I thought about it being the roof rails, but I am not so sure. The whistle happens usually no slower than 60mph, but always happens once I reach 75-80.
You could check with local shops to see if they have a weatherstripping leak detector. I think some use an ultrasonic emitter inside your vehicle and you move a microphone around the door and other openings to detect leaks.
I think it's just the resonance threshold. Other factors may come into play but I think it's the biggest one.
Thanks again!
I was going to go screaming back to my dealer about the windshield install. I've been listening very closely since the new windshield was put in a couple of months ago, and was quite dismayed at the noise I heard starting at exactly 58 mph.
Don't get up that high very often (LOTS of speed traps on my commute), so it's possible I just never noticed it before. Also rarely get to go above 70, so not sure if it goes away...I'll try this weekend when I head out to the burbs.
P.S. to everyone else...I have a sedan, sorry to interrupt...as you were.
I'm new to this forum and really enjoyed all the discussion. I had my P5 for nearly 10 months now and am very happy with it except for the fuel economy. I do mixed driving and get an avg of 22-23 mpg. The sticker shows 25 city and 30 highway so I expected the mpg to be around 27. (does anybody get this?) One theory I have is that the manufacturer initially puts in a higher viscosity oil for the breaking in period. Perhaps going to 5w-30 or 10w-30 afterward would mark some improvement? Others have suggested increasing the tire pressure which I'll certainly try. Would the roof rack cause a significant drag to affect fuel economy? I like to consider some self fixes before bringing my car to the dealer.
Try taking off the rack and see what you get.
Or you could always try for a tail wind.
Some "summer" blends do have less energy content, which decreases your economy as well. For example, ethanol and other oxygenating additives just don't pack as much punch as gasoline.
Other easy things to check/change: oil, oil filter, tire inflation pressures, wheel alignment, air filter, spark plugs. I notice an improvement in economy of 1-2mpg after I change my oil & oil filter. I get a small trend increase after I change the air filter, but it's small. I guess I never let my air filter get too dirty.
Bruno, 70% Hwy (80mph), 30% City, Manual P5.
My mix is about 70/30 local/freeway and I can get 29mpg to 24mpg, depending on how friskily I drive.
Some times I am ashamed to be a Californian; other times I watch the weather reports around the world.
Bruno
Every time I have taken it in to the dealer, I get the same response that the computer say everything is normal and they can't find anything wrong. This is very annoying as my mileage is dropping more and more. I do have something new to tell them. On almost every hill, the automatic will drop out of overdrive to make it up the hill. This is on some hills that are not steep, but fairly long. I've also noticed on the last few tanks, that I am having to mash the pedal more to take off. It took a while for me to notice this, as it was so gradual. Also, sometimes when I hit a bump or go over a rise, you can feel the power come back for a short time, but it eventually goes back.
Now, other than the gas mileage problem, this is a great car. I've had the most fun driving and owning this car. It's classic red and I just waxed it and it looks great. It handles as well as a more expensive sports car and when running right has enough power to move you around and the price is extremely reasonable for what you get.
Another thing I noticed that affected mpg was turning the windshield defroster on. This also turned on the A/C which helped to quickly defrost the inside. My older car never did this so I was surprised.
It's frustrating, especially when you read so many posts from people getting 30+ mpg.
BTW mazdafun, if the mass air flow sensor is defective wouldn't the check engine light come on?
I remember also the old post about air sensor, and IIRC, there was no engine light warning come on. The computer is just feed with wrong informations.
Bruno
Hem, ... ask the dealer to check? ;-)
Bruno
Is this due to the slightly rough idle? Is it common for Mazdas (I'm a former Civic Si owner)? Might the dealer be able to fix it? It's got only about 700 miles, so is still under warranty.
No, my P5 does not buck during acceleration in traffic. 700 miles is still very little. There is probably more friction for the new engine. My opinion is wait until the engine breaks more, probably until 3000 miles. If the bucking problem will be still prominent, then you should worry.
Bruno (former Civic ES owner)
I don't think the 2.0 engine has any balance shafts or other devices to counter the momentum of the pistons. Most small engines don't (I think Mitsubishi owns a patent on a mechanism for small engines). You're not likely to notice except at higher rpms or when idling with too lean a fuel/air mixture (on the verge of stalling).
proteges rock..yes/no/maybe
Your idle should be smooth, but takeoffs in 1st can be touchy. It seems to be a result of the very lean burn at idle (for emissions) and an aggressive throttle tip in.
I've been driving standard for 15 years and I still have trouble making a smooth getaway in 1st. My P5 has over 15k on it.
That's what went through my head when I heard the sound for the first time. Am I off base anyone?
That's what I figured. I've heard the sound before in other cars. Usually though just on hard bumps like speed bumps and such.
If you installed a K&N filter on your P5, I and perhaps others would appreciate knowing how it affected 1) Low-end power, 2) High-RPM power, 3) MPG, 4) Noise Level, 5) Warranty, 6) Anything else you'd care to share.
Also, if you've added a cold air intake tube, what were its affects? What did it cost, how thick is it, and where'd you get it?
1. about the same
2. about the same, but engine revs up a little faster now
3. I'm getting 1-2mpg better than before
4. definitely louder than stock filter, but it sounds good!
5. replacement filter will NOT void your warranty
6. go for either the drop-in, or the 2 most popular intakes (AEM short ram or Injen CAI). You won't regret it!
if you want more info, go to http://www.protegeclub.com/forum , there are tons of information about these intakes, and a lot of Pro owners that have firsthand experiences with these.
good luck!
once you drive it you'll see why Protege/Protege5's have such a loyal following
I love the looks of the car and driving it. Even had a lady in a BMW stop by me at the gas station yesterday to tell me "that's a VERY nice looking car" made my day.
The only problems I've really had are with my dealer. I'll be going back tomorrow to have a scratch in my leather repaired, and to make them do the "pre-inspection" that I fear was never done!!
In any case, I feel the pluses far outweight the minuses.
Sharon
