Chevy Silverado/GMC Sierra - Owners hangout
-David
http://www.picturetrail.com/gallery/view?p=999&uid=526167&gid=747605&
I'd like to improve the ride a bit. Has anyone changed their shocks and noticed a better ride?
I'd appreciate anyone's suggestions. Thanks
whatsa;
Nice pics. Have you tried using chains with those tires? It looks pretty tight.
-David
-- Don
As far as overpriced and overrated? Not at all. I got mine for $216 and now that i have them I would have paid more for them if they cost more.
-- Don
Now I get to test the major guard extended warranty as my rack has sprung a leak. I called major guard and they said no problem just take it to a GM dealership. I asked whether it be a Chevy or GMC made no difference to them...so off it went to my Denali dealership...who's service advisor stated, we'll work on it and just curious as to why you brought it here versus your or any Chevy dealership. I jokingly answered I understand that GMC's have lock washers. Receiving a puzzled look, I told him the Chevy dealership has a new service manager...a young, gungho, company man who denies everything under the sun to increase his P&L. The advisor understood. Only problem is the rack is backordered and the wait is two weeks. I wonder how much p/s fluid I'll go through by then?
-David
Also, noticed the battery wasn't held securely in place-the front edge of the battery tray needed to be bent in towards the battery to keep it secure. Noticed it on another '03 so I would think most are like this.
After I got home and unhooked the trailer, I went for a little drive to test it out, and the problem was still happening. The next day (Sunday) I took it out and the problem no longer existed. Also drove fine today.
Now, I've experienced a "clunking" sound that seemed to be from the transmission before, and as odd is this sounds, it always seems to happen when I'm driving in a reasonably heavy rain, but it's never been as bad as it was Saturday.
Sorry for the long post, but I wanted to be as descriptive as possible. Does anyone have a clue what could be happening?
That did not help this cold I have been trying to shake , all day Sat and Sun in the rain hitching up the trailer loading and unloading the lawn tractor.
Then after a 5 min rest, turned the key and Y E S . What is the problem ? The hell if I know, but if I had not parked behind my dad's 87 Taurus I would have just left it and used the ford. That thing sits for weeks, but starts everytime you turn the key. I only keep it for sentimental reasons.
After it started the security light came on, but then it always come on when start up or when driving.
2000 Silverado 5.3 xcab
Revker: Tires are 285/75/16 on 16x8 rims. I cranked the torsion bars about 4 turns (raised front about 3/4") and still had to trim the plastic wheel wells toward the front of the truck. I still get a slight rub on the rear of the left front fender well when turning all the way to the left (would have to reroute the emergency brake cable - and the rub isn't bad enough to mess with that). No problem with the rear clearance. I have read others with 285 A/T's that don't rub with no mods. It may be the more aggressive side tread of the mud tires that causes the rub (or the 8" wide rims). As far as the ride, it rides like a 3/4-ton truck. I don't expect a car-like ride with no rattles like some others do. I will say one thing, and it probably isn't a fair comparison, but this is 10 times the truck my '91 F-150 was.
I have the Dunlop Radial Rover R/T's 265's on my 2500HD/ext cab/4x4/LB/4:10's/Allison/8.1
send me an email: omcniff@shinbiro.com
if you'd like to see pics
Owen
I really like the interior changes for '03.
truck doing ? Is it still the only one
in Korea or are you stateside now ?
Any problems or issues with it?...geo
My Y2K override feature works fine , push dome light button in 3 times and it cancels the auto feature. It resets everytime you restart the truck however. I thought 99's were the same way, maybe not.
Ray T.
Ray - I had a '99 Grand Am w/ auto headlights and there wasn't a damned thing I could do about them; apparently in '99 GM didn't realize that there are times when you don't want them coming on (like pulling up to a guard gate at a secure facility). I thought about popping out that eye in the defrost vent and bypassing it, but never did.
Also, I want to go with 265's : any reccomendations on brand? I like Michelin's, but I don't like their price.
Thanks - Mark
I have 35k on my Steeltex 245's and expect another 10k before replacement. I'm not to anal about tires, I mean it is a truck after all.
Ray T.
P265 75 16 and a LT 265 75 16 tire if you stay with the same tire pressure. The LT tire will (normally) allow a higher PSI. For example the P265 75 16 Firestone tires that came on my Z-71 have a max of 44 PSI, most LT rated 265 75 16's will be rated up to 50 PSI. IMO I would still run the same tire pressure regardless of P or LT (some will disagree, but they are FOS!) Unless I was caring a big load that is.
One thing that is a little strange - the P265 has a higher load rating at 44 PSI than an LT265 (load range C)at 50PSI. Not sure why.
You will find many LT tires in this size - only a few P rated.
The original P245s were Goodyears, and they seemed to wallow in the corners (sidewall flexing?). I like the solid feeling of the LT245s.
The suspension is the same for either tire type.
Mike L
I dont run it long. After a few min i turn the recirc on and it stays cold enough
kip
In the January 2002 Techline article
( http://service.gm.com/techlink/html_en/index.html )
GM explains the operation of the recirc switch.
A/C Compressor Runs with
Switch Off or Recirc Inoperative
On some 2000 Chevrolet Silverado and
GMC Sierra trucks built through
approximately October 1999, the A/C
compressor will run whenever Recirc mode
is selected. The A/C indicator will not
illuminate unless selected on by the driver.
Additionally, Recirc will not be available
with HVAC in Floor, Defrost or any
combination of Floor and Defrost. The
Recirc indicator will flash 3 times to indicate
this. HVAC will automatically switch out of
Recirc when any Floor/Defrost position is
selected.
All replacement Control Heads for model
year 1999 to present will operate in this
way.
Operating the A/C compressor in Recirc
mode will improve dehumidification and
assist in minimizing the chances of fogging.
Not allowing Recirc in modes that will direct
airflow to the windshield or floor will reduce
the amount of moist interior air being
distributed on glass surfaces.
Original Part Number New Part Number
09361345 w/rear defog 15753263 w/rear defog
09361355 w/o 15753264 w/o
? Thanks to GM Technical Assistance
Walter
WHat i notice though is when running the AC the engine bogs down (not bad but you know what i mean?) and with recirc it doesnt.
Anyone else experienced this, and can this be fixed with a Hypertech Power Programmer III?
Or maybe I'll keep driving it around in 3rd yet, but with the tow/haul mode on.
Or will the Hypertech Programmer be able to fix the problem and drop it into 1st gear if I floor it while I'm doing 35 mph?
Walter (Gator)
- don
PANG! Is the sound I get when driving forward or reverse at a slow speed like when turning into a parking stall. Seems like something is binding in the steering shaft and releases under tension. And the PANG! is quite loud.
After replacing the rack and pinion, the sound is gone. Not sure if they lubed the steering shaft or the leaking rack was the problem. Just thought I'd pass it on in case anyone else has the PANG! LMAO!!
I have a loud THUD when making right turns. SOunds like the front end is falling apart. I had the front tires off today and nothing looked abnormal. All bolts tight and nothing has play in it
Sounds like it is in the drivers wheel well/ under the drivers floorboard
Mike L
Also I have had the steering shaft fixed 3 times (WOAH). The first time you could feel the vib in the wheel when turning. This time there is no vib just an audible THUD.
Also i checked the shocks and those are fine. Also the tires arent rubbing at all either
I'm considering the purchase of a 2003 GMC 1500 base ext cab, 4x4 with a 4.8.
The vehicle will be the primary use vehicle, so I'd be interested in "real world" gas mileage you guys might be getting.
Also, I'm looking at using it to tow an open car trailer weighing in around 5000 lbs.
Anybody have experience in such?
Is the 4.8 enough? I know it's rated at 7100 lbs. but we all know "real world is different from "specs"
Thanks in Advance.
Keith in Zelienople PA
