MINI Cooper
1151618202152
  • raybearraybear Member Posts: 1,795
    Hey Revka, if you need to know how that car handles winter driving conditions I'll gladly volunteer to fly out there and take it for the next eight months or so...
  • footiefootie Member Posts: 636
    What in the world is the Mini doing with a shift 'cable'. With all the rest of the electronically assisted do-dads, why isn't this some combination of mechanical and electrical certainty.
    Is this the secret British addition to the car to insure it continues the tradition of 'the mysterious defect in your car was randomly assigned at the factory. Like all mystery defects they are guaranteed not to show up under scrutiny and only appear at the most awkward moments.'
  • lngtonge18lngtonge18 Member Posts: 2,228
    Shift cables aren't new, nor rare. They are used in just about every manual transmission on the market. This includes Honda, Toyota, VW, etc. The cable operated shifter is considered more simplistic and less prone to problems then shift linkages. Eletronically controlled manual trannys are currently available only on Aston Martins, Ferraris, and Maseratis. I do believe the Mini is considerably cheaper then those cars and therefore the cable should not be a shocker.
    Thanks, Ingtonge18.
    I guess I feel better knowing that Honda and Toyota do the shifter via cable. I should have known that was true!
    I feel much worse, though, that with 100,000's of these being done in cars built in the U.S. by these two major vendors, that BMW and Mini can't figure out how to duplicate what works, successfully and reliably in new cars.
    There's no excuses today for poor execution of undifferentiated technology.
  • hpulley4hpulley4 Member Posts: 591
    I read that a MINI rep told someone (so true or not I don't know) that the design was originally made break-away on purpose so people who drove their MINIs really hard would unclip the cable instead of wrecking the tranny. So it was at first just a magnetic linkage. This was too weak so they added the bushing. Now for the fix, they're adding a clip to the bushing. True or not, I don't know but it does have both a bit of a ring of truth and a funny sound as it means the clip is a hack on top of an existing hack (the bushing).
    Too bad there were in production for a year before they discovered this and too bad for the north american launch especially as if they'd found it just a few months earlier, there wouldn't be any bad cars over here.
  • rickroverrickrover Member Posts: 601
    I'll bet the aftermarket will have an upgraded short throw shift linkage for the MINI soon. I put a short throw shift linkage in my GTI recently. With all the aftermarket performance vendors that are turning their attention to the MINI and S, it won't be long before you'll have a choice of enhanced shift linkages for the MINI. I had around 5 different short throw shift linkages to choose from for my GTI and chose one from dieselgeek.com.
    When you put a new, short throw linkage in, do you replace the things that are coming loose on Coopers?
  • mgreene1mgreene1 Member Posts: 116
    They got the weight wrong (should be 2678 lbs per Mini brochure), but still a very interesting read.
    http://www.europeancarweb.com/archives/features/0802_feature02.shtml
    I would think an aftermarket company would address any inherent design shortcommings plus enhance the linkage feel and shorten the throw. My GTI had the rubbery somewhat vague feel that front wheel drive cars tend to have. Now it has a much more positive mechanical feel with shorter throw, not unlike a typical BMW. I liked the stock shift linkage in the Cooper S I drove - I'm sure BMW will get the linkage bugs worked out.
  • wolf22301wolf22301 Member Posts: 10
    Can anyone explain the advantage or disadvantage associated with getting the 17" wheels? I'm not certain I like the look of them and don't know whether they improve handling or make traction worse in snow? Is it just another fashion statement? Will my tires last longer or need replacement more often?
  • silver_bulletsilver_bullet Member Posts: 1,339
    ... most people get large diameter wheels for looks. Generally speaking, larger wheels weigh more and thus increase unsprung weight, a bad thing. Larger diameter, low profile tires usually provide sharper handling, with the tradeoff being increased cost, harsher ride, shorter tire life, and more weight. Most snow tire fitments will call for smaller diameter, taller profile tires that aren't as wide - you want a snow tire to dig into the snow, not skate on top. As with many things, there are exceptions (for example, light weight forged wheels might weigh less than your smaller diameter factory wheels), but these have been my experiences.
  • crcoxecrcoxe Member Posts: 72
    ... with silver_bullet. People may fool themselves into thinking they are getting the larger wheels for better performance, but it's really nothing more than looks. Personally, I opted for the 16" rims on my Cooper for this reason alone. The 15's just looked too skimpy. The tester I drove before buying mine had 17" rims on it (like the picture on post # 848 - I think they look great) and I must say it stuck to the road like nothing I have ever driven before. Then again, so do the 16's. And cost is also an option, not only for the rims, but for replacement tires also.
    Haven't had the opportunity to drive in the snow yet, but I think it'll do just fine.
    As for the rough ride, remember this is a MINI. It comes with very tight suspension standard (even tighter with the sport pkg and on the "S"), so you will certainly not mistake the ride quality for that of a Lexus. I may be mistaken, but the difference in ride quality from the 15's to the 17's can't be all that noticeable - can it? Cobblestone and pothole infested streets are not among the MINI's best friends, twisty back roads are!
  • nyccarguynyccarguy Member Posts: 17,954
    you are correct...the bigger wheels usually have wider tires with lower sidewall aspect ratios. The rolling radius of the 15, 16, & 17" tires should be the same so the speedometers don't have to be calibrated for each car differently. The lower the sidewall you have means the less tire you have between you and the road. So the 17" wheels will ride slightly rougher than the 16" wheels. 17" wheels also add weight as opposed to 16" wheels. Weight is the enemy of performance.
  • jtaimjtaim Member Posts: 34
    Folks, sorry if this has been asked already, but how is the Cooper with the A/C on? In Texas the A/C will be on almost all of Summer and with such a tiny engine, any HP loss will be noticed, even if it's a light car. I just want to be sure the Cooper isn't a dog with the A/C on.
    There is some loss, especially when getting started from a dead stop but as long as you give it a little extra gas, it goes alright. It is a small engine and A/C does hurt it some for sure though.
    I wouldn't go so far as to say the Cooper is a dog with the A/C on, but as hpulley4 notes, there is a noticeable power loss especially off the line or merging onto the highway. It's certainly a factor for consideration if you really want to hit it hard with the A/C on. Since you are a Texas buyer, you may want to spend some time on the test drive with the A/C maxed out and see how it feels to you. I have no major complaints about it.
  • johnny36johnny36 Member Posts: 10
    silver_bullet has touch on a subject that I've been mulling over...
    I got 15" wheels and I too have felt they look a little 'skimpy' (the only aspect of my MC that I'm not over the moon about).
    What I'm wondering; what's involve with 'upgrading' to 16's? Are wheel-wells different on MC that was build for 16's (or 17's for that matter)? Anybody have an idea of cost? I'm not desperate for the change, I would be doing it for purely aesthetic reasons as I certainly don't feel my MC lacks performance.
  • drivinisfundrivinisfun Member Posts: 372
    I don't think going from the 15" to the 16" wheels would be a problem as long as you stick to the appropiate tire and wheel dimensions recommended for the car. Visit Tirerack.com for further details.
    As long as you pick a wheel/tire combo that stays within the design parameters of the car, you'll have no problems. The only difference between a MINI with 15" wheels and one with 17" wheels is the wheels and tires. What you need to watch is the overall diameter of the wheel/tire combo. You want to stay within 1% or 2% of stock if possible, and you also need to make sure the replacement wheel's offset is within spec.
    Things are moving along pretty smoothly. The car was finally built on 8/7 and it already has been loaded and booked on the vessel for the Atlantic journey!. I had a production date of 8/9 but this week's production batch at the Oxford factory was running ahead of schedule. Very excited!! We are expecting to take delivery sometime in early to mid September!
  • britgreenbritgreen Member Posts: 1
    Anyone compare the Mini in a test drive to the Bug? I like the TDI that the VW offers - and wonder if Mini is an over hyped car? Can I sniff your elmer's glue???...
    My Mini has been ok - performance wise (15" wheeels, non S)has been ok. I've taken it back a few times for misc. fixes to the dealer (that's a 60 mile trip...) and am not happy with the dealer experience in Jacksonville Fla.
    Enjoy the looks you're getting now (I am) but look for my car on the lot in 6 months....
    Well I suppose someone has to be the devil's advocate. It's good to shake things up a little but every now and then. I didn't test drive the new beetle, nor did I ever have any interest in it. I think it's just personal preference on styling, etc. Also, I have heard some real horror stories about the Beetle's poor performance after a few years (oil consumption, excessive rattles/noise, numerous trips back to the dealer). Of course, the MINI has not been around long enough for a comparison in this regard, but I would hesitate before purchasing a Beetle - even a TDI - notwithstanding my personal preference against the styling. Check out some of the VW discussions here on edmunds, seems as though quite a few Beetle owners are not all that happy.
    As for whether MINI is an overhyped car, I suppose time will tell. Keep in mind that they are hardly advertising at all - word of mouth is saving them a pretty penny in the advertising dept. With production numbers so low for at least the first two years, the hype may not drop for a while. That will hopefully keep resale values up should you decide to get rid of yours soon. Personally, I think trading for a Beetle would be a big mistake. Of course, I am so happy with my MC that I can't even conceive of dropping it for a VW.
    There's my Elmer's glue. Sniff away.
  • revkarevka Member Posts: 1,750
    You may want to check out our Mini Cooper vs. VW New Beetle discussion. Happy motoring!
    Revka
    Hatchbacks & Wagons Boards
    What kind of problems have you had with your MINI? Have they been only annoyances or real threating problems?
    Rest assured, your MINI is a vastly superior car to the current generation IV VW Beetle in every possible way including interior space packaging. The Beetle is simply a Golf with a Beetle body, that's pretty much it. The current Jetta/Golf/Beetle IV Platform is becoming pretty obsolete as these cars in stock form exhibit too much understeer, soft springs and generally good but not earth shattering handling dynamics. Also the Beetle has a solid rear axle which is prehistoric in comparison to the rear suspension setup found in the MINI.
    As noted by the previous poster, the Beetle's reliability has been rated from poor (Used cars to avoid per CR) to the current average rating. VW service is nothing to write home about and these cars by now already have very well documented design and assembly problems that will only be cured when the next generation V platform debuts in 2004.
    Finally, I will avoid a Mexican manufactured VW product at all costs, trust me, the Puebla plant is churning out very questionnable quality and continues to do so (Just check the Jetta/Beetle forums and see for yourself).
    A family acquitance bought a new 2002 Brazilian built VW Golf 5 door. The car has been great so far but the 2.0L engine is noisy and racous in the highway albeit it returns good fuel economy and has good low end torque for a small 4 cylinder.
    If I were to go to a VW Beetle, I would prefer the Golf as it is a more practical, better looking car for the same money. Better yet I would wait next year for the V generation Jetta/Golf cars but be warned, these will be first year models such as your MINI, so don't expect squeaky clean reliability from the get go.
    Based on the MINI's reliability performance so far (MINI2.com MINICooperonline.com Roadfly.com) I think most of the problems experienced by early build owners are mostly annoyances and nothing safety threating with the exception of the shifter cable problem in 5 speed Coopers (Which BMW already issued a worldwide recall and VIN range numbers have been posted for a new improved cable fix) and the hesitation in some MCS models (For which a software fix is scheduled to be distributed next month).
    I think the MINI is a very solid and excellent bet from any point of view. It boggles my mind why people keep buying such junk as the Ford Focus (Ugly, cheap interior and chock full of recalls).
    But if you want an APPLIANCE that almost never sees the dealer for the exception of oil changes, then a Toyota Echo is more the car for you. But hey who knows, even Toyotas have had problems with engine sludge!! :)
    So as you can see the 100% perfect car does not exist and all manufacturers can put a bad apple here and there from time to time. Is just the nature of high production numbers.
    I had heard rumblings of a possible recall, but nothing in stone. Where is it posted? I am expecially curious because you say it also references specific VINs. Not sure if mine falls within the ones slated for the new shift cable or not. If necessary, I'd rather get a pre-emptive fix as opposed to getting stranded at wrong place/wrong time.
    ( I would strongly suggest for you to frequent more MINI2.com Minicooperonline.com and Roadfly.com sites as these have much more up-to-date information than the dedicated topics here in Edmunds.com)
    Recall Alert: MINI COOPER
    Owner Notification Date: 7/26/2002
    Number of Units Potentially Affected: 3,531
    Component Description: POWER TRAIN:TRANSMISSION:3 SPEED:LEVER AND LINKAGE:FLOOR SHIFT
    NHTSA Campaign Number: 02V201000
    Description of Recall Campaign: On certain passenger vehicles equipped with manual transmissions, the transmission shift cable connects the gearshift lever in the vehicle interior to the shift linkage on the transmission. It is possible for the shift cable to detach from the transmission shift linkage while the driver is attempting to change gears. If the cable detaches from the shift linkage, gear changes will no longer be possible and the transmission will remain in the last gear selected.
    If shift cable detachment occurs and the transmission remains in any forward gear, the vehicle can still be driven in that gear only. However, if the transmission moves into neutral and remains there, the ability to accelerate or maintain speed will be lost, increasing the risk of a crash.
    Dealers will inspect the shift cable and, if necessary, install a retaining clip over the end of the shift cable to prevent it from detaching from the transmission. Owner notification is expected to begin August 15, 2002. Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact BMW at 1-866-ASK-MINI (1-866-275-6464).
  • seminole_kevseminole_kev Member Posts: 1,696
    I guess some of us are too stupid to not buy "such junk".
    By the way, saw my first MINI that was actually out on the road. Silver with black roof. Great looking car. Oklahoma City finally gets its first official MINI dealer @January of 2003. 'Bout time!
    Kev, sorry about my early remarks re: Focus. Totally off the wall. But let me just say this....I had an opportunity to ride in a new Focus ZX3 over the weekend and was not impressed with the interior materials and finish. I had higher expectations for this car in terms of interior build quality and finish. It looks and feels very cheap. I almost felt like I was riding an old Renault or Fiat or even a Pontiac LeMans (The ones made by Daewoo).
    I am sure the car is terrific in many other aspects but the interior is really Dodge Neon grade all the way. The ergomonics are a different matter all together.
    Still, the Focus recall history and low resale value are its main deterrents amid very good competitors in its class. The irony of it all is that Ford did both good and bad to the Focus, by creating a world class small car and by at the same time destroying its quality reputation in NA at the same time.
    Hey, I'm not going to dispute that Ford's boned up the launch of the Focus, that's for sure! Really I think the interior is not as nice in quality as the Civic or Golf, but on par with the Protege, Sentra and previous Corolla. (I haven't been in the new Corolla, but hear that it is now the class leader in interior quality for inexpensive compacts).
    To tie back into the MINI. I really dig the exterior and interior styling. Still see a few of the original Mini's running around town.
    Would you let go of your Focus for a new MINI?
    most likely yes. I prefer 5-door hatches though. Even so, I was still tempted to say "screw the extra doors" and buy a MINI if I liked it, but alas, no authorized dealer here. There is a local import dealer that was selling them, but the thought of driving to Kansas City for warranty work/recalls seemed ridiculous!
    Really If I could let go of the extra doors, it would have been between a Golf GTi, Mini Cooper S, and a SVT Focus.
    Also, all of this would be dependent on what price I could actually get a MINI out the door for. Seems like the actual selling prices are all over the map for some people.
  • tonewheeltonewheel Member Posts: 47
    Just ordered the wife a new Copper with delivery in October.
    I'd be interested in some opinions concerning the recommended oil change schedule. Mini's come with synthetic oil from the factory (recommended for regular use), and the first recommended change is at 10,000 miles. Every 15,000 miles thereafter. WTF? I maintain our cars myself, including oil changes (always synthetic), and go 5,000 miles between changes.
    Thoughts? Comments? I can't understand such a long schedule. Don't tell me these engines don't create acids, sludge, particulate and dirt over time.
    The Mini has been developed by the engineering geniuses at BMW which in its own cars advises oil changes at 15,000 mile intervals. Believe me, engines are built better than well enough to withstand 15,000 oil change intervals (especially with synthetics).
    Also, I know you chnage your own oil, but Free Scheduled Maintenance is included with the Mini for the forst 3 years/36,000 miles.
    Thanks for the info. And yes, I thought the included scheduled maintenance was a real bonus. (I can't get under the MINI anyway! Zero clearance!)
  • milwaukeeboymilwaukeeboy Member Posts: 19
    hi all,
    random thoughts and questions on the following:
    status of my mini - my s got built on 8/2 but it still is listed as awaiting transport (seems like dif's car slipped on the boat in front of me). oh well...
    roof rack - has anyone seen one? does anyone have one? how much is your dealer charging (it is a dealer installed option).
    toggle switches - what is the third switch from the right for? i've never seen it populated.
    flag over sunroof - has anyone seen this? i heard it can be done.
    oil - is that really included in scheduled maintenance? that sounds too good to be true.
    motor on dudes and dudettes :-)
    mb
    The oil change interval is long, that's for sure. It supposedly takes your driving into account but I rev fairly high (including accidentally going to 7250RPM in 2nd gear today while merging onto the freeway when a truck tried to occupy the same space as me, still didn't hit the rev limiter somehow) and at over 5500km it still says I have over 10000km to go before my first oil change.
    DO CHECK YOUR OIL LEVEL THOUGH! At first my car used/consumed no oil at all but when I checked it before I filled up on gas this morning it was right between MAX and MIN on the stick. They say to add 1L of 100% synthetic when it is right above the MIN line so I'll be checking my oil at every gas filling and perhaps sooner. So while the interval is quite long it seems like I'll definitely need to add a little oil before the first change (at this rate, I'll need to add 1.0L before the first change). In Canada the maintenence is not included for some reason.
    Coolant and brake fluid were both between MIN and MAX which is fine (car had only gone a few km before checking and coolant is usually near MIN when still cold).
    The always-missing (in north america at least) toggle switch is for rear fog lights which are illegal in USA and Canada but mandatory in the UK and optional or mandatory in other locations. The MINI is a true world car with what appear to be funny features to us on this side of the pond here and there.
    Just to let you know, rear fog lights are not illegal in this country. My mom's 01 Audi A4 has them, as do Saabs, Volvos, and Mercedes. I guess they just decided to not offer the rear fog lights on the Mini.
    If I'm not mistaken, both front and rear fog lights come with the sport package.
    And I don't know if they are legal in Canada, or Ontario at least. Never seen rear fogs though it sounds like they are just an extra set of red lights, kind of like brighter running lights or something so I don't know what the big deal is about them possibly being illegal.
    Harry
    I just have to share this: Yesterday, my wife and I took the MC to Lowe's to pick up some stuff for our house. On the way home, the Cooper had: two adults, eight 8' lengths of chair rail, one large box containing a new miter saw (now my second favorite toy behind the MC), and three plastic bags containing various nails, wood putty, etc. The tail gate closed without a fight and we drove off. We got some interesting looks while loading the car in the parking lot, but I'm not sure if they were the standard "that's one of those new Coopers" looks, or if they were the "I can't believe they got all that stuff in the back of that MINI." As miniusa says, "the SUV backlash starts now."
    You got the 8' lengths of chair rail to fit inside the MINI? Is there 8' from the windshield to the closed rear hatch??? Or do they make flexible chair rail that can be rolled up now :-)
    The local Mini dealer had ordered an August-build '02 model with heated seats but left off the heated mirrors and nozzle, which is only $30 more with the cold weather package. I was going to get that '02 car and retro fit those items, but the service guy said it would cost $550 for the heated mirrors and he wasn't sure about the heated nozzles. Since that was several hundred dollars for a $30 upgrade, he suggested just ordering another car, so I decided to hold out for an '03 model, which should be here by mid-Nov, and will get British racing green with white top and white bonnet stripes, along with the premium package, cold weather package, fog lights, DSC, and leather seats for the Mini S. The price increase for the '03 is just $125 so it made a lot of sense. I've been completely satisfied the WRX wagon that it will be replacing and definitely don't mind driving the WRX for a couple more months.
    If the Mini proves anywhere near as reliable as that little Subie, I'll be a very happy camper even though driving this winter might require a little more care. To be honest, I didn't notice that much difference in power in the Mini S while driving in the midrange, although it's somewhat slower from a dead stop.
    The Mini S has a very tall 1st gear (nearly 44 mph compared to 35 mph with the WRX) and that makes a big difference in the 0-60 perfomance times. Not being an adolescent stoplight racer, I actually preferred the taller 1st gear and despised the 1-2 shift on my former Audi S4, where you'd go through 1st gear in an eye blink and immediately need to shift to 2nd. That's great for 0-60 times, but it's a major pain in the butt for everyday drivability, especially with the very clunky gearbox of the Audi, which was admittedly improved with an aftermarket short shifter. The WRX with the factory STi shifter was much better than the modded S4, but it's not nearly as refined as the stock Mini S gearbox which is exceptionally smooth and precise but with a tad longer throw (no big deal).
    What really sold me on the Mini S was the substantial "big car" feel in such a tight handling package, and the power is more than adequate for the way I typically drive (i.e., in the midrange), and the power delivery is very linear, a big plus. There will always be faster cars, but my priorities are balance, refinement, luxury, and overall fun factor. Legroom for rear passengers is way down on my list, so the Mini S might be the ideal second car for me, especially since it has a lot of utility with the back seats folded down.
    Another big plus of the Mini S is the possibility of the John Cooper Works upgrade, which is supposed to be available next year as a dealer-installed option with the full factory warranty. It won't be cheap (probably about $4500) but will give you about 200 bhp and more torque, from a ported and polished head, upgraded supercharger, exhaust, and ECM. My impression is that the Mini S can easily handle that extra power with the stock suspension, but I'll wait to see if torque steer becomes a problem, since there is no limited slip differential. I'll probably spring for this kit, but not if that means upsetting the car's wonderful balance and drivability. ;)
  • oballeanioballeani Member Posts: 4
    I am considering to purchase the Cooper. However, since I live in Montreal and have to deal with its winters, I am a bit worried about the Mini's handling in the snow. Although everyone says it handles extremely well, can it handle snow/ice covered roads and highways ? What about its ground clearance, can that be a problem ? I am aware that the car was released in the spring, but does anyone have any experience with it in the melting snow at least ?
    Thanks for your opinion.
    Oliver
    I got my MINI Cooper at the end of April and by some fluke of nature we got 3 snowstorms in the first couple of weeks. It had 195/55R16 Goodyear Eagle NCT5 summer tires on it (not recommended for winter driving) and yet it still did fine in 1-2" of snow. The ABS did come on once or twice when coming to complete stops but nothing exciting. Hills were fine, traction control didn't kick in when accelerating normally. Even though it did alright in those little snowstorms with summer tires I plan on getting some steel 15" rims with 175/65R15 or 185/65R15 winter tires before the end of the year. I think it will be a good winter car.
    The minimum ground clearance is 5" with 195/55R16 or 185/65R15 tires. This is a bit lower than your average car with about 6" of clearance but not by much -- you'll have to decide if 1" less is a problem.
    I have more experience in rain when the All-season Stability Control + Traction, Anti-lock Braking System, Electronic Brake-force Distribution, Corner Braking Control and overall car characteristics have shown themselves to be very good in poor weather. With all the electronics it is a very well behaved car even in overly spirited driving. I don't drive fast in bad weather all the time but the help is good for that first corner under poor road conditions where I sometimes forget to be more cautious at first.
    You won't have to spend $4,500 to get 200 HP out of an S. An ECU upgrade and underpully for the supercharger should take it to 200. Boosted engines (supercharged or turbo) are really cheap to get significant HP upgrades from. I have a 2002 GTI 1.8t that I've modified from 180 HP to 235 that cost all of $1,100 - ECU upgrade (www.goapr.com), minor turbo intake upgrades (Neuspeed) and a low restriction exhaust (Eurosport). Torque steer is not an issue on my GTI.
    It looks like a lot of the aftermarket companies that modify VW's are getting into the MINI performance aftermarket as well.
    You are probably looking at close to 300 HP with the $4,500 in upgrades on the S you outline above - larger supercharger etc, etc. I doubt a ported and polished head will be a value add on an S - that upgrade is for a regular MINI.
    re: mods
    The JCW kit is supposed to retain full factory warranty and be street legal. With aftermarket mods, you take your chances. Buyer's choice. ;)
    re: ground clearance
    After some research, I found the Mini has 4.5" and the Mini S has 4.8" which should be enough for reasonable winter driving. My S4 had 3.5" and still did fine over 2 winters in upstate NY although it did have AWD. Still, I think the Mini with FWD and a lot of weight on the front should do fine. It better! It's replacing the WRX wagon as my winter driver. ;)
    PS: I agree with rickrover about the benefits of a chip / exhaust on turbo cars. The S4 had those mods and it made a *huge* difference.
  • minimike2minimike2 Member Posts: 50
    I was very, very impressed with my Mini S test drive. But, now I'm thinking back that the salesperson had the air conditioner off the whole time...
    Hmm, I gotta go back for another test drive now huh? sheesh...
    As the compressor doesn't have much to do when it isn't hot. I tried it in April but it didn't have any effect. When the temps are in the 90's (high 30's Celcius) then you'll notice the effect right when you're starting out. Just give it some gas and you'll be fine. Once you get going you don't notice it too much, just when rolling from a dead stop will you need to take it into account.
  • 5port5port Member Posts: 395
    I dont own a Mini but I thought you guys should read this : BMW Chairman Helmut Panke
    Panke also said consumers should expect more derivatives from Mini, suggesting a soft-top model is a strong possibility. Panel van-like Clubsport models are also expected.
    " Mini as a brand will not and cannot rely on just one body style," he said. We'll do what we have done , for example, within BMW and bring out step-by-step additional models to make it a full brand there."
    Make one please!!! A Mini convertible would be an awesome replacement for the VW Cabrio (the New Beetle convertible just isn't the same). Just keep it a 4 seater with a decent sized trunk please! I would buy one for sure.
