There are some tires that have a tread pattern with a particular direction that should be on one side only. With those tires you must be very careful when backing up.
http://www.epinions.com/content_107936910980
So Goodyear, Firestone, Uniroyal et al went off and did soft-riding, cheap radials. The problem was you had a stiff steel belt sitting on top of a squishy carcass, and the end result was a whole lot of belt-separation problems. Traditional rotation patterns that reversed the rotational direction of the wheel tended to make the problem even worse, so along came the 'swap the tires on the same side' rotation patterns. Firestone - who, oddly, had probably more radial-making experience than any other American tire company, they'd had a line of fabric-belted high-speed radials back in the '60s which were said to be (no personal experience on this point) some of the best tires anywhere - did some of the worst tires (remember the Firestone 500?) in the '70s.
Nowadays tires are (mostly - I can't say I know much about the $25 chain-store rim-protector variety) a lot better than they were in the '70s, so I can't imagine encountering any kind of belt-separation problem purely from swapping sides, though I also see no benefit to moving the tires across the car except in some specific instances (the tires on my track car move around all the time to equalize wear.)
These days, some automakers recommend against rotation, but nearly as I can determine their reason for doing so is primarily one of minimizing dealer-service 'comebacks' - moving a tire from one corner, where it's worn in to that position, to another corner can result in louder noises (particularly with a block-type tread pattern like most tires today), a tire with a minor imbalance will be more objectionable on the front than the rear, etc.
As far as I'm concerned, if you can rotate (some cars have staggered wheel sizes that make rotation economically impractical) you should rotate.
Tires with directional tread patterns pretty much have to be kept on the same side of the car (you can have the tire popped off the wheel, flipped over, and rebalanced before moving it to the other side, which is also the only way to rotate tires on a car with staggered tire sizes, but this is of course costly and can't be done in your driveway.)
There's a very small number of tires that are both asymmetrical and directional - the BFG Comp TA KD is the only one I can think of off the top of my head - these are sold in 'left side' and 'right side' patterns. More pain than I want to deal with.
It seems that SRX production is up to over 200 cars a week now and the 2 previous weeks less than 1000 CTSs were made.
This week 1100 were made. 3 weeks ago CTS production was 13,000 more than the same time last year.
This week that has been cut to 10,500 more than last year.
41,200 vs. 30,700.
I know the 2 vehicles are built in the same plant and they might be built on the same line.
I guess they need to run 3 shifts to get production back up.
My dealer is down to 2 cars!!
http://www.cadillac.com/cadillacjsp/models/gallery.jsp?model=cts
The best tires being made in the US in the '70s were the fabric-belted police radials, at the time the only US tires rated for 125mph use.
Now, back to your regularly scheduled CTS discussion...
The European manufacturers, especially Peugoet had it nailed.
it was more of spring and shock design issue.
You guys probably recall how most American cars would bounce 3 times over a bump while European cars would bounce once.
I might actually do my own oil change next time on the CTS (I still change the oil on my wife's PT cruiser myself). I have curbside recycling that will pick up the used oil for no charge. My only fear is the potential driveway mess caused by the membrane filter.
As for tires...I've been enjoying the new wheels but am debating what to do about the tires. I must have some of those soft radials because my tires seem to be developing flat spots while sitting in the garage over night. It reminds me of the bias ply tires my Grandpa had on his old Ford pickup. I've already had these tires balanced twice; it rides smooth as silk on the trip home from the tire shop and then the next day the ride is rough even on smooth pavement. The ride seems to improve if I drive for awhile but I don't see myself looking forward to miserable ride quality for half of my trip to and from work for the next year or two.
Any suggestions? I'm trying to decide if I'm being overly sensitive or if the tires are truly crap. I've driven plenty of cars with low profile tires so I'm used to the enhanced road feel; this is more like an up/down front/back surging over smooth pavement at 25-45MPH. At higher speeds it's unnoticeable. ??
As far as I know EVERY vehicle manufacturer recommends tire rotation and the reason is that each wheel position will develop a wear pattern peculiar to that position. Rotating the tires prevents this wear pattern becoming so large that it develops into a noise or vibration. Typically if you rotate a set of tires and get a new noise or vibration, then the tires were overdue for a rotation, the inflation pressures were low, and / or the vehicle is misaligned. Rotating the tires puts a new wear pattern into the tire and cancels the old wear pattern, thereby prevent any pattern from becoming severe. BTW if you don't rotate tires you will be guaranteed to get irregular wear which will cause excessive noise and vibration - the only question is will your tires wearout before the irregular wear becomes bad enough to be perceived. The front tires on a FWD wear so fast they usually don't, but the rears wear so slowly, it's almost impossible to avoid irregular wear and you wind up throwing away a tire with lots of tread left.
BTW the stiff belt was not the cause of belt separations in the early days of steel belted radials. It was a combination of the adhesion of the rubber compound to the steel and the rubber compound breaking down to form a weak acid causing corrosion. All the tire manufacturers had the problem, but Firestone seemed to be the last to understand that a change in rubber chemistry was needed.
Also, the belts do not "take a set" went first used, nor do they "shift". These 2 phrases are used to try to describe why certain things happen. Unfortunately the explanations aren't accurate and they lead to misunderstandings. Belts are a composite of rubber and steel. Once cured, the tire will flex but the relative position of the belts is fixed. UNLESS something goes wrong. That's when these "explanations" are trotted out.
Hope this helps.
No it is not a new Cadillac.
Radial Tuned Suspension.
My aunt and uncle had a '76 Pontiac 4 door(grandAm?) that had beautiful ride quality.
Sitting here with my six week old daughter (getting her up to speed on the auto industry) happy to see you're still enjoying your cars! Sorry I haven't been around for a while, it's been a bit busy with the CTS-V coming up to speed in the plant and other launch activities (not to mention the little one!). Has anyone bought an '04 yet? I've been driving one for the past three months and the jump in torque is very noticeable, especially part throttle. Overall it makes the car seem a bit more nimble
Kids can change your priorities, but I bet you are having fun.
We have some '04 owners here. But I think some people are waiting for the Base and 1SB cars to be available with the Sport Package.
There was a production problem with the non chrome 17" wheels.
b4z, thanks for those pics. I've been meaning to check out the updated website for some 04 pics. You still thinking about a CTS? Saw an 04 last night(or else an 03 with aftermarket dual exhuast) in traffic. I cam upon it so I noticed the dual exhaust and frankly, did not pay attention to the license plate surround. At one point I was next to it and the couple in the CTS seemed to be checking out my LS as much as I was checking out their CTS.
This is my first post to this board so I hope this does what it is supposed to do!
I ordered 1SB with Sport package and it was on restriction until 8/14. I talked to the dealer on Thursday and it has been manufactured and is in transit! I will have the Sport package on the Luxury model. Waited as I didn't want the moonroof or fancy sound system. I know you will all welcome me with a "why not?"
Don't care for sunroof either as i am very tall.
No CTS for me right now. Refi the Impala or a '95-97 lexus LS 400.
About loose bolts--- I had my CTS repaired after being hit by another car. It was fixed in May. About two weeks ago. I was in traffic and a friend of mine was behind me. He pulled alongside and told me to check my rear bumper. He said that it looked like it was moving? When I got home, I touched it and realized that it was very loose. I drove to the dealer and called a service person out to look at it immediately. It was repaired there. When I opened the trunk , he pulled back the trim and carpet. Of the four bolts that were to hold it (the bumper) in place ...two were missing and the other two were so loose that they were about to fall off. He added the missing bolts and tightened the loose ones.
Not as bad as your transmission job, but a careless error nonetheless....another Flat Rate Tech?
When We drop off our CTS's for service we must demand a written inspection report documenting all work done,from a major job to even correctly tightening an oil drain plug or rotating tires .Each step must be listed . Dealer service departments completed work inspection practices are still in the stone age because they can get away with it . Flat Rate Techs who screw up a job should not get paid for that job at all . NEVER mind they have to eat the time for the come back. They are playing the odds with our lives and time wasted going back.
. Having us come back to fix their incompetence while telling us that they will cheerfully fix there problem has to cease. It would be relatively simple to institute an inspection process into any dealership . Would the techs complain ----you bet --- All of there incompetence would be immediately exposed , but any manufacturer or dealership owner who really cared would DEMAND it . does anybody do it ? YES,there are many independent shops who do it to some degree and I have heard a commercial of a large chain oil change outfit who has started an written inspection report . I would go to them for any services they offer.
To improve quality Cadillac uses the latest and best of available inspection techniques to give us a very good CTS . The dealers have done NOTHING to improve the quality of the work /services they provide
'Belt slip' is a very commonly-used term to describe the movement of the steel belts relative to the carcass, and it still occurs in some cases today though not as frequently. Whether you regard it as technically accurate, it is a reasonable description of the problem.
I'd heard somewhere that in the '721' Firestone attempted to correct their belt-corrosion problems by coating the steel. May or may not be accurate.
This doesn't excuse sloppy or dangerous work, but it does indicate the kinds of pressures that techs work under.
Gotta run now, more details later including a run down on the mods they do to the class cars.
PS PMDRIVER... nice little commercial they show on day-one. Now I know what you look like! And keep us posted on the -V with whatever you can, please.
Like you, I have a young child for my CTS to transport (11 week old boy) and I'm happy that this car is safer than average when we strap him into his car seat. Truthfully, if we were in the market now, we'd probably be more SRX customers because of the baby, but my wife and I still have lots of smiles every time we drive this car.
And unlike some of the recent reports, I have nothing but nice things to say about my dealer in Nashville, Andrews Cadillac. Their work is fast and their prices are fair. The reps who handle your car have all worked there for years and know you by name. For my last oil change, I pointed out that one of the 5 chrome bolt covers on my polished 17" wheels had fallen off. They found another one from parts, screwed it on, and said "Have a nice day". I would have paid for it, but they wouldn't have any of that. Nice folks to do business with.
Any body else have this problem??
They initionaly said one day. Each time I call them they say 3-5 days to fix. This has happened twice.
Today after 4 days of the 3-5 days,some one started to work on it. I call on MY Cell Phone from the car and let them hear the messages.
The system was designed around Analog cell technology and wont work with the digital towers that are close to my house. I have also tried it a 100 miles south near San Diego.
They even called me up last week and gave me a number for my car, it worked ONCE when they called, but today they tried again and it did not work.
They are redesigning the cell phone system for digital and it is under beta test. Apparently they will have to change all cars with On Star from analog to digital with a full recall.
If you have the same problems check with the dealer and see when you can get digital. Analog will only good for a few years,maybe 2006,then it will become all digital, so those with a 2003 might end up with something that will NEVER work before the 4 years or before you get to 50000 miles.
Lets BUG them.
I am really upset as we were going away on a trip, would like to use it. They gave me more minutes. I am sure that in the future, when they get digital working, it will be great for hands free dialing, and probally a LOT cheaper than it is now.
Unless it works soon will go to Better Business and report this. They should not put out a system that is obsolete and I have a 2004 car made in July.
Today I waxed 80% with Mequires, alot of work, will finish tomorrow if it is cloudy.
berry
As to why your personal calling isn't working, my guess is it has to do with either your vehicle's Onstar unit or Onstar's system of tracking minutes. If you can call Onstar from your car, then the cellular part of the system is working. Being analog should not have anything to do with this.
Another test is to push the onstar button and say "my number". It should tell you your car's phone number and display it on the DIC. Dial that number from your home and/or cell phone while you are in your car with the engine running to see if you can receive calls.
-Hope that helps.
On another similar note, my wife was shopping in a local trendy yuppie [non-permissible content removed] shopping district when she ran into a lady with a cute dog that my 1.5yr old wanted to pet. As she was talking to the lady someone walked by and told the woman that she saw her on TV that morning. My wife asked "are you famous?"...the lady replied "I'm the voice of Onstar". My wife told her that we had the CTS with Onstar and enjoy using it. I told my wife that she missed a golden opportunity. She should have interrupted the woman while she was talking and said "slower"..."again"..."sounds like"..."goodbye".
If you don't know what I'm talking about now, you will as soon as you get Onstar "working"...good luck!
It says ON Star Ready, then when you say anything it says Personal Calling Not Available.
Even tried SEX and it says goodbye. Very smart!
On Star is VERY FAMILIAR with my problem, the girl I talked too says she has had three similar problems recently. She is the technition that will trouble shoot it with the cell towers. Takes another day for the ANALOG guy to respond. Will call me each day and give me progress, but each time you complain , will take 3-5 days to respond.
I am in Orange County CA where we have towers everywhere, big population.
Got to get on the beta test for digital.
I also do hot believe Analog will survive the 5 years, probally go away in 2006, according to ON Star. In fact it is gone now other wise they wouldn't be doing digital beta testing.
Berry
I know one other person reported a similar cut a couple of months ago. Has anyone else had a similar problem? I am wondering if there is any connection between this and the fact that the car was I use has a guide track on the left side. I think I will use another car wash in the future.
This seems like it would be a very HOT optioned car. Black over ebony, no sunroof, the Sport Pack., 3.6, Bose, and power pass. seat. No extras. Very attractive to me to, but I don't think the '02 Avalanche is worth enough on trade....bummer!
Did they make very many non-LuxSport cars with the Sport Package, or is this just a very rare car, being as it was one of the first '04s? Anyone interested?!
I remember my previous dealer in Atlanta telling me that half of their buyers wanted a base car with almost no options to they could get out of the dealership in the low 30K's. That may be still holding true.
MSRP including destination is $49,995.
http://media.gm.com/
Then when I say My Number, it comes back with number they dont know about, it is different from what they told me. An area code they have never heard about. Can Dial a number now but says no units, minutes Pending according to the units gal.
Cant find out just what the problem is, they do not understand. Says it should be working by Sunday. They call me every day or so.
Going on vacation this week, so want to try it out as we drive north, maybe to Canada, depending on the weather, at least Montery CA.
It is cold as hell in western Canada now so may wait till next year to go to Vancouver. I like the OC weather, usually great about 80 high, 60 low.
They still say cars will be changed to allow dual mode, at least my car 2004. Maybe it has dual mode, they do not know. Or it may be analog/digital, would be nice to know. They say it will change by flipping a switch fron analog to digital at On Star
See the site below for a description of the Federal ruling on On Star.
http://www.onstar.com/us_english/jsp/faq/not_faq_main.jsp?topPage- =not_faq_federal.jsp&id=16&title=Federal+Ruling
Berry
b4z, a little more than I expected but considering the serious hardware the CTS-V packs, that price can be justified.
The voice repeated it so fast even the technician had to have me replay it back 5 times.
She did not recognize the area code. I want a 949 area code.
berry
"In August, Cadillac had its best sales month since October 1990. CTS had 4,278 deliveries in August, a monthly sales record, up 30 percent from last year and 62 percent calendar year-to-date. Total Escalade sales had its best-ever sales month with 5,616 deliveries, a 7 percent improvement over last year."
Got 2 in the mail today, but my buddy snagged 1 to buy a new truck............geo
