Volkswagen Golf Care & Maintenance
I would very much like to know if anyone else is having the same problem as I with their throttle having a large amount of free play approx 1" (25mm). I have had car back to the dealer 3 times for this problem, the first they did nothing and said they called factory tech and they were told it was normal. 2nd time they tried to adjust and it got better but it only stayed that way for a few days. 3rd time they called factory again and said they got instructions for some NEW settings, well the car didn't have the lag in the throttle and ran like it had an extra cylinder added GREAT! I thought, it only lasted for about 2 weeks. it is back like it was when I first complained.
Thanks for your input!
I too have experienced the 'window-crash'in my 99.5 Jetta GLS, although mine occurred in snow (at the airport 35 minutes b4 flying out,grrr) not in desert heat.
Fortunately i guess, it happened on the very last day of my warranty, so it was repaired for free.
I've been reading the forums on vwvortex.com, and it seems to be a pretty regular occurrence that volkswagen fixes for free, and have actually redesigned the window regulator to compensate.
Good luck
Dave
* The car burns oil rapidly between oil changes and requires maintenance
* My drivers side AND passenger side window fell into the door and after the secretary told me there was nothing they could do (mind you, it was raining and I had a 1 hr commute home) I had the manager help, if you call it that...I was charged $250.
* The sunroof is broken (its $85 just for VW to look at it)
* The Mass Airflow Sensor needed replacement at 40,000 miles ($550)
* There is a rattling in the passenger side speaker (dealer can’t figure it out but charges for checking)
* The dash board lights sometimes don’t come on
Please note that all of these problems are not due to misuse of the car...at one time I ran a car detailing business and I treat the car very, very well and have been disheartened by its problems.
VW service is horrible!! and the workers are very unsypathethic to any problems. Since its not one problem that recurs over and over I dont qualify for the lemon-law; a loophole if you ask me.
I will never buy a VW again.
Feel free to ask me any questions… jeffebay2000@yahoo.com
I need some advise. I am a student on a very tight budjet and i am looking for my first reasonable car. Basically I need realiability (especially for our Canadian winters), don't want to invest tons in repairs and just a car that will get me to school,work, home. I expect to do about 20 000km/yr and I always keep up on oil changes and general maintenance etc.
Passing by my local garage, I noticed someone was selling a 4 door, 5-Speed 91 Jetta. It has 215 000 kms, some rust, visible repairs on the moldings but otherwise it seems in good shape. Took it for a spin and it seemed ok although i'm not used to driving manual. The thing that concerned me is that there was a light on the dashboard and buzzing of some sort, like a warning light. The guy said it was something he had to adjust. Any ideas what it could be? He's asking for $2000 CDN.
I am wondering what you all think of this. Do Jettas have an overall good rating? In terms of quality, do you think this car would last very much longer...will it see 300 000? Is there anyone out there with this same car that can give me some advise? Or anyone that has had experience with Jettas, were you pleased or deceived with Jetta?
Thank you so much for your help and advise. I appreciate all your time and patience. My first car is a big step and I dont want to make a mistake.
Have a great day!!
Regards
No this problem is the result of a lag. You press the pedal down slowly about an inch or two and you feel nothing. Then, after about 2 seconds, all the gas that you've been pouring in goes into the cylinders at once (the same effect as if you floored the car) and then the wheels spin. It is certainly not normal, but I don't know how much of a problem it is. It is a bit dangerous however with the V6 because you really take off and it tends to happen when you slowly accelerate while turning (around 5mph)...
P.S. How do you like performance of the new 180 hp turbo with the Tiptronic? When we test drove it, my wife did most of driving since it will be mainly her car. Seemed pretty fun, tho I wanted the stick for best driving pleasure.
I use 93 all the time, because it only costs $1 or so more per tank than regular. Also, 93 is recommended. I hear you can use 87/89, but with lower performance and fuel economy.
Black: You are wasting money and probably doing more harm than good to the car. Using premium in a car that only requires regular will eventually cause carbon build-up.
And 10,200 miles since Feb. 2001? I have 6300 and just got my car on 11/3/01.
I do have a couple of questions for current GTI owners about the car:
1) I only have about 600 miles on the car, but am noticing a low popping sound when making sharp turns especially at low speeds (backing out of a parking spot). The wheel is not fully to the lock, but it sounds like the steering/suspension making a sound. Is this normal and has anyone else experienced it?
2) There is a annoying rattle/squeak from the passenger side front seat. Any comments on what it might be and how to stop it? It doesn't seem to occur when someone is sitting in it or if I reach over and hold the seat.
Other than these two minor things, the car is a blast to drive.
The seat problem can be fixed by replacing the seat frame, which I've done twice but the second time it wasn't even fixed! So it lasts even today...Rattles are a given, you gotta hear my car. Even the little chrome area around the shifter(?) crekas when I slow down and accelerate! VW makes it better my [non-permissible content removed]...
Oils which are suitable for the full recommended oil change interval in all climates include, but aren't limited to:
Mobil Delvac 1, 5w40 (full synthetic, a reformulated version of Mobil 1 which is intended for diesel engines)
Chevron Delo 400, 5w40 (full synthetic version)
Shell Rotella T (full synthetic version, not to be confused with Rotella SB synthetic blend or regular Rotella T non-synthetic)
Amsoil Series 3000, 5w30 (full synthetic, CH-4 rated)
Amsoil High Performance, 10w40 (full synthetic, CH-4 rated)
Amsoil semi-synthetic 15w40 (CH-4 rated and high quality, but almost as expensive as the full synthetic, and higher viscosity at low temperatures)
Redline, synthetic version (make sure you get the type meant for diesel engines, with the CG-4 or CH-4 rating)
Our topic for Wednesday, March 13: Stump the Technicians!
Join us with your maintenance & repair questions this Wednesday from 5-7pm PT/8-10pm ET. Some of our contributors from the maintenance & repair boards will be waiting to hear your problems and attempting to solve them.
kirstie_h
Roving Host
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
I've got a 2002 Passat GLX. Been real happy with it but it's developed a vibration in the headliner, right over the passenger side rear seat. I mentioned it to the dealer when I had the first service (rip-off) and they said they'd ask VW about it; never heard anything.
But anyway, sometimes when the car idles I hear the vibration, often when driving, worse when the sunroof is open. It's not air pulsation, b/c I can repeat the sound when I tap the ceiling.
I'm hesitant to have the dealer do anything b/c I'm afraid they'll never get it all back together the same.
Anyone have the same/similar experience.
I am desperate for a solution. I want to ask if anyone out there having problem with condensation in the side marker lens. 3 month after I got 2002 GLX, some idiot stole my side marker lenses and lamps (lights below side mirrors). They pulled the lens out and cut a wire inside. They also tried to steal my alloy wheels but saw the lock bolt, then gave up.
Our dealer reinstalled a new side marker lenses, lamps, and wires. After a few days later, a driver side marker lens was getting foggy. I can see that there is moisture inside. Several days later, it started to form beads of water inside. We went to get serviced twice. The third time, e went back to our dealer and replaced the left lens and two hours later I see the moisture forming in the lens again. The right side lens is just fine since they replaced first time. We went back to dealer right away to show what’s going on. The dealer had no clue and seemed not cared. They used air pressure to spray inside the lens, which has not way of getting air. If you’ve seen the lens carefully, lamp goes in the lens but have clear plastic cover over it. No way of getting moisture in there. The dealer messed around, but the result is the same.
I am getting sick of it. I bought a new car so I don’t have to commute to the dealer every other month. Does anyone have some problem? If so how did you fix it? Any suggestions???
That's the thing, if you're a mechanic and can fix all the little rattles, etc., VWs are really fun cars to drive. But if like me you're paying someone to fix it, it'll cost a fortune.
engineering chic: didn't you say you were a mechanical engineer, or was that a dirt (civil) engineer? Though being an engineer doesn't mean you're mechanically inclined also....hope you enjoy your Subie...is it a WRX? Watch out for the glove box rattle and radiator leaks.
I own a 92 Jetta. Gasoline engine. Love the car. Bought it used, right now it's got close to 145,000 miles on it. Been across the country with it 4 times already. I have more than just one question, so if you want to reply to my userid (EM935YHF@aol.com) instead of on this board, please do, with my apologies.
ISSUE 1: engine slugginess. I read in here where premium gas creates carbon build up. I had no idea. Occasionally, I would fill it up with premium, especially when I drove it at the high altitudes in Colorado and Utah. Today, I'm now pouring in that injector cleaner stuff to bring back some peppiness to the car it used to have. But this week I plan to take it to the VW Dealer shop to do a thorough cleaning of the injectors and carburetor.
Will that be good money spent?($100)
Issue 2: the cooling fan. When I'm idling, the temperature climbs to about the center, the fan comes on and generally I see the temperature needle go back down slightly. But the fan sounds different this time. I don't know how to explain it. Before, it sounded pretty loud. Now, sometimes it's barely audible, other times it has this weird sound. Is this just my imagination?
Also, when it idles for a while, sometimes, not always, I smell this really odd smell, almost metallic. Catalytic converter? The injector cleaner doing its work?
ISSUE 3: In case anyone wondered, if it's hard to start or the RPM races when you push in the clutch to shift, check the oxygen sensor. About $100 to replace. What's that other oxygen thing that costs $550 to replace? Never heard of that.
Thanks everyone. Edward
http://www.tuninglinx.com/html/afilter.html
regarding octane:
http://theserviceadvisor.com/octane.htm
http://mach.mach-nine.com/gti/vwtechcontent/vwpdf/v970101.pdf
I have a 2002 Passat with 5067 miles on it. I was going to take it to the dealer for the first service. They were going to charge $35 for what seems to be a simple oil change. He also said they use castrol GTX. I was thinking for $35 I could do it myself (and use a synthetic)! I notice it has a audi filter on it. Anybody change their own oil or have advice WRT this?
thx!
thx!
You'll end up needing a set of car ramps, T-25 torx driver for the belly pan, 19mm wrench for the oil drain plug....
Is the belly pan the plastic shield that is under the front part of the engine? How may bolts hold it on? How many quarts do you need with filter? What brand of filters do you use and where do you get them?
Thanks, Dan
The engine oil capacity is about 5 quarts (the exact number is in the owner's manual, I think it's 4.7).
The first change I bought it at the dealership.
The second & third one, I got at Autozone, it was Purolator, but it was imported from Germany, it is a Hengst filter, which is one of the German OEM filter manufacturers.
Mann filters I've heard are good also. I plan on ordering them soon at http://www.vwparts.com Impex Auto parts, I'm told is very good.
car's oil should be changed at the 1,000 mile
mark. Vw says its fine until you reach the 5,000
mile mark. What do you guys think and why?
David
Jiffy Lube recommends changing the oil in your car every 3K or 3 months. Whichever comes first. I tend to agree with them. Except on a brand new engine. Some might argue that the reason they do that is to sell oil changes and make money. Which may be true. Then you have the dealer. Which says it only needs it every 5K. And some may say that the only reason they recommend this is to save on warranty costs since the first 24K on a VW is free concerning oil changes. At least mine was. And let's face it, the longer you go between changes, the faster your engine will wear internally. Plain and simple.
I have a 01 Jetta VR6 and I changed my oil myself at 1K with a dealer purchased filter. Then i let them do it at 5K. I then changed it myself at 7,500 and then let them do it again at 10K. So it went until they stopped doing it for free. It cost me money but my engine runs (and sounds) perfectly tuned with no knocks or ticks. The oil is also still a beautiful golden brown, not black. Im not saying that people that observe the 5K interval will have issues but I can guarantee you if you let that brand new engine go to 5K before your first change the oil will be jet black when you bring it in for service. And the car will still be pretty much brand new. Just seems like a pretty sad way to treat a brand new car. But hey at least VW isn't recommending a 7,500K service interval for the oil. Like a lot of car companies did in their owners manuals in the 80's and early 90's. Heck, some may still call for this. These mileage recommendations (7.5K) were called for in the owners manuals under "normal" driving conditions. But what most people don't realize is our everyday driving IS considered "severe service" driving. IE, stop and go traffic, dusty weather, extreme cold and heat etc. These are not "normal" conditions. Nor do they warrant letting a change interval go to 7.5K. OR 5K in my opinion.
But it's also my opinion that the faster your engine starts wearing out and blowing smoke the sooner you'll purchase a new one...along with the car it sits in. Letting your oil go for extended intervals is extremely tough on the rings and upper valve train in particular. Most cars these days are over head cam units (all VWs are) and it doesn't take much for these engines to starve the camshaft for oil if too much heated oil varnish builds up in the oil galley ways. The wear occurs at idle conditions if your engine gets to this point and doesn't get the pressure it needs at lower rpms. Ok, that's the end of my tirade for today. Bottom line.....change your oil......often. It can only do your car good.
