Bluetooth?
Voice recong. nav?
Touch screen nav?
Allow passenger to program while in motion nav?
Adaptive HID?
What % of the folks really have a problem in your opinion. Do you really think it's more than 5%?
MODERATOR /ADMINISTRATOR
Review your vehicle
I'm sure they got the anatomical metrics right - but they probably messed up on demographics! :-)
I am considering a new FX or an RX and am very concerned with the FX's poor choice of a mandatory permanant donut-spare!! It seems to me if you have a flat in the FX on a trip with the rear end full of luggage/stuff then you are in deep do-do.
A quick aside. Have you driven both cars yet? They are very, very different in terms of drive, handling and overall feel. It's been my experience that people love one of the other but not both.
The seats are fine and even (unlevel?) and do not put any pressure whatsoever on the hips. It may be uncomfortable for you, but it is not in the least a "medical" issue. You just prefer a different seat just leave it at that. Don't go jumping on the "design flaw" bandwagon just because you are more comfortable in another vehicle.
Seems like the Infiniti designers/engineers didn't spend enough time on the interior. May be all their time was spent on the exterior and handling. The interior is definitely the weakest link of this otherwise brilliant vehicle.
I live in Austin, TX.
Does anyone have experience of Infiniti of Austin.
They quoted me "firm" $500 "above" invoice of a '04 FX35 with tech package. It seems to me that the one had sat on the lot for a while since its MSRP is based on old base price.
My first impression of the dealer is sloppiness even though the internet manager did her best.
I wonder the quality of service.
Infiniti of Austin is the only dealer within 100 miles.
Is it a FX35 specific that the latch system should not be used in the middle seat? I've mine install in my Audi Allroad using the latch. I should go check my Allroad manual.
and,it is a nissan engine...........
so,do as i did and take the car in for service to a nissan dealer and there is always one near you.
but,for a warranty repair you must go to a infinity dealer.
my oil change plus the total service checks at 3750 miles came out to $ 24.00
I have a question on Intelligent Key.
If a component of system fails, what will happen?
I guess the following may plausible scenarios.
1. If the battery of remote runs out, then you cannot get in the car as well as cannot run the engine, right?
2. If the battery of the vehicle runs out, what will happen? Is there manual key to get in?
3. For valet parking, does Infiniti provide a valet key? Or should you give the remote to the valet?
When I looked at JD Power rating, FX 35 only got 3 circles for mechanical problems. Are there any known and popular issues at this time?
The intelligent key has a manual key built into it. Slide the catch and remove the metal key. The metal key will open the doors and start the car just like a traditional key will.
"2. If the battery of the vehicle runs out, what will happen? Is there manual key to get in?"
See above. The metal key will still open the drivers door.
"3. For valet parking, does Infiniti provide a valet key? Or should you give the remote to the valet?"
You give the valet the intelligent key with the metal key removed. That way they can't open the glove box if it is locked.
"When I looked at JD Power rating, FX 35 only got 3 circles for mechanical problems. Are there any known and popular issues at this time?"
Nothing major as far as I know. There is the seat comfort issue so make sure you take a long test drive.
If you want to know more about the intelligent key system go to;
http://www.nissan-techinfo.com/infiniti/deptog.asp?dept%5Fid=58
You can either view online or download the FX35/45 owners manual there (no account is requird). The intelligent key information is on page 110 onwards of the 2004 manual.
does anyone know when the 2005's will be out? particularly a 2005 FX35 with tech package in the Greater Toronto Area?
i've called dealers and they all gave me different answers varying from late September to late November.
thanks.
thx
E
Had it towed to my dealer and looked at. The short story is the tech said the filter was dirty (I looked at it - it was dirty, but not disgusting), causing the engine to suck oil from the crankcase into the combustion chamber, resulting in the smoke and noise (the noise stopped after it was warmed up). I call BS on several levels.
In checking on other forums, I have found that this is not an uncommon occurrence, but have not found anyone who has received a satisfactory explanation or a fix to prevent it happening again. Any Edmunds posters have any experience with this?
Thanks...
The Advanced Lane Departure System recognizes lane markings through the use of a small camera mounted behind the rearview mirror. The camera's signal and the vehicle's speed are sent to the system's advanced microprocessing unit, which combines the information to calculate both the distance between the vehicle and the lane marking and the lateral velocity to the lane marking. A judgment is then made as to whether the vehicle is moving out of the lane (depending on the distance and lateral velocity to the lane).
If it is determined that the vehicle is leaving the lane, both visual (indicator light located on the instrument panel) and audible (buzzer) warning signals are generated, alerting the driver to take corrective action. The system will not operate if the camera can't detect the lane markers or if vehicle's speed is below 45 miles per hour.
"Some of the typical scenarios where the Lane Departure Warning system will warn the drivers when they are not giving 100% of their attention to driving and drift out of their lanes of travel are, for example, adjusting the audio system, looking at other occupants, searching for addresses or landmarks when driving on unfamiliar roads, or when concentrating on conversations rather than driving," said Yakushi.
The Infiniti Lane Departure Warning system was developed in conjunction with Valeo SA and Iteris, Inc., the latter that has previously developed LDW systems for the commercial long-haul truck industry.
I suppose activating the turn signal could momentarily turn off the lane departure system?
Yes. that is correct.
1. There is no navigation DVD available for Europe that will work with the Infiniti system as far as I know.
2. The DVD entertainment system is locked to region 1, so region 2 DVDs won't play on it.
Nissan should be able to work on it. It may be worth buying some oil filters, air filters and cabin filters (for the A/C) from the U.S. Also, check on the local availibility of the 20" tyres. Good luck!
