Mazda Protege5
1) Window rattle when not closed all the way. Not much to do here. Either open it more or close it. I note the same rattle in my sedan. I think it's the loose edge of the window glass hitting against the trim on the door on either side of the glass. If it really bugs you, you can attempt to apply some caulk or foam tape under the metal clips that hold these trim pieces in place.
2) 6x8 or 5x7 (with a hole pattern that also fits 6x8) up front. Here are a few sites about speaker replacement in the P5:
www.protege5online.com/Tech_Help/Audio/ [break to bypass the 115-letter limit] Speakers/speakers.html
http://byrneweb.com/sunburn/newcar/install.html
www.astolfo.com/p5/p5.asp
To put anything else but round speakers in the rear doors would mean cutting away metal (not recommended as this would weaken them in side impacts), unless you pick speakers that are tiny enough so that you have to add metal to mount them.
I have't had a problem because of it sliding around, but plunking it down on a Natural Aire foam airconditioning filter (Wal-Mart) will anchor it nicely.
1. I've seen pics here of P5 withoutroof rack but also without inserts (seems as though the guy who did this just used tape a glue to plug the holes -- not to my taste). Does anyone have pics of P5 with inserts as provided by Mazda?
2. Will I notice that much of an increase in acceleration/power from the 1.8L to the 2.0L? (Was interested to read a posting here about someone who had both a 2000 ES and a new P5.)
3. Just read Consumer Reports article on the P5 class of vehicles. Very confusing/frustrating. CR puts the P5 down the list, yet when the ones above it in the rates are examined P5's competition always fall short, whether it's reliability, mileage, warranty or fit 'n finish. CR's big beef seems to be noise and stiffness of ride, which finally brings me to my question: Is the ride all that different between the ES and the P5. Is the P5 all that much stiffer? I don't quite understand the suspension differences between the ES and the Pro5. (Were there changes made in suspension between the 2000ES and the 2002ES?) Secondly, I've never thought the road noise in my ES was all that great and I have OEM tires. Can't imagine how much quieter replacing my tires with those recommended on this board would be. Is cabin noise more pronounced due to a unified cabin in the Pro5 (even with a cargo cover) versus a separate truck in the ES? Your ideas on noise and ride in general would be appreciated. By the way, I have test driven a P5 and loved it, but when you're psyched about a first drive you miss things.
4. Has anyone used a roofrack on an ES? I have one which I used on my old 92 Pro but am a bit reluctant to use it on my "pristine" 2000. Don't want any scratches.
Thanks again for any input... looking forward to contributing more.
The burning river mobilized the nation and the flaming Cuyahoga River became a rallying point for passage of the Clean Water Act. I was just a kid, when I lived in the Cleveland Heights section of Cleveland from 1968 thru 1971. I will always remember my dad taking me down to where the Cuyahoga merged with Lake Erie! A lot of dead Yellow Perch and Carp. At the time, there was a very popular T.V. commercial, a native American Indian in full dress surveyed the site of a polluted landscape and cried at the mess. Everywhere you went, people wore Ecology Now T-shirts. As you know, Lake Erie is vastly cleaner in the year 2002, however I've heard the Cuyahoga River is reverting to a badly polluted sewer? Jeeze,....to bad for Cleveland.
-old head
There is more wind noise in the P5, but most of that is because of the roof rack. I don't hear a difference in road noise, but I'm not very sensitive to road noise.
"I also don't have to try my remote on every car in the WalMart parking lot to figure out which one is mine because it looks exactly like the other 5000 cars parked there. I just look for the best looking car on the lot, start it and drive off."
Sedan has a stiffer rear end (because the speaker deck is a brace for the two rear strut towers, whereas there isn't anyplace to put one in the P5).
P5 comes with a front strut tower brace.
P5 comes with MP3 body clad-ons (front bumper & fogs, side sills).
P5 antenna is a flexible whip (removable for when you go through an automatic car wash -- I wouldn't) while sedan's is a manual pull-out.
P5 2002.5 has side marker lights on the front fenders.
P5 rear speakers are in the rear doors and are round v. elliptical.
P5 rear doors have small map pockets (still no cupholders).
P5 has more rear head-room.
P5 rear outboard seats have adjustable headrests.
P5 is shorter by 3-4 inches (to minimize effect of more sheet-metal in the rear on handling). Great for anyone with lots of junk in their garage.
Since the P5's cargo area is more open to the cabin, you'll hear more road noise from the back. All hatches and wagons are like this versus their sedan brethren.
2.0L v. 1.8L. I don't think you'll note any real difference in 0-whatever times. If anything, the P5 will be slower due to its additional weight (more sheetmetal and bracing for the wagon shape...I think about 200lb). The consensus seems to be that the 2.0L makes more torque down low for faster starts in daily local driving, but seems to run out of power at a lower RPM than the 1.8L. The 2.0 is harsher-sounding at elevated RPMs (think 5000 and up) than the 1.8L. Economy seems to be the same.
I use a roof-rack on my '99LX. I take it off when I'm not using it to avoid the wind noise and the hit on my economy (I notice a loss of about 2mpg with it on, even with the fairing). It also minimizes scratching due to dirt accumulating where the rack contacts the car. Since the rack clips onto the door frame, your door weather seals are also compromised when the rack is mounted. This leads to additional wind noise and water seeping in between the doors and the door frames.
Once your rack is "tailored" to your ES, it should take only a few minutes to remount it. It takes 2 minutes to remove my roof rack (Mondial) and about 10 (inlcluding cleaning) to remount it. The hardest part is putting it in or taking it out of its storage spot in my utility room.
Also, before I mount the rack, I carefully clean off both the rack fairing weatherstripping, footpads and clips and the areas on my Pro where the rack touches to avoid trapping grit.
I was at a bbq yesterday and my friend who was hosting it just bought a Pontiac Vibe. I took a good look at it inside and out, and it is very impressive. I had rented a P5 in southern California a couple of weeks ago and loved it, but the Vibe seems more solidly built. Was the Vibe at or near the top of the list in Consumer Reports?
What other hatchbacks were listed? I really want a hatchback, but don't want to jump in too quick until I compare them all.
http://www.caranddriver.com/xp/Caranddriver/comparisontests/2002/june/200206_comparo_boxes.xml
If you're a driver first and a general consumer second, read the C&D review. The P5 has the best driving experience and if that's what you care about, well, that's what C&D cares about, so that's the most appropriate review.
If you're a general consumer first and a driver second, read the CR review.
Having driven the Matrix XRS, the Focus ZX5, and owning a P5, I have to agree with C&D, of course. :-)
Has anyone heard if Honda or Nissan is going to come out with a hatchback?
To tie this into the topic, I don't think the 5-door Civic would steal many sales for the Pro 5. Two different buyers.
With respect to Consumer Reports, can anyone with access tell us what is says, at least the main points?
You can see the trend: CR ranked the cars based roughly on how much they had the characteristics of an SUV. Specifically, big interiors, bigengines, soft quiet rides, high-up seating, and cargo area were more important than handling, reliability, and gas mileage! Times have changed for CR apparently.
Despite it having both the best reliability (often by far) AND the best tested gas mileage (the Matrix got less!) of the group, Consumer Reports knocks the P5 down because the ride is too stiff and because it has the seating position of a regular car rather than an SUV. Odd. Because those are two of my favorite features of the car.
CR liked the Jetta Wagon best, despite its mediocre reliability and transmission. As for the Ford, CR a while back rated Focus models highly, only to discover later that they have absolutely dismal reliability. What's funny is that CR haven't owned up to their mistake yet. They are STILL top-rating the Focus highly despite the killer reliability problems. They actually rated the Focus higher than the Protege5, even though they're on the opposite *extremes* of CR's reliability rankings.
The real fight is between the Matrix and the Protege5. Matrix gets slightly better: transmission, rear seat comfort, controls, and better: ride and tall-person access (. The Protege5 gets slightly better reliability and emergency handling. Odd that CR specifically noted the problems with the Matrix's driving position and rear seat visibility but didn't mark the car down for it. Yet it was the Matrix's upright driving position, tiny rear window, and loose handling that led me to pick the Protege5 over the Matrix in the first. That and the fact that the Matrix is hideously ugly, though that was a minor nitpick.
Talking points:
Jetta Wagon
Hi: ride, quietness, fit and finish, turning circle, safety, cargo room
Lo: power delivering, rear seat room, premium fuel, fussy to fold rear seat
Matrix
Vibe
Hi: interior flexibility, access, rear seat room, transmission, availability of all-wheel drive
Lo: noisy engine, awkward driving position, rear seat visibility
Focus CX-5
Hi: handling, ride, offset crash results,
Lo: reliability, noise, luggage space
Protege5
Hi: handling, breaking
Lo: ride, noise, access
Impreza Outback Sport
Hi: AWD, Offset crash results
Lo: ride, fuel economy, cargo volume, break pedal feel
Ratings:
4=excellent 3=very good 2=good 1=fair 0=poor. The Vibe gets marked the same as the Matrix except as noted.
Jetta Matrix/Vibe Focus CX-5 Protege5 Impreza
Acceleration 3 2 2 2 2
Transmission 1 4 3 3 3
Routine Handling 3 3 4 3 3
Emergency Handling 3 2 3 3 2
Braking 4 4 4 4 3
Ride 3 3/2 3 1 2
Ride (Full) 3 3/2 3 1 2
Noise 3 2 2 2 2
Driving Position 3 2 3 3 3
Front Seat 3 3 3 3 3
Rear Seat 1 3 2 2 2
Access 3 4 3 2 2
Controls 3 4 4 3 3
Fit and Finish 4 3 2 3 3
Cargo Area 2 1 0 1 0
Reliability 2 3 0 4 3
Mileage 23 24 24 25 22
FYI, Reliability is not factored into the C.R. "overall score" for a car. The reliability >does< affect whether a car gets a "recommended" check mark. Look at the list and you'll see that even though the Foci are quite high up the list they don't get the check marks because they are unreliable.
In general, I think you are correct in noting that CR likes "family friendly" features like high seating positions, soft and quiet rides etc. They definitely don't care much for enthusiast cars, unless it's specifically a sports car review (a rare occurrence).
I prefer to read the full report and take the overall rating with a pinch of salt. The full report contains good information that allows me to draw my own conclusions based on my own preferences, ignoring CR's "family" bias. If you like the firm ride of the P5 then that's great, CR has confirmed that the P5 has what you want!
At least their physical measurements of cargo space are done in a consistent manner, resulting in figures that make more sense than those given my manufacturers. Unfortunately for Mazda, they seem to have stuck to their ethics and quoted figures for cargo stacked up to the lower sills of the windows while everyone else seems to have derived their numbers by stuffing their vehicles up to the roof. You'll note that the actual cargo volume of the P5 is quite close to that of the Matrix/Vibe. Also note the difference between the figures for the cargo floor length to back of front v. rear seats. This indicates the relative space in the rear seats. The CR-V has a delta of 19in (cramped), the P5 has one of 25. I think only the PT Cruiser has a figure that's significantly higher.
Anyway, CR has their bias. So does every other reviewer. Just read a bunch and find ones that best match your priorities. CR reflects more realistic cargo and turning circle values, and give a good indication of projected reliability. Their mpg figures tend to be higher than more auto-oriented mags since they don't seem to push them as hard. I look to CR for value, reliability, physical measurements, C&D for sound measurements, fun-to-drive quotient and driver-oriented things like comfort and ergonomics, Automobile for most of the same as C&D, with more of a view towards design.
What are you concerned about? Handling? Starting up in cold mornings? My Pro handled great. Also, I've seen a lot of P5's running around up here in Calgary and they all seem to get around with no troubles either.
My Pro only had the Potenza's and those did fine for most of the winter, but you could really tell when there was ice on the ground. Traction was almost nil.
I can't say for the stock tires on the P5 though. Anybody else?
I ran those tires last winter with great results. Amazing traction, and no drama. The whole thing cost about $550 from Tirerack, delivered to my door. I do the change over myself too.
Just make sure to put a bit of litheum grease on the steel hub as they rust up to the hub a bit over the winter.
>previous VW and it was unstoppable in snow.
I would say that being "unstoppable in snow" is a bad attribute for winter tires ;-)
Do they look like they might go 40K or more, or are they more like the 25K tires that so many cars come equipped with (Bridgestone Potenza was one such tire in my experience)?
Also, what do people think of the unusual tire size used on the P5? Tirerack.com shows only 6 choices, ntb.com shows none, discounttire.com shows one but it's not stocked in my area. Has anyone had trouble getting tires? I wouldn't want to have to drive for several days on the emergency spare waiting for a replacement to arrive, should I have a flat.
All this is hypothetical, mind you, as I don't own a P5 (yet).
I believe you can go up to a 205/45-16 if you want. Slightly wider, but the sidewall is an identical height (3.8").
Tire Size Calculator --> http://www.miata.net/garage/tirecalc.html
LOVE it. 11000 trouble free miles. Hwy mileage with a/c on, 3 passengers, and going 80 on the interstate - 30.2!
Handling - amazing. Had a 98 GS-R and I dare say it handles just as well.
Noise - I don't know what all these reviewers (CR) are talking about - I don't find any excessive noise. (I do have my roof rack off, with the factory inserts.)
Have had many comments on my car. Has tinted windows and magnetic bra.
Matrix/Vibe - I think they're ugly (my opinion), they are like mini-minivans - i sat in one and that's the exact impression me and my friend had. Also, the interior trim is WAY too cheesy for me (those bright chrome inserts - ugh). The "chair" (as I like to call it for this car) - feels just like that - too high. And the car -- it must be a foot taller than the P5 (?) - no likey.
Demographics - completely by observation - every Matrix/Vibe I've seen on the road is driven by "older" folk (I dunno - 40++). The P5 on the other hand - All 20-30 somethings - wave at each other (hey, is this a jeep thing?). Way cool. Toyota's average age is not getting any younger with this car - as was their plan.
Dealer service (Morries Mazda in Mpls) - Great! fast, clean, new, car wash too.
Love the car!!
I bought my new P5 last week. Some comments for those thinking of buying one -
Note the Consumer Reports review was comparing some larger vehicles - wasn't the RAV4 in the mix? Anyway, their emphasis was different. It is like reading CR for hotels. If it doesn't have 1500 sq ft and a heated pool, it rates lower. Their preferences may not be yours.
CR did say that the suspension was stiff, and they're right. Give them credit for calling it like it is. If you are in a town with really lousy roads, it may bother you. The upside is terrific handling. Every time I bend the car into a turn I appreciate how great the handling is. Motor Trend talks about the P5's "extremely well-engineered suspension package", and they're not kidding.
Other comments: highway ride is very good. The engine drones on a bit at 75 mph. At times I don't notice it, and probably wouldn't when using the stereo. Exterior look is distinctive, which is great. Interior is nicely done - detail work that you wouldn't expect at this price (lighted ignition key spot in my car; map lights that work; etc). Headroom: I'm 6'2", and with the moonroof I still have tons of headroom.
Car and Driver said the car was a sports car in station-wagon clothes. They're pretty discriminating reviewers. I neglected their opinion once before (bought a Civic), and regretted it. My usual rule is to find a car that CR likes (for reliability) but which C&D also likes (for driving impressions).
I believe C&D also complained about engine vibration - perhaps at idle. I have no idea what that is about, because my new (mid-cycle refresh, or "2002.5") car is very quiet at idle. No problem. Feels more expensive.
Highway wind noise is there; I could probably remove it by removing the cross bars. I'm still debating. It isn't troubling, but after a sustained run at 85 mph I may feel differently. I hear removing the rack (crossbars, or whole thing) is quite easy.
Matrix etc: CR liked it, but C&D really didn't. Particularly in 180 hp trim, C&D talked about an engine that didn't show up for work until 6000 rpm. The Matrix has higher HP but lower torque, and a torque peak Much higher than the P5 (P5: 135 peak at 4000 rpm; 180hp matrix/vibe: 130 at 6800 rpm). That means you have to rev the heck out of the matrix/vibe to get the power. I think that would be tedious. Some have said the 2.0L engine in the protege/P5 is less rev-happy than the 1.8. I find the around-town performance to be very good (I was also considering a Passat). There is no reason to rev to 6000 rpm, it is true.
I was also looking at (and could afford) the Passat, Impreza 2.5TS, Impreza WRX, and Altima, so it isn't like I couldn't buy "more" car. I ruled out the Jetta for reliability reasons (love the interior of that car though). For $17.5 the P5 is a steal (that was 500 over invoice; add tax etc). Buy one and appreciate what a great car it would be at $1000 more than that.
The shifter is smoother than my '99 Civic. Really.
Suggested driving test:
1) Drive on the lousiest road you can find near the dealer. This is confirming whether you can live with a tight suspension.
2) Drive through a favorite on/offramp or turn when no one is around to slow you down. This will make a great counterpoint to (1).
3) Turn it on and leave the fan, stereo etc off and sit in it at idle. Muffle the salesperson; notice how quiet the car can be.
4) Run it at 70-80 on the highway with fans/stereo off to get a feel for what long trips would be like.
Reviews you should read:
Consumer Reports
Car and Driver (link given above)
Automotive.com : http://www.automotive.com/reviews/2002/Mazda/2002_Mazda_Protege5.html
Road and Track (has sidebar on P5):
road and track
Motor Trend:
http://www.motortrend.com/may02/wagon/1.html
Brian
I haver not been able to find an answer to a question I have about the sport automatic transmission. If you are driving at 50 to 65 mph and need to shift to a lower gear because climbing or descending a steep grade in the mountains, can it be shifted from D to M? Will it go into either third or fourth depending on which gear it was in when it is changed to M? Thanks
Basically, it won't let you do anything bad, and will let you redline the engine, if you want to. Takes about 1s for it to shift after you twitch the shifter.
Since it's all electronically controlled, you can go from D to M and back anytime. M is basically a shift-and-hold unless it thinks you're being silly mechanism.
All in all most cars generally handle much better if properly lowered with a combination of adjustable struts (to control the firmness) and
a good set of aftermarket springs. The cars usually IMO look better too when you eliminate the wheel well gap.
One thing to remember though in doing this is that your ride will become significantly harsher. Bumps you used to glide over may become quite jarring.
I lowered my already low MR2 Turbo about 1.5 inches using tockico adjustable struts and H&R springs. I also put on 17 inch rims and the ride became VERY firm. So firm in fact that after about 4 years I outgrew it and recently sold the car. If you happen to have bad roads where you live I'd avoid messing with the suspension much.
-Finn
zoom-zoom
Bruno
Thanks for the excellent overview of your P5. I'm still shopping around, and I'm also considering the same lineup of cars you did. After my two test drives, I agree with you down the line.
The only place I feel the P5 can't compete with a car like the Passat is in terms of safety. I'm sure the P5 is fine, but the bigger, heavier Passat and its multiple air bags does seem to do a better job of protection. But beyond that, I could feel very good about a P5 purchase (and the money I would save).
I may try to hold out and get an entry-level Mazda 6 this fall...but who knows how long I'd actually have to wait...
Anyway, thanks again for the review and links. I'll hope you keep us posted on your impressions of the car in the future.
-larry
Incidentally, I saw your name on the dry-erase board at Grinder's in Grandview a couple days ago.
Coincidentally, I also have that car in my garage in Gran Turismo 2, a yellow one!!!
I finally broke down and ordered the cargo tray. I'm excited for it to arrive tomorrow.
