the frame, because another car illegally tried to move into the carpool lane right in front of us without looking and we had nowhere to go. We grazed him and climbed the cement freeway divider. I was worried that we might have twisted the frame, but the Wrangler is one tough vehicle. It turned out to be over $4,000 of body damage mostly (the air bags didn't deploy - not enough of a front end collision). The neat thing about it was that we drove away while the at-fault Toyota pickup had to wait for a tow truck.
Here's hoping your Wrangler is back in your driveway soon!
Jeeperman Bumper
Hmm, I wonder whose it could be?
It's about to change again.
-Paul
I drove my Unlimited to Michigan via the Indiana Tollroad this past weekend with the soft top on. It was fairly noisy, but no worse than I expected. The engine doesn't like it too much when you're doing 75mph with the A/C, however. It was 100+ so I had to have the air on, and I noticed my side windows were "bubbling" out, and I couldn't figure out why. Eventually, I realized I had the A/C on with "fresh" air, causing the soft top to balloon out. When I switched it to recycled air, the sides actually sucked in. Pretty funny.
I'll attach em in another post for ya...
-Paul
If you end up ordering them and like how they look on my rig, let Eddie at Raingler know. These were originally done for him (hence the 14 MB TIFF's). I hope they end up using them in some of their ads soon.
-Paul
-Paul
It's not available separately from the master cylinder as far as I know, and no, I wouldn't leave it unsecured......it's bound to fail when you need it most! :sick:
Try to find a circlip or 'e'clip that works, or as a final resort you could use wire or a zip-tie.
Again, I hope everyone is well on the way to recovery.
Thanks anyway!
