Mazda Protege5
Has anybody found winter tires that would fit on the factory rims at a reasonable price?
I'm not sure if the P5 can go down to 14 inch rims. Currently the P5 has 16 inch tires and rims. I know you can go -1 size ok, but I'm not sure if you can go -2, which is what you'd be doing if you tried to go w/ 14 inch rims.
My '01 LX 2.0 had 15 inch tires and I can go from P195/55/15 to P185/65/14, making only a negligible
difference in odometer reading.
Have you looked at Michelin Arctic Alpins? They are going to be my choice for this winter. The prices I've been getting are about $520 w/out rims. So w/ rims they would be about $700 CDN.
If you want to check out what different tire sizes will be like, goto this page:
http://www.miata.net/garage/tirecalc.html
Pro Fan
-juice
- wheel circumference (in mm)=pi*(r*25.4+w*p/50); (1889.4mm for the above example)
- Rev/mile=1.6e6/wheel circumference (846.9 for the above example)
Bruno
23mpg seems indeed low. My Hwy/St driving balance is pretty much like yours, and I use AC too, but I end up about 28.5mpg. I don't think the type of transmission (I have a manual) and gently hilly road in Austin (Houston is flatter) could explain the difference of 5mpg. I use 89 (R+M)/2 grade gas, but it shouldn't make any difference either.
BTW, I don't understand the 2th row of your spread sheet:
the distance should be 1031-804=227 miles, but you have 196 miles instead. What's wrong?
Bruno
It would probably reduce wind noise though, especially if you have a moonroof.
-juice
4 new steel wheels and 4, 195/55QR-15 Michelin Arctic-Alpins
$514. USD shipped from Indiana to VT. Perfect fit.
Also, driving conditions do vary ALOT -- traffic, hills/flat roads, elevation, temperature, driving habits, AC (on/off)....
That's why i'm not surprised to see 5 MPG differences at all. And yes, automatics do consume more fuel.
If you do it only once, there can be plenty of error, but if you keep a chart and do it repeatedly, that error becomes insignificant.
Also, to calculate a true average, add up all the miles, divide by all the gallons used, to get a weighted average. Do not average your averages.
Why? Well, let's say you drive 400 miles in the city, and get 20mpg using 20 gallons. Then you drive a 40 mile trip, and get 40mpg on 1 gallon, but refill early. So you average 30mpg, right?
Wrong. You drove 440 miles and used 21 gallons, for a true weighted average of 20.95 mpg. The 30mpg average of averages is grossly incorrect.
If you fill up your tank at about the same mileage every time (say, 300 miles), then the effect is smaller.
-juice
PF
-juice
Then I divide the number of miles I've gone "on that tank" by the amount of gas I put in. I do this with every fillup and so far it has been between 28-31 MPG. Pretty consistant.
You can use the history to help spot maintenance or other issues, as well as satisfying your curiosity. I actually figured out someone was siphoning fuel out of my 323 in the parking lot at work. I noticed a dip of 3-4mpg and got a locking gas cap. My economy magically returned to normal.
You can also spot when gas stations over-report (as in cheating you out of fuel) how much fuel they sell you when you consistently get 3-4mpg better at a particular station. I think that one station I complained about a few months ago got busted because my calculations when I fill up there have been consistent with other stations for a while now. Of course, they did get new owners about that time....
Bruno
Does anybody know about it?
It should run you about $220
It looks ok...I think the tip is a bit fat for the stock cut-out.
I think modern day electronics controlled engines just won't knock. Ignition will be retarded when the knock sensors detect it.
The computer will try to adjust air-fuel ratios and firing timings based on octane!
So STICK TO REGULAR which is 85/86 in the Mountain West because of the altitude (you're right elec3), and 87/88 elsewhere.
It is part of the accessory list from Mazda, along with bumper protector and other things. It is supposed to be at least the muffler but my dealer soes not have any more info than that.
BTW, iamz mentioned earlier about how to lower the "mids" on P5 stereo, it really works ppl. Please try it and your sound system will sound better.
Our seetings:
Bass : almost all the way up
Mids : 1/3
Trebele : all the way up
zoom-zoom
That is not my real problem though. I am dissapointed to find that most of my CD's skip tooo much in the stock stero. I have never seen(heard) anything like this before, and I have driven almost every manaufactures 2001 car and tried their stock cd-players. This is by far the worst.
Has anyone else noticed this?
http://hometown.aol.com/audia8q/myhomepage/business.html
rich
Revka
Hatchbacks / Station Wagons / Women's Auto Center Boards
Sorry. Wasn't online in a while. That picture is of an german 323f (our protege5) interior. I have no idea if its a NAV, DVD or something else, but I am trying to establish connections with germany so I can buy one of those for my protege5. Looks very nice and much nicer than those slide out LCD units they sell here.
This is mostly highway speed (70-75mph)and city driving (50-60mph) but i am also stuck in traffic each day for about an hour. I was expecting more like 28-30 mpg so i am not too impressed. Sound system for me is fine really. I turned down bass to 50% because i don't want to have to remove door panels to change blown speakers. I do have an jensen amp from my mustang but don't want to install it yet, as i also need the capacitor ($100) + box ($70) + sub ($80) + installation ($40) + install kit ($60) and that's a lot of mula. I also don't want anybody to drill holes in my firewall as that is so dumb. If they can't find an existing hole through which to run power wires i won't be getting it installed.
Mazda has came out with sport exhaust as some of you have posted and all the dealers in south florida don't even know if its just the muffler or the whole cat-back system. What kind of bs is that. who else is supposed to know if they don't. Zoom-zoom stickers are quite a rarity here know. My protege club picked up a few at the miami auto show. I have seen them in silver, white and red. I have placed a white one on my strut tower brace in the engine compartment. looks very nice. i can't wait for a turbo to come out. If it add something like 50-60hp (with 5-6lb of boost) that would be great. A lot of civics and even toyotas here run turbos now. checking out corksport.com now and their prices are almost outrageous.
But i think the player could be a bit over sensitive... the CDRs that i have recorded plays without a hitch in all my other CD players at home.
Rich
Check out the Pro Sedans board and Winter Tire board under main Accessories topic.
Any thoughts?
i don't remember seeing leather seats as options...
Re: the stereo
I haven't really had any skipping problems. I had a store-bought CD skip once when I hit a large and unseen bump. I haven't had any problems with CD-Rs though I did try burning a CD-RW last night just to see how it would play (I didn't realize the stereo would do RWs). It works but it seems like the seek times are longer and a couple times it wouldn't even find the RW, it spit it back out and said CHECK CD. It seems like the unit supports CD-RW almost as an afterthought and not from the ground up.
As a headphone audiophile, I was a bit skeptical about the advice to turn your midrange most of the way down. In hi-fi headphones, midrange is very important to the overall sound because it is where voices and many instruments live. On a good pair of headphones, having insufficient mids will give you dark, distant, and flat sound. It seems that the Pro5 stereo doesn't work that way though
Also allow me to ask one more time for those who believe that the computer adjusts the air-fuel ratio and spark timing with respect to the minimal required octance (other than when the knock-sensor detects knocking), please provide reading references. I never heard such thing.
Bruno
Mine doesn't have the changer and it is quite sensitive to skips. Normal driving is no problem, but any kind of change in surface or roadwork will cause skips.
