MINI Cooper
14648505152
  • stevecebustevecebu Member Posts: 493
    My MINI Dealer is pretty far away from me, about 2 hours and it's mostly highway with a lot of traffic depending on the day. There are only 2 dealers and they are either in Peabody Mass or Boston Mass and I will be way up in New Hampshire. How do MINI owners deal with this distance for oil changes, services or what if your car breaks down? There are closer BMW places but nothing for MINI and Edmunds lists nothing in the entire State of New Hampshire!
    I've seen nothing on the MINI site to show anything closer.
    So what do people do just take a day off of work or rent a car when you get the car serviced?
    Also does anyone have any experiences with either dealership? I can't recall the names offhand but opinions are really welcome. Also about the back seats, are they really useable or is it very tight back there? We won't have the option to actually sit in one for a while as we are outside the country but so far the MINI really appeals to me wife and I like small cars that are good for a lot of highway use.
    I'd really appreciate some feedback.
  • bodble2bodble2 Member Posts: 4,514
    For me, the sunroof is not that desireable. It's large size really makes for a hot interior on a sunny day. And the mesh-style shade cannot block out the sun effectively.
    1. What is the Sport Button and what does it do?
    2. Do you need to insert the key fob into the dash before you can start the car with the Start/Stop Button, ala BMW 3-series? And do you need to turn the engine off before the fob can be extracted?
    3. It appears there is some sort of a LED light built into the top of the tachometer instrument pod. Is that for the security system option, so that it would blink if the security sytem is installed (and armed)? On the old Mini, the LED is on the tip of the turn-signal stalk.
  • rayainswrayainsw Member Posts: 3,195
    A 1 - From the 2007 owner's manual:
    > Engine responds more spontaneously to
    movements of the accelerator.
    > Steering response is more direct.
    With automatic transmission:
    > More rapid gear shifting in Sport program
    2022 X3 M40i
    A 2 - With Convenient Access, what my Daughter ordered:
    PG 25 The engine can be started or the ignition can be
    switched on when a remote control is inside the
    vehicle. It is not necessary to insert a remote
    control into the ignition lock, page 35.
    PG 24 The engine can only be started when the
    vehicle detects that the remote control is
    inside the vehicle.
    2022 X3 M40i
    A3 - From the 2007 manual:
    In vehicles with an alarm system preparation
    package, LEDs are located on the tachometer. If
    the vehicle is equipped with an alarm system,
    the LEDs indicate the various functional states.
    For more information on the alarm system, refer
    to the separate Owner's Manual for the alarm
    system.
    2022 X3 M40i
    Thanks for the detailed explanation....on all 3 points!
    Sorry, one more question. :blush:
    Can you ask your daughter, at your convenience, if there is any mention in the manual, about whether or not the engine has to be turned off, before the fob can be extracted from the slot in the dash?
    Many thanks!
  • minimac1minimac1 Member Posts: 2
    Having recently gotten a 2007 MINI Cooper (base), I was surprised when the 10.6-gallon-rated gas tank accepted
    more than 13 gallons of fuel. I queried the dealer, who said that the rating and actual capacity can be different. However, I wonder if the 13.2-gallon (50 liter) tanks for the Cooper S are also being put on the Cooper base. My "range" on the central console currently stands at 560 miles, and that seems high for 10.6 gallons. Anybody know about gas tank sizes?
    Maybe it is rated at 10.6 Imperial Gallons.
    Actually, nevermind. I got an '07 Cooper as a service loaner today. The engine has to be off before the fob can be extracted.
  • globalcitizenglobalcitizen Member Posts: 1
    Hi all - :)
    I'm about to purchase a 2007 Cooper S; however, I wanted to get feedback on Dynamic Stability Control and Limited Slip Differential options.
    In speaking with the dealer that I am working with he says that not many customers go with these options. I'm not sure how much this is true so wanted to get input on the pros and cons of these two options and whether they are really worth getting.
    Mark
    According to this link & a couple of others I have seen - 13.2 US gallons on both S & 'regular' now.....
    http://motoringfile.com/2007/05/20/minis-get-large-fuel-tank-in-the-us/
    2022 X3 M40i
  • charlenevtcharlenevt Member Posts: 2
    I'm purchasing my MINI this week, and one of the pros a friend of mine told me about (she's had her MINI for over a year) is that when you need service, MINI will send a flatbed truck to your place to take your MINI and will give you a MINI loaner while yours is being serviced. So, you don't even have to drive over! ...however, I don't know if they have a distance limit. *crossed fingers* that they don't! :shades:
  • paul_devilpaul_devil Member Posts: 7
    How can I relie on MINI cooper S if it's gonna be my first car for commuting? I have no idea about MINI. I am planning to get the newest one, Cooper S 2007, but still in researching. How does it function well on snow? How much problem?
    Pls, I need to consider all these factors. I did test drive and I love it so bad.
    If day-to-day reliability is your top priority, then I would stay away from the '07, due to the fact it is a 1st-year model. Wait a couple of months, and you'd be into the '08's.
    Thank you bodble2 for your reply.
    The thing is I might buy at the end of this year since I have to work hard for my fisrt dream car MINI. Somehow, I am scared because of all problems I have read the forums. I don't think I can effort all expenses that would occur. And I never saw anyone talk about how MINI works well on snow. I also want to know about that thing as well. I don't understand what do u mean a 1st-year model?
    Thank you so much
    The '07 is the 1st year of a major redesign for the MINI. Even Japanese models have some growing pains with a new redesign, let alone BMW which is, generally-speaking, less reliable than the Japanese brands.
    Regarding snow performance, for whatever it's worth, we've haven't had any trouble getting through light to medium snowfalls around town with our base MINI, with the standard all-seasons. In deep snow, I think the low front clearance may be an issue.
  • jaxs1jaxs1 Member Posts: 2,697
    I recently test drove 2 automatic Minis. A Cooper and a Cooper S. I was disappointed by several things.
    The Cooper had just adequate power with one person. Maybe 2 at most.
    I don't think people who plan on buying the new stretched Clubman because they want to carry passengers in the back seat will want this engine. I doubt it can safely accelerate with the weight of a full load of passengers.
    Since I will be driving with no more than 1 passenger and mostly with no passengers, I think a base Mini automatic would be "livable." Maybe it would be a bit quicker with the 6-speed stick.
    The Cooper S automatic was way faster. It had so much power that it caused torque steer and was jumpy and difficult to drive smoothly. You can avoid the torque steer by not using all the power, but the car was still jumpy even with light throttle.
    The ride of the S was hard and bumpy and the engine was too loud at cruising speed. Everything seemed louder in the Cooper S, even the tires and road noise.
    The worst aspects of the cars were the quality or the "quality control." The first car had the airbag light on and the salesman said don't worry about it, it's just a light that has to be reset.
    Both the base Cooper and the Cooper S had power side view mirrors that seemed to stick and jam in certain positions when you try to adjust them.
    The Cooper S passenger seat had a very loud rattle over ever little bump in the road. I thought the door wasn't shut properly, so I stopped and reslammed the passenger door and then realized it was the passenger seat making all that noise.
    The manual A/C on the Cooper S seemed stronger than the automatic A/C on the base Cooper. I'm not sure if it is because an S has a more powerful A/C unit than the base Cooper or if something was just set differently.
    They cars looked very nice. The interiors looked great with the optional $1900 lounge leather, chrome trim and piano black trim (except for some cheap gray plastic pieces that do not get upgraded with the optional trims and end up looking even cheaper in comparison to the upgraded trim around it).
    It's probably not a good idea to buy a 2007 or maybe any new Mini unless you have the time to take it back to the dealer a few times to fix various problems that will very likely come up.
    Some of these problems should have been found when the vehicles were inspected at the factory and then again at the dealer. Who knows what other problems would turn up after a few days of driving.
    I think, for some reason, the new 6-speed steptronic does not pair well with the Base Cooper. We have a '05 Base Cooper with the CVT, which is sluggish off the line. But once it gets going, it's actually quite lively. We drive it mostly in the city, but from the limited time we've had it on the highway, I think it would do quite well on the highway, as long as there aren't big hills to climb! Also, I find it very quiet on the highway, compared to other small cars such as the Civic. The CVT's biggest flaws are low-speed lurchiness and sluggishness off the line. But other than that, I actually think it is a better match for the base engine than the steptronic. I find the steptronic has very short gearing in 1st gear, and it tends to hold on too long before upshifting. You almost have to lift off the gas to induce upshift, which is not exactly conducive to good acceleration.
    I drove both cars with the A/C on. Maybe the base will feel much faster without the A/C. I have heard people say the A/C is a huge power drain on the base Cooper. However, I need the A/C most of the year, so turning it off is not a solution.
    Even then, I still found it adequate driving by myself. I was able to get on the freeway quickly enough with the A/C on, but no power to spare.
    The quality issues are a bigger problem.
    I thought the quality control was sloppy and an embarrassment to all who were involved in first causing and then not finding and correcting the issues.
    So as long as I have read you guyz mention about MINI, it made me think as twice seriously. But I doont really know why I really love MINI eventhough I never own one. It is really into me now. However, I dont wanna be the one who keep getting it fixed. As long as it will be my first car, I want to feel confident and more relie on.
    How could I do then? If I wait for 2008 MINI, clubman, I dont think I like it. It looks bigger and as jaxs1 said, the power doesn't adequate for sure. Is anybody light me up the way... huh!!
    "The quality issues are a bigger problem."
    I don't think it is quality issue per se. I just write it off to new model teething problems. The reason why I recommend waiting for the 2nd, or even 3rd year, if you can help it.
    If you don't carry passengers in the back seat, the Clubman probably won't be much slower. However, two 150 lb passengers riding in back will make it a joke with base engine, automatic transmission and the air conditioning running.
    You can always get a Clubman S.
    Maybe the 2008's will have better quality control and maybe you will be lucky and get everything fixed right the first time in only one or two trips to the dealer.
    I guess you just have to consider going to the dealer a few times a year to get problems repaired part of the "experience" of driving a Mini.
    It's your first car, you've probably worked hard to save up for it, and as you've stated, reliability is important. The last thing you would want is to end up with a car with gremlins, which would really sour your first-new-car experience, which is always a special experience (sort of like your first girlfriend!). I think you should resist urge to get '07 MINI. Wait a few months (if you can). The '08 would be out. And more importantly, it would give you more time to follow forums such as Edmumds to gauge the reliability of the car.
  • peachtreecitypeachtreecity Member Posts: 10
    Does anyone know when a 2008 MINI could be ordered, and when they arrive at the U.S. dealerships? A salesman in Atlanta told me they would not arrive until February 15, 2008, but I think he just wanted to sell me a 2007 from his lot.
  • mini0207mini0207 Member Posts: 1
    I purchased a 2007 Cooper in April and so far I have taken it back to the service department 4 times for the same reason: RATTLING DASH BOARD / DOORS MAKE NOISE WHEN CLOSING
    BRAKES GROWLING
    I have been told by the Service Advisor that ALL of the above is NORMAL.
    I have bought many cars over the years and NEVER have had these problems (specially on a brand new car).
    Please let me know your thoughts on this.
    um... nothing to say then since u guyz insist your words. I have to rethink about getting one soon. I just have to wait for a new model coming out soon. Inforamtion here is very useful for me. I've learnt alot since I have no idea about car at all especially European car. I always get used to Japanese car.
    The thing that I really want to buy MINI is that I love it, and in my country its cost about 80,000 dollars here. but here is what I can effort by myself. I hope to keep track of all new mini launching in the market soon from you guyz.
    Thank you so much, I appreciated.
    Paul_MD
  • motoronmotoron Member Posts: 6
    :lemon: Well, just under 25 miles into my "experience" and my new 2007 MCS check engine light (half solid) displays which reduces engine performance to a crawl. I limp home. Contact BMW who says "bring it for service." I do. Error code resets on Restart (MS Windows 98? :-) ;) so problem can't be detected. I'm sent home. Problem continues and I determine:
    Occurs when decellerating through 3000 - 2500 RPM w/o engaging clutch and when engine is warm.
    Return to Mini of Universal City. Force problem before arriving, they verify. (Dealer is great. Doing what they can!!!, BUT unknown code so need to contact BMW east coast. No one seems to have solution. Dealer has begun to order parts. 3 week old MCS. No driving without malfunction. I refrain from driving. Now 5 days in service at dealer. Do I need to contact CA Atty General's Office re: Song Beverly "lemon law"?
    Help! I miss my Mini and really want it fixed. So far, car is dangerous to drive (problem could occur at inopportune times, and who knows what the error could create?) I'm not faulting dealer, BMW has manufactured and sold an inoperable vehicle.
    I want my MCS (working) :(
  • oldfart4oldfart4 Member Posts: 3
    With 40 miles on my Mini Cooper S my check engine light went on. Without even looking at the car the guy at the service desk said that he knew what the problem was; the oxygen sensor was too sensitive as related to the car's computer parameters for it. That is, the computer settings were too narrow. BMW uninstalled all the software and reinstalled it (4 hours) and the problem disappeared.
    Alan Lisook
    I am trying to get an idea of the size of the Mini's rear seat legroom. Edmunds lists them as having 29.9 inches. Although I have no clue how they got that figure. Was the front seat all the way up or midway?
    I know the best thing is to go to a dealer but we are just not going to be back in the US for a while and my wife who is 4'11" tall figures with her slim build she can fit in the back seat when needed.
    Size is such a relative thing but I've heard it's very tiny in the back but I'm only 5'7" tall so I drive in a relaxed position but hardly way back like a very tall guy. Any ideas about how to measure the seats? has anyone actually done this? I always thought the measurement was from the front of the rear seat cushion to the back of the front seat back. Is this correct?
    can anyone actually measure the distance that way in theirs for us that way? That way I could try and push the seats in my current car to that size and see if she fits.
    I've seen the Mini Ad on the Mini website where 4 big guys get out of the car but I doubt they were very comfortable sitting in there.
    We dropped another car off our list and are narrowing down our suspects and they just don't sell Mini's in this country, unless you want an old one.
    Help with this would really be appreciated.
    My wife is 5'1" tall and drives in an upright position. With the front seat set for her, there is 5.5 inches of leg roon between the back of the front seat and the front of the back seat cushion.
    My wife is 5'1" tall and drives in an upright position. With the front seat set for her, there is 5.5 inches of leg room between the back of the front seat and the front of the back seat cushion.
    Thanks, I went out and measured it and she can fit in the backseat but I cannot. But the seats in my truck do not go back that far they go to about 7 inches.
    I can go to the Toyota dealer hand have her sit in the 3rd seat in an Innova and that should be more comparable. Those are very tight in leg room. I'll measure that distance and see what it is. She really had a problem in the back of the Innova as it's really for kids or the maid.
    Thanks for the help
    My mother in law is about five foot two I think and could fit behind my wife who is five foot six in our MINI.
    I would think four foot eleven should be fine.
    We just watched a You Tube video and a 5'11" guy was able to fit into the rear seat of the Mini, a 911 and a Ridgeline truck trunk. So I guess it's doable. She's the one who will have to sit back there if we take my aunt anywhere. At least until we buy a bigger car as a primary car. I want small and mid size so it's a tossup between the Fit, The Scion xD and the Mini Cooper S (might as well get an S) Yes the prices vary a bit :) but I had a Jazz/Fit and it's not a good car for highway driving. But it can hold a lot of stuff! No clue about the Scion xD until I drive one. The big issues with the Mini are the RFT's, no spare tire and the dealer is a State away. :(
    My wife is going to want the mini but it's got to fit at least 3 people and go on a 90 mile trip once every few week with all of us. Most of the time it will just be either one or the both of us.
    So we'll see but at least we know it's possible. :D
    i'm kind of loathe to buy a 2007 Mini in December or January and I have no idea of the new colors available. I really liked the Hyper Yellow but not the ugly mustard yellow. All I have heard is around march 2008 for the 2008 Mini Cooper S. I really hate to lose a full year depreciation with zero discount available when a new model will be out in 1-2 months or so. If anyone has any info please post it. Thanks
  • esther5esther5 Member Posts: 1
    I could use some friendly advice. I searched the archived discussions and didn't see any question quite like this.
    I have a love – hate relationship with my 2003 Mini Cooper. I love to drive it. I love its looks and what it stands for. However I have found that although the car has wonderful styling and peppy drive, it’s seriously unreliable. In the last three and a half years, I’ve been in and out of the dealership with a cornucopia of issues:
    -severe oil leak, entire transmission replaced
    -two broken fuel pumps
    -broken oxygen sensor
    -strut covers fell off
    -two broken glove boxes
    -windshield wipers & sprayers re-installed (twice)
    -door locks on both sides replaced
    -battery replaced 2x in 1 year
    -poor A/C
    -passenger’s & driver’s windows stop working
    -driver’s & passenger’s doors won’t open
    -sunvisor won’t fold shut
    -torn upper strut mounts
    This car has near about broken my heart. My warranty ended last spring and it’s become apparent I cannot afford the upkeep. I’ve spent $3000 in the last six months! My gut is telling me to quickly trade it in for something new, while I still can get a decent value out of it. But what to replace it with? Mini has my heart; I haven’t found another car in the universe (priced 25K or under) that revs my engine. I test drove a Prius and it was nice enough but it seemed huge and looks like a spaceship. Not cute and zippy at all.
    I’ve considered staying in the Mini family and getting a 2007, but complaints about the “teething” issues are starting to flood several message boards.
    Like I said, it's crushing to even consider not getting a Mini. But reliability matters! Any suggestions or advice on this would be greatly appreciated. I am totally stymied. Do I stay in the Mini family and sacrifice reliability for style? Or do I choose a practical car that lacks the unique Mini zing? The only thing I know is that I need to get rid of my 2003 before it breaks down again!
  • tiff_ctiff_c Member Posts: 531
    I've been through what you are going through but it's been with other brands.
    I guess you can always buy a 2008 model which should have the 2007 bugs worked out of them otherwise you'll have to try another brand. have you tried the Mazdaspeed 3? Yes bigger and a hatch but for small zippy cars there is only the MINI. British cars are usually notoriously unreliable. My wife wants one but the dealer is very far and reliability is a big factor. I honestly can't think of anything that can compare except a Mazda Miata. I had one and they are great! But only 2 seats, but the fun factor is very high and they are RWD and about $25K. They are also very reliable. The manual top takes only 10 seconds to drop from inside the car.
    I'd be interested to know what you do end up getting.
  • denrogdenrog Member Posts: 8
    I am very interested in buying a 2008 Mini Cooper/ S and just test drove both equipped with the automatic. Of course the test cars were 07's but anyway the Cooper had stock 15" wheels w/o the sport package and the "S" had 17" wheels with the package. I did notice that the car had a better ride with the 15's and I was wondering if the tire size was the difference or the sport package combined with the larger 17's on the "S was the reason? I really like the look of the bigger wheels but the ride is actually more important to me. Do you think that the 16" wheels would be a good compromise? Also I didn't really feel much of a difference between the two motors out on my test drive. I took it easy and just drove like I normally would so I'm thinking that the more horsepower and turbo would benefit me more in passing and accelerating with the peddle to the metal so to speak. Otherwise the 118 hp would do just fine. Any thoughts?
    Thanks..........Dennis
    I thought the base Cooper comes standard with 16" wheels, or is that just for '08? The harsher ride was probably due to both the sport package and bigger wheels. Can you get a base Cooper S with 17" wheels but without the sport package? That might be the best combination for looks and ride comfort. And I agree that the turbo would not make its presence felt if you're just cruising along serenely!
    The 08 Cooper has 15" wheels as standard equipment and the "S" comes with 16". Yes you can get 17" wheels without the sport package but I think that all low profile like tires which I would consider the 17" to be lend themselves to a somewhat rougher ride. I may have to take another test drive.
    Does anyone find the Mini's rain-sensing wipers not working as well as advertised. We just leased a '07, and it's been snowing here, and the wipers don't seem to work as they're supposed to. One push up is supposed to bring on rain-sensing function, but it only seems to go into regular speed mode. Does it not work if it is snowing? :confuse:
    On our old '05 Cooper, when you unlock the hatch with the remote, the lights will flash twice, and when you close the hatch, the lights will flash once to confirm locking. On our '07, the lights don't flash, either to confirm locking or unlocking. (They wil flash when the doors are locked and unlocked). Also, does the hatch unlock button have to be held down longer than normal to unlock the hatch? Can anyone confirm if this is the way the system is supposed to be?
    Is there a panic alarm feature on the Cooper? When I tried to unlock the rear hatch with the remote, more often than not, I trigger the alarm. I suspect I may be holding down the hatch unlock button too long which triggered the alarm.
  • minipakminipak Member Posts: 7
    I would like to learn if standard '08 MINI Cooper has the same HP engine rating compare with the '07 model. I have red somewhere that the 2008 model has redesigned new 120 HP engine and, also, the body is about 2.5 inches longer. Could anybody confirm that?
    The longer body is probably referring to the Clubman. Otherwise, according to my salesman, the '08 is identical to the '07, including the engine output. Of course, it also wouldn't surprise me if a salesman dispensed incorrect information. :(
    In the owner's manual for the '07 Mini, it says that there is a warning symbol if you've left a door, the hatch, on the bonnet (hood) open. I've tried doing that with the ignition off, ignition started, engine running, transmission in Park, transmission in Drive, and any combination in between, but I don't see any such symbol! The only thing I haven't tried is to try to open something while the car is actually moving. Perhaps the manual is printed for all market versions of the Mini, and there are regional differences in the Mini? Anyone else (especially in Canada) whose Mini displays these symbols?
  • spyderonespyderone Member Posts: 54
    The 2007 is 2.5 to 3 inches longer than the 2006 and as far as the HP I would assume it is the same since they just changed it for the 2007 model. All the changes that were made were from the 2006 model to the 2007 model.
    Below is a link to the article, where I've found the info about futures for the '08 MINI Cooper:
    http://onlocation.consumerreports.org/AutoShowDetroit/2-Model.asp?ID=349
    From the 2007 Detroit Auto Show:
    "The iconic Mini Cooper is updated for 2008, though you need to look close to note the differences. The front-end has been extended 2.4 inches to allow for a new powertrain family and to meet pedestrian safety goals. A revised grille and more aggressive front fascia modernize the appearance.
    The interior is more thoroughly revised, though it remains true to the previous iteration's distinctive layout. The center speedometer is larger, and the gauge face now accommodates more functions. Center-stack controls have been updated, though the toggle-switch array is still used. A Lights Package provides a series of ambient illumination.
    The base Cooper features a new 120-hp , 1.6-liter four-cylinder, with a slight power increase. The more exciting Cooper S sees the supercharger replaced with a turbo. Peak output is up slightly at 175 horsepower, though the performance character is likely different. The standard transmission on both is a six-speed manual, with a paddle-shifted six-speed automatic available. "
    Sorry but this sounds like the 2007 Mini and not the 2008 which isn't even out yet. The changes are almost zero but prices have gone way up. $500 more for the Sport Package which is the same as the 2007 Sport Package.
