Chevrolet C6 Corvette
11213151718
  • ravanravan Member Posts: 6
    I must say your'e absolutely correct in making these statements that chevrolet just lies instead of fixing the problem..I've been there I know....and they have the nerve to call it the new American Revolution...what a joke!
  • fotorichfotorich Member Posts: 6
    A new wrinkle has been added to my over zealous cockpit heat problem. I called the GM customer service center for the 5th time, and again I was told the rep would not speak to me. I was advised to call the head of Roger Dean’s service dept. and make a new appointment. Rob McDonald argued with me while looking at a photography thermometer accurate to ¼ of a degree, that it was normal to have 120 degree heat blowing from the vents. All they did was fill out the paper work and send me home, a 50 mile trip. On the way home I turned off the AC and the temp started to climb to the ambient temp of 85. Then out of the blue I felt cool air coming out of the vents. The thermometer in the vent showed a temp of 78 and the cars sensor said an outside temp. of 85. Somehow with the AC physically turned off, you know line through the snow flake, the AC was on and running. There has to be a major computer problem when a car can turn on its AC while still turned off in the cockpit.
    Fotorich
  • my5tvettemy5tvette Member Posts: 4
    Hi . I owen a c6 convertible my self ! An I did what you did I turned off the Air Conditioner and set the seating to fresh air and the temp of 60 Degrees. well the air that comes in is from the out side air the fresh air vents comes from the front of you wind shield which take air from out side as well as air from the motor. that might be the issue here. :sick: :(
  • arslanarslan Member Posts: 36
    as an option sometime in the near future?
  • starrow68starrow68 Member Posts: 1,142
    I only have a C5 but I can say from experience that telling when the automatic features are on and off in not straight forward. The system off position with outside vent open does come past the hot fire wall area and before temps outside get to needing A/C the vents will require A/C to cool things off. The dialed temp on the display, even if at 60 or much higher is meaningless if you are not in automatic mode so is not a good indicator. However, finding a really good C6 tech is where the solution lies, if the closest dealer is 50 miles away I don't know what to suggest except to search for more web input in corvette specific discussions. Good luck.
    Randy
    Thanks to all who have responded to my HOT C6. Let try and explain the problem again. After a day or more, and starting the car for the first time; the AC, fresh air and temperature controls having been left as follows:
    AC off (Snowflake with slash line)
    Temperature controls set at 60
    Outside air open (interior recirculation off)
    Fan set at the second third or forth setting.
    When starting the car, and driving for a reasonable amount of time, under these circumstances the temp of the outside air coming in is usually not more than a few degrees warmer than the ambient temperature. This is true even when sitting in heavy traffic. Under these conditions the occurrence of extremely hot air blowing from the vents is rare. I repeat, rare but it has happened.
    However if the car engine is stopped even if the ignition is only turned off momentarily or for an hour or so, with the comfort controls set as described above, the air coming out of the vents will rapidly climb to 100-120 degrees Fahrenheit. I do not mean to imply that hot air blows and than dissipates as one drives the car. I mean the hot air will continue to blow and climb as you drive at highway speeds. The only relief is to turn on the AC.
    Now I do not like to drive with the AC on all the time especially on a nice day. It also robs the car of power and eats up gas mileage
    Fotorich.
    I drove 2 Coupes, back to back.
    1 = MX0, 3LT, NAV (Std. \ base suspension)
    & 1 = MX0, 1LT, Z51.
    Brief background. I have driven 4 door sport sedans for many years. Last Corvette I drove was a ’98 or ’99 C5 owned by a business associate about 5 years ago. Last one I have been inside, except at a show or (stationary) at a dealer, was a Y2K C5. My current ride is a 2005 GP GXP (5.3L V8, 4 speed manumatic w/Paddles), with published quarter times generally clustered in the low 14s.
    Paddle Shift A6. One of the reasons I have waited until now to allow myself to seriously consider a Corvette has been the previous 4 speed automatic trans. No offense intended to anyone with that trans., but each of my past 4 sedans has had a 4 or 5 speed manumatic trans. – and I know I would miss that feature, a lot. ( I have posted several reasons for my preference elsewhere on the Forum. ) This 6 speed trans. with paddle shift manumatic function is an acceptable implementation. Shift response to paddle command could certainly be quicker, but I am reasonably certain now that I could adapt. Otherwise, the driveline is smooth and refined. Engine response is always sharp & immediate. LS2 = great V8!
    Z51. Not as much ride difference as I’d expected, but expecting to put 15K mi / yr on what will be a daily driver ( unlikely to be driven on a track or auto-X ), cheaper & longer lasting front tires, etc. mean I’d be fine with the Base suspension. I did not stress the car, handling-wise, in my drives, and thus would not have been able to evaluate any difference(s) in ultimate limits. I trust the published numbers – as I believe the Quarter Mile ET-s I’ve seen.
    The ride of the base suspension suits me & my driving requirements just fine. The ride is certainly firm, but I found it well controlled \ damped & I expect that it will be livable for my long trips as well as my commute. Also (and one reason I did not fight the suggestion that I drive a Z51 as well as a Base car) neither of these 2 cars showed any signs of extraneous noise, such as creaks or groans or squeaks from interior plastic bits rubbing or from anything that might not be bolted (screwed, glued) together perfectly. I noticed no wind noise at the (brief) 70 MPH cruise intervals. ( Sound systems were off during all of both drives. ) I presume that it would be the same at any speed I’d be comfortable holding & cruising = typically 80 MPH or so. No vibrations noted at any speeds – in either car. I heard no ‘click’ on brake applications.
    The overall impression was of a very well engineered & carefully assembled car. Remarkably so. Kudos, GM.
    Sport seats = excellent comfort & support! 1LT \ base seats, not so much.
    The controls and displays are well done & I felt immediately comfortable in the car – and given that the driving position is a good 6 or 7 inches (or more) lower than anything I have driven in a long time, that really impressed me.
    Acceleration. Well, ‘acceptable’ hardly covers this. ( New cars, low miles, no abuse.) But there is definitely enough acceleration ability to appreciate the difference between my current sedan (again, low 14s) and a 13 flat or better sports car.
    Sound. I will probably replace the exhaust at some point, with something just a bit more aggressive – but the combination \ blend of engine & exhaust was OK. For now.
    Handling. I certainly did not stress these cars. They both felt sure footed, planted, confidence inspiring. I expect that it will be rewarding to drive at 6 or 7 tenths, without being punishing to drive over imperfect surfaces.
    Steering. See above. And: Effort, response, road feel, & kickback = all excellent on the 5 mile (or so) loop I drove.
    Outward visibility. OK. Rear mirror size & placement, etc. is not quite as good as I had hoped (and I am used to) but I think it will be OK. The only remaining issue \ concern for me her is the low roof line & ability to see things like overhead traffic signals. Best I can tell, I ‘lose’ about 6 to 8 inches of windshield height, compared to what I am used to seeing, looking forward. My ‘Solution’ = I will order the CC3.
    HUD = very cool. Even better than mine. I have one in my GXP, and use it literally all the time. This particular example had a slight ( but would be annoying ) distortion, likely in the windshield glass at that particular area – as I moved my head side to side while driving. ( Not caused by polarized sunglasses. ) But the Tachometer display as well as the gear selected & the MPH means I would even more rarely have to look down at the instruments. Well done.
    3LT. 1LT. I already knew that I would want the 3LT. As stated, I found the sport seats (2LT & 3) to be exceptionally comfortable as well as supportive. (I am 6’0” and approx. 225 \ 230 #s.) The 1LT \ Base seats, were noticeably less comfortable, at least for me. I’d also find the lack of the current trans. gear display on the HUD (3LT) to be annoying in a 1LT or 2LT – having to divert my eyes well down off the road, to the DIC display, below the Speedo & Tach. And the telescoping wheel allows me to adopt a more comfortable driving position.
    I will once more mention that I noted ( and thoroughly enjoyed ) the very significant difference in acceleration feel between my current sedan (again, documented as a low 14s) and this 13 flat (or better) C6 A6. Because this is one primary reason for my lusting after the C6, and these drives met my (high) expectations. In my street driving, I can rarely even approach the handling limits of any car, as I always want to leave some measure of safety margin, to allow for the unexpected (for example: sand or oil on the road surface, an idiot move by another driver, etc.) even in (um) ‘spirited’ cornering. But I can ** ALWAYS ** manage a safe place to use WOT. Even if only briefly.
    Yet, quite clearly, the C6 is much more than a very quick accelerating sports car. There was certainly no doubt in my mind after these test drives that the C6 is a thoroughbred: A refined, but very capable grand touring machine - as well as a an outstanding overall sports car. Exactly what I am looking for, right now.
    So. I expect to order a 2007 – for delivery in late September to late October.
    MX0, 3LT, CC3, Monterey Red \ Titanium.
    Thanks to everyone here who has posted information & answered question.
    Comments welcome.
    - Ray
    Very favorably impressed.
    2022 X3 M40i
    Thanks for the great analysis. So refreshing to see someone knowing what makes a difference after seeing so many ask what 'other people would do'. Having never seen the HUD until I got in my C5, my test drives were in used early C5's without the option, I couldn't agree more. After 3 days in the car I then missed it in anything else I have to drive. Having a 6 sp manual and been in a few 4sp auto's on track, as well as two 25 minute sessions in the new paddle shifter, I can say that the 6sp auto is a large step up. Spring Mountain Motorsports Park outside Las Vegas is a great place to get a much better feel for any of the current Corvette's and be more confident behind the wheel. FWIW
    Randy
  • bhill2bhill2 Member Posts: 2,640
    I had one question/suggestion with regard to the distortion in the HUD. Was it at the bottom of the display? If so, you may just need to adjust the display to show an inch or so higher on the windshield. I get a distortion if the display is too low.
    “I had one question/suggestion with regard to the distortion in the HUD. Was it at the bottom of the display? If so, you may just need to adjust the display to show an inch or so higher on the windshield. I get a distortion if the display is too low.”
    Could be.
    Since I was not going to buy that particular example, I only mentioned it to the sales person & moved on with the test drive.
    I have made a note on my ‘Checklist’ to be certain I verify the HUD clarity when ( note, not ‘if’ ) I pick mine up.
    - Ray
    Psychologically ready to buy, but not quite financially ready . .
    2022 X3 M40i
  • jmessjmess Member Posts: 677
    Out of all the driving dynamics of my car I find the steering to be the one that disappoints me; I find it to be a little disconnected from the front wheels and a little slow with lower speed corners. You get use to it but it doesn't offer enough feel for my tastes.
    I have spoken with people in the GM Customer Service Center at least 12 times now and have actually been called back maybe four times. However, the factory Rep and his boss refuse to even address the heat problem and refuse to take any action. Evidently the bean counters have determined it is cheaper not to fix a complicated problem. Let’s face it; most people will not incur the expense of the lemon law ($6,000 up front attorney fees) when the Lemon Law Board is made up of the auto industry people. And if by some freak occurrence you should win you cannot recover the six grand and still have to pay an outrageous fee per mile on the odometer. Most people just lump it, and when they can, buy another car. What the damn bean counters do not take into consideration is that they have lost a customer for the rest of their life. Just as I am doing here by alerting you to the problems of dealing with this company perhaps you and others will go elsewhere to buy a car. AND EVERYONE WONDERS WHY THE AMERICAN CAR COMPANIES HAVE BEEN OVER TAKEN BY THE JAPANESE AND OTHERS. It has been my personal experience that the foreign car companies take care of their customers. I just placed my order for a foreign luxury car using my American 1800 mile C-6 Vette as down payment.
    Sorry to hear about all the problems you've encountered. I would strongly suggest you contact the better business bureau...GM had to replace a car which my friend brought brand new in 2000 which had acid rain on it....the dealer refused to do anything about it so he got all his paperwork together and filed a complaint at the BBB. As a result, he ended up with a 2001 brand new car. GM was very hateful about the whole thing and yea sure my friend had to pay for every mile he used but in the end he won and it was worth the effort..I know GM doesnt really care about their customers as its very evident with lagging sales and their general attitude..best of luck!
  • pony_piratepony_pirate Member Posts: 317
    I find it naive to expect human kindness from a corporation, a smile from a rock. You bought a dream, accept the consequences. That's the American way. :shades:
    Nobody should expect human kindness, but it is not naive to expect ethical treatment. A corporation, or any business, has an obligation to the customer to deliver to them a product that works as advertised. In some cases, failure to do so has resulted in legal action by the government, but in the larger sense failure to stand behind your product is a serious breach of good faith. I will cite one example of the opposite approach; the warehouse chain Costco, with very few exceptions, has a no questions asked return policy. My wife and I bought a large-screen TV from them and it started malfunctioning. The manufacturer was unhelpful. We called Costco to get their help. They, with no further comment, delivered a new one and hauled the malfunctioning one away. Although this was not a car, it is worth mentioning that Costco is not exactly going out of businessdue to this policy, and they now have two customers for life.
    Your point is very well taken and I totally agree with what you've said.
  • tjohntjohn Member Posts: 14
    WOW, I just finished reading the past dozen or so posts. After seeing Jay Leno speak highly of the C6 on the first PAYBACK episode, I thought I would see what real buyers are saying after shelling out their actual hard earned cash for one (lets not forget Leno has 2 full time techs ensuring he isn't stranded on the side of the road).
    I'm dissapointed but not surprised with what I'm reading, it's the same story I read 10 years ago when I thought I would buy a vette - well, once again, GM is selling to dreamers and not enthusiasts. That is most evident in how they treat their customers - you will not find this treatment at a Honda, Toyota, or Nissan Dealership - Or Volvo or even BMW. I really thought they changed, but it seems they haven't. If the Nissan deal (or Toyota) doesn't materialize - GM is doomed.
    I work in a customer support organization on a program that produces fighter AC at $130M a copy, there is no way we would survive if our customer where making posts like these. I have serious doubts about GM making it without the "help" of Toyota or Nissan.
    I have yet to buy a Chevy (I've owned Ford, Honda, Volvo and Toyota) just as quickly as the new C6 caught my eye, I have canned the idea once again of buying one....GM will not gain a new customer as long as real people are making posts like the above.
  • ssmerocketssmerocket Member Posts: 6
    I don't think most of us based our decision to buy a C6 on the horror stories we read in this or any other forum. There are many ,many more happy owners out there with little or no problems to report. Just read through the Honda, Nissan etc. forums here and you will find similar stories and the words "lemon law", "lawyer", "never again", "dealer says it's OK" used over and over.
    I have my own Nissan dealership horror stories....
    If automakers spent as much time and money on quality control as your organization does on fighter aircraft or mine on space launch hardware no one could afford the cost of the automobiles. The quality has to be built in by design, robust manufacturing processes and minimal touch labor. There's bound to be escapes and unfortunately the folks affected will complain loudly to the rest of us as they have a right to do. But don't let the negativity get in the way of your decision.
    There are a lot of dreamers AND enthusiasts who buy C6 Corvettes and they too are real people having a great time driving a great car!
    "WOW, I just finished reading the past dozen or so posts."
    I hope your research went just a little deeper. Since there have been about 34,000 Corvettes produced in each of the last few years, the number of complaints here is surprisingly small. BTW, there are other complaints that don't show up here but do at the make specific boards.
    Some times approach is more important than the facts, shouldn't be but life isn't always fair. I take my C5 to the track, some times 5 days in a month, some times 1 or 2 days. Last Friday it was just over 100 degrees and I was doing over 100mph at four points on a 2.5 mile track each lap, amazing what a robust design will stand up to. That has been the case for over 3 years on a 5 yr old car and the local dealer replaced my full ABS system a couple months ago under extended warranty. That is with a car that has an after market oil cooler, harness bar and 3" wide 6 pt belts hanging behind the seats. What does that prove, nothing, just like any other one off situation. Corvette has been getting good overall ratings for the past several years and is the best of what GM offers. Too bad you won't get a chance to try one out.
  • tsytsy Member Posts: 1,551
    If you look at the boards for any of these other manufacturers you will find people complaining about all of them. But it is a very small minority of very vocal people (or if you're really cynical, people who don't even really own the car!). I myself have had problems with VW and Nissan, so GM is not alone by any means.
    Even Consumer Reports, a publication very very Japanese Automaker biased, shows that the Corvette is one of the most satisfying cars to own. And it is.
    I doubt every car GM makes is perfect. But then again, not every car Toyota makes is perfect either. It would be nice if every 'imperfect' car sold could be returned and replaced, like Nordstrom, but no car manufacturer in the world does this. It's just not feasable.
    The C6 Vette is a great car and don't let a few disgruntled people tell you otherwise. Do the research yourself and you'll find the vast majority of people (even enthusiasts!) agree.
    tom
  • bigmike5bigmike5 Member Posts: 960
    If you feel you are getting nowhere then Lemon Law and court are the place to go. Yes, there may be some up front fees, but you may be able to get those back from the court. I had a friend in law school do one in MA on a Buick. They played hard ball all the way until the judge told the lawyers he wanted this case settled and gave them a half hour to do it. My buddy got a loaner before the case was pending and his money back, plus costs, and he had put several thousand miles on the new car and a large number of miles on the loaner--no deduction for either. That was a long time ago, in a different galaxy perhaps, but when push comes to shove, if you have a case you will win. :shades:
  • jc71251jc71251 Member Posts: 2
    I am about to purchase an 07 C6 coupe. The dealer can get me one with the Z51 handling package immediately or I can wait and he will order me one w/o that package. This will be my daily driver and I don't expect to do any track time with this car. Having read some posts it sounds like the Z51 will mean faster tire wear and a significantly firmer/harsher ride. Correct?
  • brianapalbrianapal Member Posts: 18
    I cannot speak from experience but I ordered my 07 w/o the Z51 package. I also do not plan on racing mine. From my research the Z51 is a slightly stiffer ride, tires wear faster, and not as good a mileage.
    You can go to the GM site and get into the gear ratios of the Z51, 6 speed, auto, and Z06. The Z51 ratios produce a faster car off the line but have a higher ratio also in 6th gear and thus not as good mileage if you are driving it any distance.
    I am sure that you will hear from those that race theirs that the Z51 is the way to go. But that was not my desire.
    I anticipate taking delivery the week of August 7.
    Good luck with your decision!
  • toquinhotoquinho Member Posts: 28
    I also thought about this for a while. I too am not planning to race. I'm buying a corvette because its incredibly fast, is a good daily driver, looks great, is reasonably priced and has good resell value. For me, most important among those reasons is the "incredibly fast" one. How else can I drive a car 0-60 in 4.1secs? Thus, I decided to get the Z51 package. I'm lead to believe that the standard gearing results in 4.5 0-60 (the posted numbers from GM) and the Z51 results in the 4.1-4.3 posted by Car and Driver and Road and Track. 4.5 sounds pedetrian compared to 4.1. That's my 2-cents.
    By the way, my previous '96 M3 had a ride that was harsher than the Z51 I test drove so I wasn't worried about the daily drive with the Z51.
    Thanks to you and Brianapal for two different points of view. I decided to go w/o the Z51 package. I am going from a 350Z that does 0-60 in about 5.3 to a car that does it in 4.5 seconds, so I will give up the extra .4 seconds for a little longer tire wear, smoother ride and better gas milage. Thanks again for the info.
  • terfidiaterfidia Member Posts: 1
    Chevrolet Customer Care Case: #1-421193860 Hot Air Vent
    Any other open cases on this same issue?
    What dealers has any forum member contacted?
    This is a repost of current A/C air vent blowing hot air
    worse than Chevrolet's See No Evil attitude and denials:
    "Thanks to all who have responded to my HOT C6.
    After a day or more, and starting the car for the first time; the AC,fresh air and temperature
    Now I do not like to drive with the AC on all the time especially on a nice day. It also robs the car of power and eats up gas mileage."
    Being a Software Engineer and Investor maybe I'm picky but
    I'm so disappointed to hear of C6 problems, its cheaper to buy a Porsche 911!
    " ... I too am not planning to race. I'm buying a corvette because its incredibly fast, is a ... "
    Just a thought, but what difference does having a fast car make in a world of 65/75 speed limits? I know, I do the 0-75 romp myself and with after market exhaust it is even more fun, but it is really limiting and doesn't teach you much about the car.
    Now, I don't "race" either, street cars don't have the required safety equipment to race, btw. But I do take my C5 to Hi Performance Driving Events (HPDEs) and after more than a year of getting instruction feel I'm a better driver in the car, both on the track and off the track. It isn't racing but I do pass many other cars under the rules of the day, groups are different with their rules, and even with 350hp :) it is a lot of fun passing a Porsche that costs twice what I paid. OK, I admit I like to tweak some Porsche drivers, easy enough to do. I also get passed plenty and most recently I can think of a Nissan 240SX and a Civic, that's another story.
    Before you dismiss getting some instruction that is mostly available on track you might want to get more info.
    Randy
    Good points. I do plan to visit a "racing school". I'm guessing that's not the focus of this discussion group, but I'm planning to look into school options near the SF bay area. Am just hoping its neither dangerous to me (nor the car) nor too expensive. I've heard of costs around $1,000+ per day. Too rich for my blood. Cheers.
    Short bursts of speed allow you to maneuver around traffic, move around the sleepwalkers, skip lightly around risky drivers. And, with a good radar detector, speed limits are relative, mere suggestions. :shades:
    The limits are much more than suggestions, although I'll admit enforcement is blessedly light. And the Radar Detector is a boon to keeping you focused and in many cases slower than you might be otherwise. BTW lazer is out in force in some locations. Those short bursts of speed have risks. I've been reading a lot about Control issues and it seems many have stuffed the new Z06's into walls, latest editorial in Vette Magazine. Driving instruction in anything with 300+ HP is still advisable. Funny thing about 3 years on track, the guy who was most convinced that he didn't need instruction was the guy who was most out of control.
    As for classes around the Bay Area, the least expensive is probably the Thunderhill Street School (THHPDS) that I think is up to $225 for the day, your car. Modest instruction in following the line on track but maybe too little on how to shift smoothly and be in the proper gear when needed. For that you need more class time like at Russell Racing at Infineon/Sears Point or similar school at Laguna Seca. As for the estimate of $1,000 per day that is light when driving a school provided car and when you get up to speed with experience is almost what I figure it costs to run the C5 for tires, brakes, brake fluid, rotors, not to mention that I've added oil cooler, brake ducts, front and rear, 6 pt harness, & fire extinguisher. You do need a helmet but TH does provide some rentals. In the beginning it is no where near that costly since point of fact you aren't really going that fast or hard. You might feel that you are but the wear on those items will tell you different.
  • luckylouluckylou Member Posts: 308
    I have been debating for a long time whether or not to dip into a Corvette.
    I am no longer spring chicken , drive a 2006 LX470 that recently has become very bored.
    It is scary to indulge myself into this expensive vehicle and reading your post makes me wonder.
    The Lexus service is impeccable , if you a loaner , No Problemo.
    I am still thinking maybe should get SC400.
    Any help welcome
    Lou
    This issue becomes one of miles of smiles! If service makes you smile, and it probably does, then stay happy. If Just getting in the Vette makes you smile like I do or for that matter like my wife does then it might also be for you. As noted several times, I tried to keep miles off my 2002 C5 by first driving my old daily driver, Pulsar, and then getting a '95 Vette. In both cases I finally gave up since driving the C5 was so much more fun, even just going 5 miles to the BART station to work. I really like this car. YMMV
  • jayellesevenjayelleseven Member Posts: 150
    for an 06 or 07 Vette, Black on Black Coupe with only Z51 package. Anyone know of any dealers in California (or Nevada Arizona, near by) that will take GMID? I only know of a dealer in Redwood City so far. Thanks!!
  • defrit2000defrit2000 Member Posts: 4
    I've loved driving my S2000 for the past 5 years but it is a love/hate daily driver. Love it when the top is down and you can stir the gears: Hate it in congested traffic, bad weather, and especially with top up and windows closed. I'm ready to have a little easier time of it.
    After reading many of the forum letters I've decided to avoid the Z51 option (live in a winter climate). I need the coupe as being a triathlete I can actually put my bike in back! My questions revolve around sport seats or not, and which transmission to choose?
    I've read little about sound systems. Does it matter? Is the exhaust note that good?
    I took delivery of my 07 Vette 4 days ago. What an great car! I did not get the Z51 option. I also live in a winter climate. I got the coupe as it has the best of both worlds. The weather has been warm and thus I have had the targa top off. With the top off and the windows down it comes close to the convertible.
    I got the 3LT option which was not cheap but brought many options including the better seats. I cannot compare it to the base seats but the upgraded seats are excellent! The 3LT also includes the upgraded sound system and XM radio. I have had XM and thus was already spoiled. I highly recommend it.
    The C6 is very comfortable. I will use it on some short and long trips and have no reservations whatsoever in doing so.
    I have not owned an S2000 but almost ordered one. The reviews that I read however were very negative on the car for any long distances and as a daily driver. The trunk was small and amazing (to me) was the fact that car insurance was cheaper on the Vette.
    The car is awesome! I have gotten so many positive comments on the car in the short time that I have owned it.
    I strongly suggest that you test drive one. I think that you will be pleased.
    The exhaust note is good but not great unless you really get on it.
    I got the manual and cannot fathom anyone getting the automatic. However, half of the Corvettes sold are automatic transmission. If you are in heavy stop and go traffic then I guess that it should be considered but to me the 6 speed manual is half the fun of driving it.
    Just an amazing car!!!
    Hope that this may have helped in your decision.
  • vete07vete07 Member Posts: 3
    Never had a Corvette, but always been dreaming of owning one. My favorite exterior color is Victory Red. However, I am undecided of whether to order it with a black interior or red interior. Can anybody make any recommendations on the pluses and minuses of each color? Really apprciate it.
    the red interior really looks too bright. Not in a good way at all. You should consider two-tone. try to google for some photos.
  • saholzsaholz Member Posts: 5
    Of course those of us who have the red interior think it's great. Personally, I like the red/black treatment...not too bright at all and it adds some style to the interior. My car is silver and it's a perfect color combination.
    Color is all about personal taste, so don't base you decision on what anyone else thinks. Look at the combinations yourself and decide what you like best.
    Stan
    No doubt color choice is personal. Definitely agree with Saholz. You got to go with what looks good to you. However, do keep resell value in the back of your mind as you're buying. I understand that bright colors (inside or out) won't help you to resell the car. Personally, I think red interiors can look great in cars (I like the reddish-browns in BMW M3s and some of the reds in Porsches), but I'm not a fan of the Corvette red. Reminds me too much of my mom's 1988 Caprice.
    Thanks everybody. Your inputs really helped a lot. I am really not thinking about resale, but your inputs (especially saholz's) on contrasting colors was great!
    DigitalCorvettes.com has hundreds of good quality photos. I used in them in deciding my color choices. :shades:
    I wanted to weigh in on the transmission issue, because I had to make a similar decision. I absolutely wanted a stick, because I am like you and love to stir the gears, but it would be my daily driver and I drive in California's famous traffic. I decided to get a stick anyway. Absolutely the right decision. The reason is that the Vette's engine is so flexible that the transmission largely allows you to select the final drive ratio. That is, I can, if I choose, puddle along at 10 mph in second gear but take it all the way to freeway speed if I wish. I only go down to first if I have to stop (and even that isn't really necessary). In short, the only time I am forced to take action is when I have to use the clutch to come to a stop. Other than that, I am shifting for amusement and to anticipate any chances of using the car's jaw-dropping acceleration.
    :confuse: Thank you bhill and brainapel your thoughts are most appreciated and helpful. Many of the car mags have written uncomplimentary things about the manual trans (and the seats, too). Does this transmission shift well? Is it short throw? Is there a problem going from 2nd to 3rd? Remember I'm leaving one of the best ever sticks (S2000) Am I going to be that disappointed?
    As you so rightly point out, with the engine being so flexible I'll probably be shifting a lot less. Brian, my son says the antennae for the XM is "really ugly" do you think so?
    I won't kid you, going from the stick in a S2000 to one in a Vette is going to be a change. It is not especially short-throw, and is anything but delicate to use. It is reasonably precise (although I find the reverse lockout a bit weak)but not 'snick-snick'. My advice would be to drive one and decide if it feels good to you. I am completely at peace with the action of mine and enjoy it greatly.
    I agree, having played with both. The C6 shifter is ok, but it's nothing compared to how slick the S2000 is. After your S2000, the Vette is going to feel like a Mack Truck.
    It's just one of those trade-offs. Your changing to a car with almost 3 times the displacement- there are going to be differences. You just have to decide what you really want.
    The 6 spd auto is quite reasonable, I don't have to deal with the "skip-shift", and it's still very fast, especially for everyday use.
    Good luck!
    tom
    BTW, the XM/Nav antenna is in the front windshield and is not exactly pretty, but I wouldn't say I really notice it either.
    Ive read the past few post about shifting/trans on the C6.
    Now how does one get to really see what its like.. when one is a 20 yr old in SoCal.
    I do not think a dealership will take me seriously, especially if I do not show up with my father. I already drive an 05 G35 Coupe so hopefully they'll see I am serious.
    Any advice??
    As regards the antenna, I am yet to figure out where it is on my Corvette. Others may wish to weigh in on this issue. My wife drives a Honda Accord and the antenna is on the back of the roof. I also have a Jeep Liberty (for the winter) and that does not have a built in XM antenna as I added it myself.
    If your son thinks the XM antenna is ugly on the Vette he better educate me as to where it is because I have yet to figure that out. The owners manual says that it is "on" the roof or the trunk lid. Again, I don't see where it is. (I had read that it was hidden and that appears to be true.) I have the coupe. I suggest that you look at and try to figure out where the antenna is. Also, drive the manual for the experience of the manual but give it a chance.
    The car truly is awesome. The S2000 may have a shorter throw and feel lighter on the road. But this is a world class 400HP car. It truly is awesome! The Z06 is comparable to cars that cost $100,00 to $200,000 and that is not my opinion but the opinion of the car magazines.
    The 6 speed manual takes some getting used to. My first impression was that I hated the 1-4 skip shift but it is easily avoided once you get used to the car. (Shift from 1st to 2nd below 15 mph or above 20.)
    Try it.
    To the guy who is 20, drive up in your present car and hopefully you can convince them that you are serious.
    With your present car, I think you have a shot; especially since dealers are trying to clear out the '06 inventory. Alternatively, would you be willing to have your father come with you? With him there saying 'Yeah, he's serious and he has the means' you should be in.
    I believe that the XM Antenna was changed for 2006 ( and 2007, of course ) and is now incorporated in the rear view mirrors.
    I believe that in 2005 ( only ) on the C6 it was the same "wart" I have on my 2005 GM Sedan.
    "(U2K) XM Satellite Radio included with Bose audio systems and features hidden antenna" - GM \ Corvette Changes for 2006
    Enjoy the drive!
    - Ray
    Still debating . . .
    2022 X3 M40i
    :) Thank you for all the helful replies. Brian, my wife and I read your response to the antennae and you had us in stitches. You have a great sense of humor. They must have changed things since my son last looked at the car.
    To all who have commmented on the transmission, I am going to test drive both but, let's face it, I'm a guy who likes to shift so I know I'm going to get the 6-speed. Know anyone who wants a S2000, 2001 with only 18,100 miles?
    To Jayellenseven I must tell you the local dealership would not provide me a test drive in their single example of the 6-speed Vette. I am a physician and their store is only a 3 minute drive from my office! If a doctor whose office is around the corner can't get a test drive God help a 20 year old. Best bet is to actually write or email a few dealerships with your story and see if anyone responds: I quess.
