Volkswagen Golf Care & Maintenance
(it's in the owner's manual also, in the maintenance section)
for all engines: here's the 5,000 mile maintenance, the very first one.
Engine Oil Change
Engine Filter Change
Water Separator drain (TDI only)
$200 for regular service? That's some expensive oil change.
The $40 oil change, they will use 5w30 conventional oil
The $80 oil change, is using Syntec 5w40, "synthetic" oil
By the way, is the oil consumption on my car considered normal? According the manual, after the first 10k miles, this car needs oil change every 10k. Did they really mean it or it's just a bogus for sales and marketing of this car? Make no mistake, I love the performance of my Golf.
So my question is, outside of the normal, break pad check, airfilter change, possible fuel filter change, possibly afew other small items, what the heck is a dealer charging for on a virtually new car? The way I see it my subaru is in the same condition it would be in regardless of the Dealer checks and my wallet has $ in it!
The reality of it is Dealerships push extended warrenties when you purchase your car, even go as far as to say that it is your only chance to get a warrenty (that specific warrenty, maybe). The reality of it is you can buy a warrenty for your car at anytime for just about any type of coverage for just about any price range your looking for. For some reason it takes someone ready to walk out of their office for them to admit this is the truth.
They tag on a nice percentage for their own profit then proceed to convince you that you need to go to all the major scheduled milege checks where they do minimal stuff to the car and charge you a very high fee. When asked what they do they give you a laundry list of things they may look at but, almost never need to be replaced unless your driving the Indy 500 everyday and you have a 2 milelong dirt driveway. I would call that misleading the customer and to some extent being very close to criminal when you factor in the cost incurred by the customer if they act on a bent or twisted truth presented by the dealer.
As for these $100 Plus check up fees on a vehicle with fairly low miles? If the engineering is so poor that a car driven 5 miles or less a day would actually require $500 worth of labor and parts at 20,000 miles then somebody needs to have a talk with the guys that designed these things we aren't in the 70's any more.
As for the flat fee. Perhaps the parent company should set the flat fee to an hour at the hourly rate, and make the dealer list all the parts and costs that really need attention after changing the oil and looking at the car, then let the customer make the call. I bet that laundry list of things they give us would be cut down to the basics real quick.
How often do you give someone $500 to look at something and maybe replace a part or two that probably costs less than $20, just so you can say you've had it looked at?
Get real.....
T
There's a VW TSB that over a course of a few weeks the dealership will monitor the oil comsumption rate.
The interim fix for the oil burners is to rebuild and install thicker piston rings.
I have not been here for a while. Thank you for the inputs.
Last week I went to the Chicago Autoshow and spoke with a VW engineer. He confirmed that the oil comsuption on my Golf was not normal, and I should call 800-DriveVW if the dealer refused to do anyting. I really love the performance and design of Golf, but I guess it's time for me to take some action to protect my investment.
The switch on the door doesn't work when opening the door of the Golf4 GLS 2001.
So, you won't be alerted when you leave your keys in, your lights on and the light won't come on when you open the door.
Where is that switch? I purchased a maintenance book, but I can't find it in there.
Is it hard to fix? Does the new part cost money, or is it just an adjustment to be made?
Does anyone have any idea what the problem could be?
I've taken it to the dealer twice, but they can't find anything wrong with it.
I have a problem starting my 2003 Jetta VR6. It happens after the car has been sitting overnight. But not every time. I turn the key and nothing really happens. The lights come on and there is a faint sound like clicking. I try this several times and in about 5 minutes or so the car will start. I have asked the dealer about it they have no explanation. They checked the computer logs in the car- no record of the events are recorded. Also, the dealership kept the car overnight and said it did not happen. I am about to take it in again as it is happening more and more frequently. Also the car is running rough the car vibrates more than it did when I first bought the car in December. Not a dependable car so far.
Push switch in and turn to the right.
Remove switch and remove connector
Locate "TFL" pin. Cover that pin with some electrical tape.
Reinstall.
The oil drain plug bolt is under the plastic cover. I am not sure of your model but on the Jetta there are 11 bolts or so to undo. I have a TDI so the oil filter canister has to be opened and a new insert oil filter installed. I also have to remove the top plastic engine cover. Once the cover/covers are removed it is very very easy.
Just bought a certified pre-owned Jetta. Woo-hoo its pretty sweet! Wanted to know what is the best type of oil for the car, synthetic or regular? I recently read that synthetic oil may accelerate the aging process of a new car because it seeps into the metal parts and softens the metal? Is this true? This is the first negative I've read about synthetics.
Also, having your car serviced at the dealership versus doing it yourself and/or taking it to a less expensive mechanic. Any thoughts? Thanks for the help.
Andy
I hope I am posting this question in the right
chat room.I drive approximately 5-6k miles a year.It will take roughly 3-4 years to reach the
2ok interval, where some services are recommneded. Does it make sense to just do oil
changes and tire rotations in the interim?
What should drivers do,who put low mileage on
their autos? Just one last thing,why are the
spark plugs changed at 105k; and no recommendatio
is made to change the tranny or coolant (2001 vw passat) Thanks a lot,
David
I know this cd changer works because i tried it in the trunk of a 99 passat wagon and the cardtridge came out with no problem. Any ideas on what may be the problem.
Also my gas gauge seems to not be acurate. how can it say 1/2 tank when i just filled it up today and only drove 66 mi.
Could please someone clarify? The maintenance booklet first states timing belt replacement at 40K miles and then it is mentioned every 20K thereafter. Kinda makes little sense to me. I thought this (pricy) replacement is supposed to be done about every 60-65K miles. Any ideas?
Unfortunately, Edmunds' maintenance schedule tool isn't helpful either since it never mentions timing belt replacement at all. I looked through all service points from 40K up to 120K. This procedure is never on the list. Same about tire rotation, BTW, that I guess is supposed to be done every 10K. Weird. Not listing these quite important procedures is misleading and pretty much reduces the value of the tool (IMHO).
To talk more about the Passat, please visit one of our active discussions on this vehicle. You can locate them using the make/model drop-down menus at the left. Thanks!
kirstie_h
MODERATOR /ADMINISTRATOR
Review your vehicle
With the exception of diesel-powered cars (belt change recommended every 60K miles), changing the timing belt before the aformentioned mileage intervals is a waste of money, from my experience (I've owned 4 VWs now).
Hope this helps...
Is any VW 16 x7 in wheel likely to fit??
The entire wiring harness had to be replaced. (2 weeks repair.) Upon replacing the wiring harness and before returning the car to me, i was informed that the catalytic converter melted on the test drive, that the O2 sensors are burned out, and that all the sparkplugs were toast. This sounds very bad to me. They explained that upon testing the car, the computer was sending a 80% fuel /20% air mixture to to the engine, causing engine to flood and sending a ton of fuel to the catalytic converter. Thus explaining the spark plug and catalytic converter problem. The repair for this is to replace the sparks, the catalytic converter and the O2 sensors. In the process they broke and air return nipple which is now being replaced.
1. Is this believeable? Do the explanation fit the problem?
2. What is going on here?
3. How can i be sure that they haven't destroyed my car? I am worried that the engine, valves, pistons, cylinders, etc. have all been compromised.
HELP.
Do you know the correct size of the allen wrench and crescent wrench needed to do the job?
Is it really necessary to replace the bolts? Haynes manual says yes.
Also, Haynes says you can retract the pistons using "a pair of needle nose pliers" but they don't illustrate that. Is it necessary to apply pressure while you rotate the piston or does it "screw" itself back?
I have done disc brakes on a 1990 buick and replaced one caliper on a saab. How good do you have to be to do this job and get the complex parking brake adjustment right?
Any help is appreciated.
Larry Lapham laurencelapham@aol.com
Problems: I've had it in the shop for a fallen power window, a brake sensor that clogged with ice, a fallen gas tank door button (girlfriend pushed LIGHTLY instead of pulling up the first time she filled it up). Nothing major, but those are annoying reasons to sit in the shop.
Problem: When I start the car after it's sat for a few hours, it's sluggish for about the first 2000 feet I drive. If I'm in my space and back out, sometimes it has even shut off on me. Any ideas as to what this could be?
Complaint: This isn't having to do with the problems. Their maintenance schedule is completely insane. Approaching 40k, I've already been warned that the 40k service is going to run me about $400. I've tried to get things done at other shops, but all are the same or more expensive than the dealer. So, after that service, I will have put about $1000 into maintenance for just 1 1/2 years. My girlfriend's Honda Civic asks for nothing more than tire rotations and oil changes for 100k, and she gets those for free through her dealer. So, I'm inches away from trading.
I love the car, but it's costing way to much to keep maintained and it has an annoying problem (I'm mentioning the problem on Saturday.)
