Cadillac CTS/CTS-V Transmission Problems
                    Are there any major engine or transmission problems with the 2004 and 2005 CTS cars?
TX,
Mike
See Also: Owner's Reports on CTS Transmission Problems
TX,
Mike
There were no problems with my car until I brought it in to the Cadillac dealer 3 weeks ago to get the oil changed.
Since the oil has been changed, the car now makes a grinding noise when driving at low speeds.
I dropped off the CTS this morning at the dealer I purchased the car from to see if they could find any problems with the car.
The service manager left me a message late this afternoon saying the noise was the rear differential.
How concerned should I be about this?
I have no idea what a rear differential is or what it does.
Thanks for any help.
Bookmark | Reply | Edit | Delete | E-mail Msg
The engine (according to the dealer) on my 2006 Cadillac CTS makes a continual whining noise when accelerating or at a steady speed above 35 MPH, that the dealer says is normal.
Previously, the dealer told me it was my Differential and replaced it.
I'm very unhappy with the car and drive with the radio on at all times to drown out the car noises.
The engine (according to the dealer) on my 2006 Cadillac CTS makes a continual howling/whining noise when accelerating and at a steady speed above 35 MPH, that the dealer says is normal.
They already replaced the Differential.
Go to http://www.cadillacfaq.com/faq/tsb/data/pi/PIP3051b.pdf
I found out about the product from my nephew who works at a transmission shop. The shop's policy is to add the product to every transmission they rebuild. The product is inexpensive, $5 -$10 once you factor in shipping, and won't affect warranties. And no, I don't have stock in the company; I'm just a very satisfied customer.
i am french and i have a cad cts 03'(excuse my bad english)
i have problems with it and i need your opinion..
when i am about 1500rpm and i let the car go 1000rpm ..the car is shaking(?) and i have the feeling is going to stop until the transmission move to the fourth speed..is it a problem of torque converter?
i have an other problem with my front brakes.i changed the rotors brakes and brakes pads but it always noisy..it is really unpleasant to brake and i must put the radio up not to hear it!! can someone help me..??thanks for replying to a desesperate french guy...
Just for some perspective, somebody locally in Nashville has a 1928 Cadillac Sport Phaeton. They recently brought it into Andrews as it needed service since the thing kept dying on the road (and overheating). Nobody outside of specialty shops deal in carburated L-head engines anymore. Parts? Ha! It took awhile (weeks) but the car is back in running shape. They even hired a detailer to clean it up (squirrels were using it to store nuts...literally). That's service.
its almost like when it shift in to 2nd or 3rd, shakes/bucks the whole car. Its intimitten probrem, hense dealer have been unable to pinpoint the issue.
I love the car, but this is getting on my nurve, enough to make me consider trading it in for something else..
If not, how much did you have to pay ?
You might have the car's computer scanned for trouble codes and see if any clues are there.
If they pull some dirty hunk of metal out of some wreck, don't even bother.
Question: Is this something that anyone has heard of? I have never cared for the how the clutch engages in gears 1, 2 or 3 - not smooth and jerky. Is there a relationship between the clutch and oil? (just throwing that out there)
Sorry for being longwinded - this is a potential crisis for me and I could use all the info ammo I can get going into battle. Thanks in advance for help -
How did it turn out with your Caddy? I also have a 2006 CTS and about 60MPH the car started to surge, tacking a 2, dropping to 1, up to 2, then it started bog down and overheated, no engine light came on. I limped off the freeway, had it towed to the dealer. My transmission cooler cracked, sent the tranny fluid into my radiator, back washed into my tranny. I had to replace my radiator, tranny cooler and transmission. GMC posted a bulletin that you can no longer replace/rebuild this tranny, you must purchase new. The total damage was $6700! Did you have any luck the GMC? The car has been nothing but trouble for me..... in and out of dealer for misc. repairs. The last time was my air bags failed and needed replacement. Although it was a safety hazard and a malfunction of the bags, the dealer still charged me $520 to replace them!
